Lenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
  • Visual_vt
    • May 2023
    • 16
    • Croatia
    Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
    SSD and BIOS seems to be OK.
    Thank you.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Write the motherboard number here and link schematic if posted in the forum.
    • Visual_vt
      • May 2023
      • 16
      • Croatia
      MB number: NM-C821, no schematic in the forum, found something on the internet.
      Link to schematic - https://www.badcaps.net/forum/troubl...c821-schematic
      • Visual_vt
        • May 2023
        • 16
        • Croatia
        AL._.EX​ posted a shematic, can you plese check?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          I've both schematic+BDV for this mb and can share if needed.
          • Visual_vt
            • May 2023
            • 16
            • Croatia
            Please share, thank you.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Here is the link
              https://www.badcaps.net/forum/troubl...atic-boardview
              • Visual_vt
                • May 2023
                • 16
                • Croatia
                Can anyone help?
                Thank you.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Look at page7 in schematic.Its detailed there.. You need to adjust board_id 2-3-4-5
                  Mention exact markings of your onboard ram if you cant figure it out.
                  • tomodachi
                    • Apr 2012
                    • 602
                    • Turkey
                    Did you make sure the on board memory is corrutpted ? Did you run memtest ?
                    This model is known for dry solder joints under the CPU and might need a reball to fix the issue.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      tomodachi, How you de solder this type of BGA with black underfill?
                      I most often end up damaging the PCB traces in case of lenovo.
                      However, replaced SOC/PCH without any issues on other brands.
                      • tomodachi
                        • Apr 2012
                        • 602
                        • Turkey
                        @mcplslg123
                        There are two types of glue / underfill used on Lenovo boards,dark black and light black / greyish.
                        I have yet to come across anyone who can remove light black / greyish underfill without damaging the pads or chip.
                        Black glue is the one that easy to remove.
                        Under reflow process it softens and becomes flexible and soft, it takes a try or two to to realise how easy it is to remove.
                        Once you remove the chip it is very easy to clean underfill from chip and the motherboard but remember heat is the key.
                        During reflow wait till it reaches the melting point
                        To make sure all balls are melted you can use a thin chip removal blade ( ones used in gsm repairs ) to poke the balls and once you see them melt just insert blade under the bga then start turning blade from gently to hard if necessary, you will see chip will be totally come off the board.
                        I've done at least 50-70 reball on this model and none of them came back with bsod / random crash and no display problems again.
                        • Visual_vt
                          • May 2023
                          • 16
                          • Croatia
                          Yes, memtest is showing errors with onboard ram.
                          Laptop freezes, sometimes no picture with onboard ram but post every time with 4GB additional memory. But still freezes in the windows...
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Thanks @tomadachi for your valuable insights on soc reflow. I value them a lot. Hope this advise of yours will enhance my skill.
                            • tomodachi
                              • Apr 2012
                              • 602
                              • Turkey
                              I hope to see your succesfull soc reworks here, good luck !
                                Lenovo IdeaPad 3 15ADA05 Notebook 3 Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                09-07-2024, 05:00 AM
                                Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                09-07-2024, 05:20 AM
                                Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
