Looking for help with dead onboard ram
  • Kukzi
    • Dec 2024
    • 5
    • Serbia
    I have a laptop that I wish to save, so I came here looking for help.
    The onboard ram is dying but there is a slot for removeable ram which I would use if I can disable the faulty one.
    Laptop information:
    Acer Aspire A515-56
    Model Number: A515-56
    Serial Number : NXA1EEX008046015773400
    https://www.acer.com/us-en/support/p...08046015773400
    Information from the motherboard:
    Vendor: ChuanYi
    FH5AT LA-K091P
    Rev: 2.0
    2020-09-11
    Hopefully I could move a component on the motherboard to disable the ram ? (don't know enough to figure it out myself)
    Also read that an option is to modify the BIOS, but from what I understood some hardware is required for that, which I don't have.
    What are my options? Would appreciate any help,
    Thanks in advance!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    https://www.badcaps.net/forum/troubl...tic-board-view
    Schematic+Boardview.
    Page9 of the schematic has info to disable onboard ram.
    If you cant figure out on your own, mention the ram markings here for solution.
    • Kukzi
      • Dec 2024
      • 5
      • Serbia
      First of all, thank you for giving me pointers where to start.
      And I should probably say again that I really have no clue what I am doing, I am assuming most of the things.
      Sent the pictures of the chip and the area where I think the components are that need to be moved.
      I would guess these are the components that need to be moved:
      RC3997 -> RC3992
      RC3993 -> RC3990
      RC3995 -> RC3994
      RC3996 -> RC3991
      Please let me know if any of this is correct and if not what would I need to do.
      Thank you!
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        No. Totally wrong resistors you've chosen.
        RamID1 and Ramid2 will remain unchanged.
        Ramid0 and ram id3 resistor should be moved to make it logic level 1.(shift RC143 to RC142 and RC50 to RC49)
        Your onboard ram is highligted on the 7th row from top in the ram id table on pg9 of schematic.
        • Kukzi
          • Dec 2024
          • 5
          • Serbia
          On the boardview file from the link in your first reply named "Compal LA-K091P Rev 2.0 BoardView" I can't find RC50 and RC49.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Yeh just noticed the discrepancies. Dont know which one is to beleived-the schematic or boardview. The schematic shows something which bdv just doesnt shows and bdv shows something which schematic doesnt show.
            Seems like either of the two is not specific to this board.
            Going by the boardview,
            Shift the following
            01.RC3997 -> RC3992
            02.RC3996 -> RC3991
            does it helps? Please confirm
            • Kukzi
              • Dec 2024
              • 5
              • Serbia
              Yes it helps, I will attempt it when I have a bit more free time since the components are much smaller than I expected.
              There is one thing I still don't understand so if you could explain it ?
              Looking at the ram table based on the ram type I got (H5AN8G6NCJRVKC) all positions are at "0" and for no onboard memory all of them would have to be "1" ?
              Or is this not what the table represents ?
              Thanks again for all the help.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Going by the suffix "VKC" it does seems like hynix 4gb and not 8GB as i assumed.
                As long as the suffix on your onboard ram is VKC and its 4gb hynix, then proceed with what you listed at post#3.
                My apologies for not looking carefully enough for the suffix.
                • brotank
                  Lenovo C861 Ryzen 5 disable 4GB samsung onboard ram
                  by brotank
                  I quiet struggling with board lenovo c681 to disable 4gb samsung onboard ram because they're faulty, I followed the instruction on the schematic to disable them with resistor codes but still not detecting the ram on the slot.
                  can someone disable onboard ram from my dumped bios, please 🙏
                  I tried the other bios on this forum with disabled onboard ram, but no success
                  my final try is to find someone that can help disable onboard ram in my dumped bios attached in this post.
                  after that I officially give up 😂
                  thanks for awesome jobs 😊...
                  03-16-2025, 12:51 PM
                • b-slayer
                  Acer A317-53 need help to disable faulty onboard ram
                  by b-slayer
                  Hello.
                  I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
                  - first one is to modify le bios to disable the onboard ram.
                  - second one is to disable the onboard ram by desoldering some components on the mainboard.
                  so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
                  so i found that my motherboard...
                  10-12-2024, 03:46 AM
                • xloomx
                  X512DK MAIN BOARD REV. 2.1 Disable Onboard RAM
                  by xloomx
                  Asus F512D, motherboard X512DK MAIN BOARD REV. 2.1 Hynix 4GB OnBoard, (ID0=0, ID1=0, ID2=1)
                  In this case to disable onboard ram, Take out R0916 and place a 10K Resistor on R0913.
                  The configuration would be for N/A:N/A , ID0=1, ID1=0, ID2=1. (Working for me with Hynix 4gb OnBoard Memory, in this case, do not touch other resistors)
                  Images Attached...
                  01-28-2025, 10:14 AM
                • Daudi83
                  Acer Aspire A315-54 onboard ram disable
                  by Daudi83
                  hello everyone. I have an acer EH7LW LA-H792P REV: 2.0 Motherboard, and the onboard ram faulty on it. Im looking for a helping hand for disable the onboard ram. i already checked the 1.A version with the resistor shifting and the memory chips removal, but the parts seems different. Im really thankful for any help.
                  12-05-2024, 01:13 PM
                • s_specialist
                  Lenovo ThinkBook 15 G4 IAP HLXA4 LA-L931P Rev 1A onboard ram disable
                  by s_specialist
                  Lenovo ThinkBook 15 G4 IAP HLXA4 LA-L931P Rev 1A device's onboard rams are faulty how can I disable the rams, can anyone help?
                  Original bios is attached
                  Serial No : MP2EF9WE...
                  07-07-2025, 12:11 AM
