NM-A751 REV:1.0 disable ram
  • cracksoft1
    • Oct 2014
    • 3
    • espaรฑa
    NM-A751 REV:1.0 DISABLE RAM
  • gunjanksh
    • Jul 2016
    • 8
    • Nepal
    hi remove all RAM chips and supply try shifting Board ID resistors.
    • Bios Cracker
      • Oct 2024
      • 312
      • India
      Send All details as per forum guidlines.
      Model:
      Serial Number:
      Problem:
      Attach Dump File:
      • brotank
        Lenovo C861 Ryzen 5 disable 4GB samsung onboard ram
        by brotank
        I quiet struggling with board lenovo c681 to disable 4gb samsung onboard ram because they're faulty, I followed the instruction on the schematic to disable them with resistor codes but still not detecting the ram on the slot.
        can someone disable onboard ram from my dumped bios, please ๐Ÿ™
        I tried the other bios on this forum with disabled onboard ram, but no success
        my final try is to find someone that can help disable onboard ram in my dumped bios attached in this post.
        after that I officially give up ๐Ÿ˜‚
        thanks for awesome jobs ๐Ÿ˜Š...
        03-16-2025, 12:51 PM
      • b-slayer
        Acer A317-53 need help to disable faulty onboard ram
        by b-slayer
        Hello.
        I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
        - first one is to modify le bios to disable the onboard ram.
        - second one is to disable the onboard ram by desoldering some components on the mainboard.
        so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
        so i found that my motherboard...
        10-12-2024, 03:46 AM
      • Mr.Ultimate
        Alienware 13R3 bios mod request - to disable dedicated graphics (dgpu failure)
        by Mr.Ultimate
        Hi everyone, hope to get someone to help and modify bios rom for me.
        I need to disable dedicated nvidia graphics chip permanently.
        GPU chip had failed(cracked silicon DIE) and I can only use laptop without failing if I disable nvidia graphics in dev manager (but it still draws power from battery and generates thermal signature.
        Ideally if it was disabled from bios at preboot.
        I believe it is possible, because if I attatch external alienware graphics amplifier , laptop at boot will disable dedicated graphics #1 (failed one) and will only boot with AGA...
        08-06-2024, 05:15 AM
      • mat2k
        Disable faulty soldered RAM on Acer A315-22
        by mat2k
        Hello, I've been googling for some pointers on this but couldn't find anything that applies to this board. I have an Acer A315-22 (board NB8607) with faulty RAM between 142 and 174mb. I just wanted to disable the onboard RAM altogether, but this one doesn't seem to have any memory down ID resistors or strap in order to disable it. I'm attaching the schematic I found, the boardview for it also seems to be available somewhere in this forum but I still don't have a use for it lol.
        How would I disable the RAM on this PC? Thanks for the help.
        [MOD EDIT] LINK to boardview + schem...
        06-02-2024, 11:26 AM
      • RotVik
        ASUS FX505GT disable discrete GPU
        by RotVik
        Hello everyone, ASUS FX505GT, dedicated GPU is shorted dead, I would like to disable it completely to activate only integrated CPU graphics.
        Any ideas? I was thinking to start by removing L8700 and L8701 so +NVVDD wont power the GPU, and maybe editing BIOS to disable it and also eliminate the possibility of fans going full speed and that kind of weird behavior.
        Is this possible? Any help would be great!
        Schematic & Boardview
        https://www.badcaps.net/forum/troubl...ets-and-mobile...
        05-15-2025, 05:19 PM
