HP Spectre x360 -DA0X36MBAE0 wont turn on after battery change - Chip identification required
  • AJ847.63e
    • Aug 2020
    • 171
    • Africa
    i all,
    Cab anyone identify this chip? Pics attached. It's marked L8=6E 74L.
    History: laptop came from a e-cycler. Dropped off a few laptops wanting to get rid of them so he asked if we wanted them, apparently he tried swapping the battery on this one and acidentally broke the tip of the battery connector and plugged the battery in upside down.
    All readings on the battery pin seem normal though (comparing to a working same model board).
    Connecting the charger you can see the above mentioned chip pulsing so it looks like its going into protection mode, but checking diode mode readings everything matches the readings I get on my known good board.
    That said that does not mean the chips not faulty, so I wanted to see if anyone could identify it so I can get a replacement. Would rather not ruin a known working board.
    Thanks for your assistance.
  • mon2
    • Dec 2019
    • 14766
    Search for ‘L8= Richtek’ on google.
    Results in RT6256BGQU.
    • AJ847.63e
      • Aug 2020
      • 171
      • Africa
      Thank you. Dam none of our donor boards have em so I’ll have to order them in.
      very strange that the diode mode measurements on the chip itself and the battery connector are the same between this board and the known good.
      • AJ847.63e
        • Aug 2020
        • 171
        • Africa
        Does anyone know if there is any boaedviews / schematics that are similar to this model since the exact ones are not available? I found a tiger lake one which looks similar physically but components wise it’s completely different.
        • mon2
          • Dec 2019
          • 14766
          The last pic of the chip appears to show a crack on the top of this component. This part is damaged.
          • AJ847.63e
            • Aug 2020
            • 171
            • Africa
            That was just crap from my cotton swab, took me a good 15 minutes of ipa and different variations of markers and an angled torch to try fill in the writing to make it legible.
            • AJ847.63e
              • Aug 2020
              • 171
              • Africa
              Unfortunately, it wasn't the RT6256BGQU​.Caved in and swapped it from the known working board but still same symptoms. 😓.
              What else would you expect to get damaged when plugging in the battery upside down? Battery connector diode readings match the known good so I'm puzzled.
              Only thing getting slightly warm apart from the 3.3/5V LDO is the TPS on the back of the board but its only getting to 38c and all its pins match the diode measurements on the KG board.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Measure Resistance to GND on all coils/3V LDO/5VLDO
                • AJ847.63e
                  • Aug 2020
                  • 171
                  • Africa
                  Looks like the PCH has been hit, popped it under the thermal cam and removed the heatsink and you can see the tip of it pulsing in sync with the LDO chip.
                  Coil resistances starting from the top left of the CPU 19.5 4.8, 4.8, 7..
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Incomplete reply to post#8. So cant confirm anything.
                    Btw, that's not the way you diagnose whether a pch is faulty or not.
                    • AJ847.63e
                      • Aug 2020
                      • 171
                      • Africa
                      Sorry didn't do the rest because I thought there's no point if the PCH is cooked.
                      Starting from the small one on the bottom left of the board (charging port side):
                      20k, 20k, 20k, OL, 67 (Bottom left cutout of copper RAM shield), 73, 52, 71, 21K.
                      What do you mean that's not a way to test if the PCH is faulty? I thought it should not be getting extremely hot in just one point where the rest of the die is stone cold. Diffused spread out heat yes that would be fine, as it's generating it's rails. But not just the top tip of it. I'd post a pic, but it blinks so fast I can't get it.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Still resistance to GND measurement on 3V ldo and 5V ldo not shared.
                        • AJ847.63e
                          • Aug 2020
                          • 171
                          • Africa
                          3v3 LDO = 6.5K
                          Does this chip have a 5V LDO? According to the datasheet that is only for the C variant (RT6256C)
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Pllease specify which TPS ic is getting warm.
                            • AJ847.63e
                              • Aug 2020
                              • 171
                              • Africa
                              TPS65988
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Its PD controller. What's the resistance to GND on LDO_1V8 & LDO_3V3? Check whether SDA/SCL lines are showing low resistance.
                                • AJ847.63e
                                  • Aug 2020
                                  • 171
                                  • Africa
                                  LDO_1V8: 1.8M
                                  LDO_3V3: 53.6
                                  SDA: 21.8K
                                  SCL: 21.8k
                                  • mon2
                                    • Dec 2019
                                    • 14766
                                    LDO_3V3: 53.6
                                    Ohms?
                                    • AJ847.63e
                                      • Aug 2020
                                      • 171
                                      • Africa
                                      No, 53.6K. And thats both on this board and on the other board that was working.
                                        HP Spectre x360 Spectre x360 - 13-aw0197tu Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                                        This specification for the HP Spectre x360 Spectre x360 - 13-aw0197tu Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 13-aw0197tu boardview and Spectre x360 - 13-aw0197tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        09-06-2024, 12:10 PM
                                        HP Spectre x360 Spectre x360 Conv13-aw0054na Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                                        This specification for the HP Spectre x360 Spectre x360 Conv13-aw0054na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 Conv13-aw0054na boardview and Spectre x360 Conv13-aw0054na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                        09-06-2024, 11:50 AM
                                        HP Spectre x360 Spectre x360 - 15-df0068nr Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                        This specification for the HP Spectre x360 Spectre x360 - 15-df0068nr Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 15-df0068nr boardview and Spectre x360 - 15-df0068nr schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        09-06-2024, 07:20 AM
                                        HP Spectre x360 Spectre x360 - 15-ch050na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                        This specification for the HP Spectre x360 Spectre x360 - 15-ch050na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 15-ch050na boardview and Spectre x360 - 15-ch050na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        09-06-2024, 06:21 AM
                                        HP EliteBook x360 1030 G4 + Spectre Tech Tote Hybrid (2-in-1) Specification for Upgrade or Repair
                                        This specification for the HP EliteBook x360 1030 G4 + Spectre Tech Tote Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Spectre Tech Tote boardview and 1030 G4 + Spectre Tech Tote schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                        09-06-2024, 11:39 AM
