NM-A751 REV:1.0 disable ram
  • cracksoft1
    • Oct 2014
    • espaΓ±a
    NM-A751 REV:1.0 DISABLE RAM
  • gunjanksh
    • Jul 2016
    • 8
    • Nepal
    hi remove all RAM chips and supply try shifting Board ID resistors.
    • Bios Cracker
      • Oct 2024
      • 322
      • India
      Send All details as per forum guidlines.
      Model:
      Serial Number:
      Problem:
      Attach Dump File:
      • brotank
        Lenovo C861 Ryzen 5 disable 4GB samsung onboard ram
        by brotank
        I quiet struggling with board lenovo c681 to disable 4gb samsung onboard ram because they're faulty, I followed the instruction on the schematic to disable them with resistor codes but still not detecting the ram on the slot.
        can someone disable onboard ram from my dumped bios, please πŸ™
        I tried the other bios on this forum with disabled onboard ram, but no success
        my final try is to find someone that can help disable onboard ram in my dumped bios attached in this post.
        after that I officially give up πŸ˜‚
        thanks for awesome jobs 😊...
        03-16-2025, 12:51 PM
      • b-slayer
        Acer A317-53 need help to disable faulty onboard ram
        by b-slayer
        Hello.
        I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
        - first one is to modify le bios to disable the onboard ram.
        - second one is to disable the onboard ram by desoldering some components on the mainboard.
        so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
        so i found that my motherboard...
        10-12-2024, 03:46 AM
      • Mr.Ultimate
        Alienware 13R3 bios mod request - to disable dedicated graphics (dgpu failure)
        by Mr.Ultimate
        Hi everyone, hope to get someone to help and modify bios rom for me.
        I need to disable dedicated nvidia graphics chip permanently.
        GPU chip had failed(cracked silicon DIE) and I can only use laptop without failing if I disable nvidia graphics in dev manager (but it still draws power from battery and generates thermal signature.
        Ideally if it was disabled from bios at preboot.
        I believe it is possible, because if I attatch external alienware graphics amplifier , laptop at boot will disable dedicated graphics #1 (failed one) and will only boot with AGA...
        08-06-2024, 05:15 AM
      • mat2k
        Disable faulty soldered RAM on Acer A315-22
        by mat2k
        Hello, I've been googling for some pointers on this but couldn't find anything that applies to this board. I have an Acer A315-22 (board NB8607) with faulty RAM between 142 and 174mb. I just wanted to disable the onboard RAM altogether, but this one doesn't seem to have any memory down ID resistors or strap in order to disable it. I'm attaching the schematic I found, the boardview for it also seems to be available somewhere in this forum but I still don't have a use for it lol.
        How would I disable the RAM on this PC? Thanks for the help.
        [MOD EDIT] LINK to boardview + schem...
        06-02-2024, 11:26 AM
      • bbenalmadena
        Old Sony VAIO da0hk5mb SVE1512E1E disable Radeon video card
        by bbenalmadena
        I have a Sony VAIO SVE1512E1E (motherboard da0hk5mb) video card is broken, has artifacts, I want to disable it, the processor is an I3-3110M that supposedly has an integrated Intel GPU and I want to disable the onboard Radeon so that can be used.
        I download some schematics, and tried to remove VPL1, but then the laptop starts some leds, and shut off. Should I try to lift VPL1 and VPR47 and pass a cable to one tip of VPR47 and the other back to VPU1 to see if that works or it is pointless?
        That seems to be some feedback to VPU1 and I guess if it does not detect voltage, laptop...
        08-30-2025, 10:40 AM
