Compaq cq40 no power issue 3v5v
  • sasser
    • Dec 2012
    • 364
    • Malaysia
    hye all i got 1 compaq cq42-627tu. intel board. LA-410P. check 3v&5v not present. ene chip also no volt. anyone had face with this issue?
    19v is present
    C482 no volt R384 r740 c475 c474 this area no volt. are that means southbrigde culprit?
  • opamp
    • Dec 2012
    • 160
    • united states
    Re: Compaq cq40 no power issue 3v5v
    Do you have voltage on PL302 and PL303? if not troubleshoot PU301
    • sasser
      • Dec 2012
      • 364
      • Malaysia
      thanks opamp to response. pl303 and pl302 no power. its that tu301 TPS51125 ?
      • aanan
        • Dec 2010
        • 222
        • India
        check voltage on TPS51125 pin no16.
        • sasser
          • Dec 2012
          • 364
          • Malaysia
          im not find any TPS51125 here only TPS51124. pin no 16 no volt.
          • sasser
            • Dec 2012
            • 364
            • Malaysia
            ENE KB926qf already change. also no 3v&5V
            • opamp
              • Dec 2012
              • 160
              • united states
              3v and 5v comes out of TPS51124. So that means it has to be operational before you get voltage on ENE KB926qf. Change TPS51124
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3616
                • slovakia
                it comes from TPS51125RGER_QFN24_4X4
                from your TPS51124 is switched rails 1,5V/1,8v
                • sasser
                  • Dec 2012
                  • 364
                  • Malaysia
                  opamp thanks for your response. im try to change today. ktmmotocross i didnt find TPS51125RGER_QFN24_4X4 i only found TPS51124.
                  • sasser
                    • Dec 2012
                    • 364
                    • Malaysia
                    for all if i change TPS51124 but no volt on vin at pin 16 no point right. i need to trace the 5v&3v before come into TPS51124. from schematic what i must check again?
                    bios chip also no volt.
                    • alihomee
                      • Dec 2012
                      • 1580
                      • malaysia
                      tps 51125 is responsible for 3v and 5v try replacing it with a good one
                      • whaldsz
                        • Apr 2013
                        • 395
                        • Philippines
                        There's no point in checking further if pin 16 don't have a proper voltage. you must check the charger circuit.
                        Measure the pin voltages of BQ24740 and post back. You may also want to perform some resistance test or check for overheating components specially capacitors along the B++ rail.
                        Also the voltages of PQ100 and 101.
                        • sasser
                          • Dec 2012
                          • 364
                          • Malaysia
                          thanks whaldsz i see BQ24740VREF got acin from b+ rail. i will post the result . PC109 PQ101 PQ103 should have some volt.
                          • sasser
                            • Dec 2012
                            • 364
                            • Malaysia
                            i got zero volt on pin acin BQ24740VREF then trace up to PR102 no volt also. then i go to PQ103 pin 1-4 all i got 19v but 6-7 00.023 ~zero . are this mosfet culprit but i already changed with another fet ? then i try to trace PQ104 there have 19v then pc106 19v and pr106 19v .
                            • sasser
                              • Dec 2012
                              • 364
                              • Malaysia
                              is see now where pu301 is not use TPS51125 but i dont know what code. but measure vin on that ic still no volt. PC312 also no volt
                              • vvacl
                                • Jun 2012
                                • 22
                                • VietNam
                                TPS51125 can be replaced by RT8205 (or CJ=xx or UP6182)
                                Check PU301:
                                pin 16 : 18.5v
                                pin 3: 2v
                                pin 8: 3v3
                                pin 17: 5v
                                if all were ok, reflash bios first -> then check wherether pin 102 of KB926 had 3v3?
                                • sasser
                                  • Dec 2012
                                  • 364
                                  • Malaysia
                                  Check PU301:
                                  pin 16 : 18.5v
                                  pin 3: 2v
                                  pin 8: 3v3
                                  pin 17: 5v
                                  yes correct vvacl but no volt on pin 16.
                                  • whaldsz
                                    • Apr 2013
                                    • 395
                                    • Philippines
                                    Post the voltages of pins 5,6 and 7 of PU102B. We need to know if PACIN is high.
                                    • sasser
                                      • Dec 2012
                                      • 364
                                      • Malaysia
                                      only seen PU102 didnt find PU102B but in schematic hav PU102B is that wrong shcema? but i found PU102 below the measure result
                                      pin 1 0v
                                      pin 2 1.23v
                                      pin 3 1.34v
                                      pin 4 0v
                                      pin 5 18.74v
                                      pin 6 3.22v
                                      pin 7 1.22v
                                      pin 8 1.80v
                                      • aanan
                                        • Dec 2010
                                        • 222
                                        • India
                                        1] check pu101 pin no3, 19 v
                                        2] pu101 pin no 11, 3 v
                                        3] pu301 pin no16 ,19v
                                        4] check B++ on 19v
                                        post result.
                                          HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                          09-12-2024, 03:44 PM
                                          HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                          09-12-2024, 03:36 PM
                                          HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:30 PM
                                          HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
