Acer Nitro 5 AN515-57, GH51G LA-181P Rev: 1B not booting.
  • MicroSMD Lab
    • Sep 2018
    • 145
    • Trinidad and Tobago
    Good day, I need some assistance with this laptop. It came in with no power after a liquid spill. The device was very dusty and one of the inrush mosfets exploded, the other was shorted and of course a shorted 19V power rail. I replaced the following defective components to clear the short:
    PQB4 (AON7380, this one blew up, pads needed to be rebuilt, no vias)
    PQB3 (EMP21N03HC, this one was shorted)
    PQB1 (L2N7002WT1G, burnt and cracked)
    PUV2 (QD9619AQR1, shorted)
    After replacing these components and checking to make sure there were no shorts, the laptop powered on for 8 seconds, the fans spun twice then the laptop powered off. I am using known-good RAM. The CPU heats up when it attemps to power on, CPU resistance on the coils is around 27 ohms. The CPU core voltage is 1.8V which I think is too high.
    At this point I'm hoping the CPU is still good and maybe it's a bios issue. TIA for your assistance.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Core voltage for 10/11th gen cpu at 1.8V is ok and not too high.
    Is the 19V rail shorted again?
    • MicroSMD Lab
      • Sep 2018
      • 145
      19V rail is good. If I press the power button another time, keyboard backlight comes on, fan spins once then it powers down again. Appreciate the quick response, thanks
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Yes, I too feel cpu is still good to go-so worth investing time as this is expensive mb.
        What are the voltage on coils for the brief time it turns on. You may need to switch it multiple times to measure all the coils.
        • MicroSMD Lab
          • Sep 2018
          • 145
          These are the voltages:
          PLB2 - 0.216V (no batt)______PL1801 - 1.9V_______ PLW1 - 1.2V
          PLM1 - 1.2V________________PLV4 - 0.8V_________PLH2 - 1.8V
          PL501 - 5V (AlwaysON)______PLV3 - 0.8V_________PLH3 - 1.8V
          PL302 - 3.39V______________PLV2 - 0.8V_________PLH4 - 1.8V
          PL1102 - 1.8V______________PLH14 - 0.8V________PLG101 - 1.8V
          I noticed that I didn't solder PLV2 after raising it to locate the shorted DrMos. After switching on multiple times to take the voltage readings, the fans spin and stop 3 times, I put the board back in the housing and it booted. I suspect that because I didn't fasten the heat sink all the way, it shut off due to high temperatures or the missing GPU voltage.
          Thanks again for your help.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Nice to know its fixed but a word of advice-Never try to turn on a gaming mb without heatsink,it"ll never boot and shutdown.
            • MicroSMD Lab
              • Sep 2018
              • 145
              Thanks, for the benefit of others, I did put on the heatsink but only fastened 3 screws lightly. From now on I will fasten all properly before testing.
              • reformatt
                • Feb 2020
                • 1534
                Just had one with liquid damage on the back of the GPU and CPU. Dead short on main power rail, and could see solder balls squeezed out from under PUV4 (QD9619AQ). PQB3 (EMP21N03HC) also shorted as expected. These GPU's measure close to zero ohms to ground, so it's hard to know whether it got damaged by having 19V put on it.
                Cleaned up this area, and replaced a few corroded caps and I could so no issues with the other buck converters in this area. Replaced PUV4 and PQB3, and they instantly shorted again on power up. I neglected to replace the PUV1 (UP9512Q) controller (which I should have done), and replacing that along with PUV4 and PQB3 fixed the fault. Surprising the GPU survived, but the power bricks for these shutdown pretty quick on overload.
                Replace the damn controller if you have a shorted DRMOS as you likely get 19V straight into it. That's a given, not sure why I didn't do that in the first place. Seniors moment maybe.
                • reessi
                  Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                  by reessi
                  Hello:
                  I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                  I started on the ACER:
                  Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                  All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                  I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                  10-29-2024, 11:31 AM
                  ACER NITRO Nitro N50-600 NITRO 50 i7-9700 Specification for Upgrade or Repair
                  This specification for the ACER NITRO Nitro N50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro N50-600 boardview and NITRO Nitro N50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                  09-12-2024, 03:28 PM
                  ACER NITRO Nitro GX50-600 NITRO 50 i5-8400 Specification for Upgrade or Repair
                  This specification for the ACER NITRO Nitro GX50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro GX50-600 boardview and NITRO Nitro GX50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                  This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-07-2024, 04:10 AM
                  Acer Nitro Nitro 5 AN515-57-775V Notebook 5 Specification for Upgrade or Repair
                  This specification for the Acer Nitro Nitro 5 AN515-57-775V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-57-775V boardview and Nitro 5 AN515-57-775V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
