asus vivobook x512 problem
  • nassih
    • Oct 2015
    • 279
    • morocco
    hi everyone
    I am repairing an asus viobook x512 which has a startup problem, I noticed that the laptop receives the voltage from the charger because it has 3.3v and 5v and that the CPU has a normal heat, the bios also has the necessary voltage, but I noticed when I put 19v from power supply, before pressing power button I have a consumption of 500ma,
    if anyone has a solution or a scematic I would be grateful
    tanks
  • nassih
    • Oct 2015
    • 279
    • morocco
    ps: adapter leds and power not lit
    • mon2
      • 14657
      Remove all power. No battery. Meter in resistance mode. Measure the resistance to ground of each inductor on the board. Report any low resistance measurements.
      • nassih
        • Oct 2015
        • 279
        • morocco
        all coils have no short,how can i check the SIO chip
        • pc_okay
          • May 2022
          • 243
          • FRANCE
          CPU heat before you press Power Button? Maybe you have a short somewhere or maybe laptop try to start…
          Asus laptop will autostart if you plug ac without battery.
          You need the boardview or at least a similar schématic/boardview (with same SIO model) to check SIO.
          Search with you board number.
