HP Omen RTX2060 BSOD while nothing presure on CPU
  • alleotechno
    • Oct 2023
    • 16
    • Malaysia
    Details:
    Model : Omen HP Laptop 15-DH0038TX
    Serial Num : CND93433LW
    Product ID : 7LJ89PA#UUF
    Bios Version : AMI F.53 4/24/2024 (8600)
    Laptop Input Voltage : 19.5Vdc | 10.3a
    My Adapter Charger : Original HP 200Watt 19.5V | 10.3a
    My laptop keep on blue screen after 10 second successfully windows loaded, BSOD while installing new windows and cannot windows update, if update ask me to perform to restart and the laptop will BSOD while installing the update.
    The blue screen comes after nothing stress/pressures my CPU not GPU. I need to use the pressures/stress software (Example Heave Load on CPU presure into the CPU to prevent from the Blue Screen and all like a normal. I need to repeat this process (CPU - Heavy Load) every time I need to use my laptop if not it will freeze or BSOD
    Appreciate it if anyone can help or share with me or facing the same issue.
    Thank you.
  • pc_okay
    • May 2022
    • 241
    • FRANCE
    please send photos of your blue screens, if error codes are différent please take severals pictures.
    thanks
    • alleotechno
      • Oct 2023
      • 16
      • Malaysia
      thanks
      Hi Pc_Okay sorry for the late update, attached the error screen. I screen capture when i close my heave load to get this error code.
ID:	3566320Click image for larger version
      • pc_okay
        • May 2022
        • 241
        • FRANCE
        You can create a free bootable memtest usb stick and test your ram:
        https://www.memtest86.com/download.htm
        Try in safe mode too.
        • alleotechno
          • Oct 2023
          • 16
          • Malaysia
          I cannot do memtest any hardware or enter the safe mode also, it will BSOD.
          • BIOSSASI
            • Dec 2023
            • 26
            • SRILANKA
            Hi , Try Replace a new SSD and clean install Os.
            Post The Result. If you get New BS Error Code Attach the Image of the error.
            • alleotechno
              • Oct 2023
              • 16
              • Malaysia
              Hi BIOS,
              The laptop will BSOD and i had try all this. But i still can play and set ULTRA Graphic setting on game like OLDEN RING, DYNASTY WARRIORS, Heroes Of Newert and many more without any issue = LOL!!!.
              1. Install new fresh windows (Inside windows installation no 2 Copying around 12% = BSOD
              2. Take out the SSD and put the new RAM = BSOD after 1/2 minutes like that.
              3. Take out Wifi Card, Speaker, Unplug any USB device, Battery = BSOD after 1/2 minutes like that.
              4. Bios downgrade & upgrade from version F.16 - F.53 (Direct jumper using hardware device & software to another laptop), without wifi card, speaker, unplug any USB device, Battery = BSOD after 1/2 minutes like that.
              5. Hp Omen from bios diagnose memory test (SSD take out) same New Ram & Old Ram (DDR4 - 3200)= Display frezee after 12%
              Except
              - I am able to play around (Bios Menu) without any issue "BSOD".
              - Inside windows with HeaveLoad Presure 1 of core my CPU (Im not using all cores, it will be lagging) at the same time presure 1 by 1 of "GPU / Ram / Disk ----->>> 3 days presure test", there is nore issue or BSOD.
              I also set power management in windows power settings "Processor Power Management" to Enable and the Cpu Turbo and the CPU Base Speed from 2.59Ghz to 3.5X Ghz and i turn off the HeaveyLoad Cpu Presure and BSOD directly "WHEA_UNCORRECTABLE_ERROR.
              I am so confuse, is it my CPU low voltage or some mosfet got issue or something else?
              • BIOSSASI
                • Dec 2023
                • 26
                • SRILANKA
                Originally posted by alleotechno
                Hi BIOS,
                Except
                Its Core Loss. Cpu issue.
                • alleotechno
                  • Oct 2023
                  • 16
                  • Malaysia
                  if you say like that, i am so appreciated if you can share with me the diagram.
                  • alleotechno
                    • Oct 2023
                    • 16
                    • Malaysia
                    Topic close! i already fix with my self.
                    • pc_okay
                      • May 2022
                      • 241
                      • FRANCE
                      So what was the problème and the solution please share With us?
                      • BIOSSASI
                        • Dec 2023
                        • 26
                        • SRILANKA
                        sharing the fixing workaround is much appreciated.
                          HP OMEN OMEN 870-033ng OMEN 870 i5-6400 Specification for Upgrade or Repair
                          This specification for the HP OMEN OMEN 870-033ng can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN 870-033ng boardview and OMEN OMEN 870-033ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-12-2024, 03:44 PM
                          HP OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) OMEN i7-6700 Specification for Upgrade or Repair
                          This specification for the HP OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                          HP OMEN OMEN by Desktop PC - 870-128na OMEN 870 i7-6700 Specification for Upgrade or Repair
                          This specification for the HP OMEN OMEN by Desktop PC - 870-128na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-128na boardview and OMEN OMEN by Desktop PC - 870-128na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          HP OMEN OMEN X by 900-189na OMEN i7-7700K Specification for Upgrade or Repair
                          This specification for the HP OMEN OMEN X by 900-189na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN X by 900-189na boardview and OMEN OMEN X by 900-189na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          HP OMEN X OMEN X by Desktop PC - 900-010 OMEN X i7-6700K Specification for Upgrade or Repair
                          This specification for the HP OMEN X OMEN X by Desktop PC - 900-010 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by Desktop PC - 900-010 boardview and OMEN X OMEN X by Desktop PC - 900-010 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
