Toshiba Tecra A40-G-138 (FUZ2SY1 A4607A) not charging
  • Avinitlarge
    • Jul 2011
    • 11
    Does anyone have a schematic for a Toshiba Tecra A40-G-138 (FUZ2SY1 A4607A motherboard)?
    It's not charging through USB C, the mosfet was dead, I've replaced it but still not working. The charger is putting 20v out and the laptop is showing it's charging so it's partially working.
    The original mosfet was a AON7422G, I’ve replaced it with a AON7430 which is a similar spec
  • mon2
    • Dec 2019
    • 14220
    Link a schematic, if available but inside the dedicated schematic forum only.
    The 20v confirms the pd controller is working ok. The low current draw of 60 mA confirms there is a power path problem to the main power rail. Which battery charger IC is onboard? Share pics and full topside markings of the charger IC. The fault is between this region and the PD controller's VBUS.
    Hunt as to how far the 20v travels onto the board.
    • Avinitlarge
      • Jul 2011
      • 11
      After replacing the mosfet, it did work briefly, 20v @ 1.57a.
      I’ve traced the voltage and it goes all the way to a mosfet, it charges fine using the barrel port, this goes to the mosfet next to the one for USB C charging. It uses a isl9241 which I believe controls the PD. I’ll get some pictures later today.
      • Avinitlarge
        • Jul 2011
        • 11
        I have a feeling is may be down to the MOSFET I’ve used, I switched them around and it stopped charging from the barrel connector.
        • mon2
          • Dec 2019
          • 14220
          If you suspect the mosfet(s) -> remove all power. Meter in resistance mode.
          Measure the resistance across the mosfets:
          source / drain
          source / gate
          gate / drain
          Post each measurement. Each measurement must be hundreds of k ohms or higher if the part is ok. Otherwise, the part may be defective. Next suggestion is to flux and remove any suspect and then measure it again while the part is off the board and on your work table.
          • ghedada.06
            • Feb 2023
            • 16
            • Algeria
            toshiba tecra z50-c-138 when i plug the charger (bench power supply) the power led comes up automatically with no display without pressing power button and i see current consumption of 0.25amp to 0.30amp. all the voltages are present except cpu votage
            i tried to turn on the laptop using an ac adapter and injecting voltage on cpu coil but nothing changed
            • mon2
              • Dec 2019
              • 14220
              Be careful of voltage injection at wrong locations or with the wrong values. Injection is usually used to hunt out shorted parts.
              Remove all power. No battery. What is the resistance to ground of the vcore cpu rail?
              • ghedada.06
                • Feb 2023
                • 16
                • Algeria
                mon212ohm
                • ghedada.06
                  • Feb 2023
                  • 16
                  • Algeria
                  mon2 to give you a clear idea about this laptop. this laptop came in usb port replacement from another computer shop, i made a mistake because i replaced the usb ports from a donner board (toshiba c50) without testing the laptop first and the computer shop didn't test it also (that was dumb from us) now the laptop turns on without me pressing power button and seems like vcore is missing
                  • mon2
                    • Dec 2019
                    • 14220
                    Does this unit allow for a normal barrel type charger feed to power the board? If not, do not use an external power supply. Remain to use the usb c adapter only. The power delivery controller is working since you have 20v but the current draw is low because some power path is not fully on. Still need to hunt for the charger ic which you mentioned may be the isl9241? Study if onboard. Check voltage to ground of each inductor. Bios is powered? Maybe bios is corrupted? Backup the original and reflash this flash device. Inject only 1 volt max if you must and confirm the cpu / pch does not heat up.
                    • Avinitlarge
                      • Jul 2011
                      • 11
                      It has a barrel connector as well as the USB C, the barrel charging is fine. I’m going to look at it again after the new year. I was hoping to get it working so I don’t have to take multiple chargers with me.
                      • mon2
                        • Dec 2019
                        • 14220
                        Share quality pics of the USB C area (top and bottom side of the board). Need more details on who the PD controller is which appears to be working since 20v is being selected. Next that follow this logic will be mosfets that enable / disable before reaching the charger IC. The fault is between the PD controller output and the charger IC which selects if the USB C or the barrel connector are the power source.
                        • Avinitlarge
                          Toshiba Tecra A40-G-138 (FUZ2SY1 A4607A) schematic request
                          by Avinitlarge
                          I am after a schematic for a Toshiba Tecra A40-G-138 (FUZ2SY1 A4607A)
                          can anyone help me out please
                          thanks
                          12-16-2024, 02:55 AM
                          Toshiba Tecra Tecra X40-E-114 Netbook Specification for Upgrade or Repair
                          This specification for the Toshiba Tecra Tecra X40-E-114 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Tecra X40-E-114 boardview and Tecra X40-E-114 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                          09-06-2024, 06:42 AM
                          Toshiba Tecra Tecra M5-103 Notebook Specification for Upgrade or Repair
                          This specification for the Toshiba Tecra Tecra M5-103 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Tecra M5-103 boardview and Tecra M5-103 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-06-2024, 05:27 AM
                          Toshiba Tecra C50-EC Notebook Specification for Upgrade or Repair
                          This specification for the Toshiba Tecra C50-EC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C50-EC boardview and C50-EC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Tecra...
                          09-06-2024, 09:01 AM
