I suspect the PCH, and I don't know how to check it.
  • Arkangelus
    • Feb 2021
    • 20
    • Chile
    I am inspecting an HP device, model 0PAD DA0PADMB8G0 REV: G, with processor i5-1035G1 and I suspect the issue with the PCH because, when connecting the original charger, there is no LED indicating detection, but the PCH gets slightly warm to the touch.
    Measuring the coils near the processor, there is no short circuit. In voltage drop measurement, I get a reading of 0.107, and in ohms I get a reading of 134.2. On the 5V coils, I get OL, and the voltage drop measurement gives me 0.384. On the 3V coil, I also get OL, and the voltage drop measurement gives me 0.323.
    This is the information I have so far, as I've been unable to find schematics or a boardview for this motherboard.
    How can I confirm that the issue is indeed with the PCH? I’ve worked on devices where problems with the 3V line mean a definite PCH failure. However, this device doesn’t even have a short on the 19V line. Is there any test I can perform to determine if the PCH is faulty?
  • reformatt
    • Feb 2020
    • 1544
    PCH is not responsible for charge light, that's usually from the EC. Usual course for troubleshooting without schematic is locate the +3V converter IC and check the +3V LDO present or not.
    • Arkangelus
      • Feb 2021
      • 20
      • Chile
      Thank you very much for responding, Reformatt. Yes, the +3V LDO is present, as well as the +5V LDO. What surprises me is that the PCH is getting a bit warm. I'm not sure if that's normal.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        PCH should'nt be warm in off condition. What is the consumption on dc supply?
        Have you flashed clean me bios?
        • Arkangelus
          • Feb 2021
          • 20
          • Chile
          Thank you very much for your response. I'm unable to check the consumption because I don't have an HP connector tip for my power supply (although I do have a cable with that blue tip that could be used to connect it to my power supply).
          Regarding your question about flashing, yes, I tried to clean the ME region of the BIOS, but I encountered a serious issue since my programmer is not able to erase/write on the XMC chip's BIOS. I searched here on the forum and found a post indicating that an equivalent model could be used on the programmer, and while it does recognize it, it doesn't fully read it. When trying to load a clean BIOS, it's unable to erase or even write.
          • ianbak
            • Apr 2023
            • 62
            Do you have a thermal camera? You can usually spot a dead PCH because any heat tends to occur in a small spot, rather than uniformly
            • Arkangelus
              • Feb 2021
              • 20
              • Chile
              Hi ianbak! Thanks for asking. No, I don't have a thermal camera. I just touched the PCH area and noticed a rise in temperature. What I did do is measure the coil that goes to the PCH, and it's not shorted. And that's strange.
              • ResoluteHawk
                ASUS GA401QM Missing 5v
                by ResoluteHawk
                Hello;
                I have an ASUS G14 GA401QM that currently has no 5v rail among other things stated below in points #3 and #4. I'd like to see if it's condition can be improved.
                1) Originally this laptop had a problem with a shorted main power rail, so measuring at the current sense resistor after the DC IN FETs yielded a very low resistance. Before proceeding further I measured the CPU coils. We get 8.2 Ohms on the farthest right coil (PL8105) and 3.3 Ohms on the four to left left of it (PL8101 through PL8104). When I injected 1v into the current sense resistor, PQH9402 got warm....
                03-14-2023, 12:23 PM
              • Salvador Pérez
                Help identifying the function of these two coils - MSI Delta 15 (MS-15CK1)
                by Salvador Pérez
                Hello everyone, I'm troubleshooting an MSI Delta 15 (MS-15CK1) motherboard, and I need help identifying the function of the two coils marked in the attached image. The laptop powers on and responds to the keyboard, but the screen does not turn on-neither the LCD nor the backlight. I've checked the main power rails, and all other coils seem to have the expected voltages:
                • 0.91V for the GPU
                • 1.7V for VRAM
                • 3.3V and 5V rails 1.8V for the BIOS
                • 0.9V for the CPU and iGPU 1.2V for the RAM
                However, these two coils are not showing any voltage....
                03-10-2025, 11:50 AM
              • bpjl
                Dell E7450 LA -A961P - diagnostics after flooding and damaged PD817, PD5 diodes
                by bpjl
                I have La-A961P Rev: 1.0 (A00) from a flooded laptop on the table. The computer was flooded with tea and at the same time the power supply was disconnected, the battery was removed immediately and the laptop was turned upside down.
                I looked at the mainboard, but I don't see any marks of water damage. Maybe the liquid did not reach MB, or maybe I just don't see it.
                During the inspection, I noticed a burned (charred on one side) double diode PD817.
                Voltage drops during PD817 measurements:
                - PIN1-PIN3 forward biased = 0.137V...
                01-27-2025, 03:01 PM
              • abajor
                A2251 L8100 Diode Drop .009V Resistance 2.6Ohm
                by abajor
                Trouble shooting an A2251, it is giving me the behavior that all three USB jacks except the DFU port are reading 5.18V .24A, the DFU port draws no current.
                Tried swapping that CD3217 from a donor, that changed to DFU port same behavior the adjacent USB port is now boot cycling, other side un effected.
                Hindsight probably should have checked the diode drops first.
                I removed L8100 to confirm that the PP1v1_S3 rail was "shorted" It reads about 2.4ohm and .009V on diode drop. The HighSide Low Side FETS before L8100 appear to be fine. Proper diode...
                01-18-2025, 04:38 PM
              • battery.12v
                Asus G512LI VCCCore raise and drop
                by battery.12v
                Hello guys, Asus G512LI, came with 3.3V drop down immediately .... 5V was stable ... after search and work found that +3VSUS_MUX is the issue (caused by U4701A TUSB1146RNQR) , left off the ic .. 3.3V came up again stable ... after power on laptop turn on for 3 seconds and power off ... VCCcore raise 0.9V for 1.5 seconds and drop down all other voltages do same thing ... Ram voltage , Gpu voltages, concerning VCCGT 0V all the time
                05-03-2024, 03:43 AM
