Asus X712EA 3 volts after the first mosfet
This topic has been answered.
  • AppleLover123
    Mr.Bombastic
    • Dec 2023
    • 61
    Hey guys,
    i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
    I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
    Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
    I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
    Now i thought something is cutting down the power or the resistnace is so high that only 3.15v reach the power rail.
    As a lucky gues i thought it's the first mosfet and i replaced it but still the same problem.
    So i think could it be the second mosfet?
    At the first mosfet:
    source to ground: infinite resistance,
    gate to ground: infinite resistance
    shorting source to gate: 2.6 ohms
    before the first mosfet: 19.5v
    after at source: 3.15v
    at the gate: 3.15v
    What could be the issue?
    I dont have a thermal camera so i cant spot a point what could get hot but i have a power supply!
  • Answer selected by AppleLover123 at 12-15-2024, 10:45 AM.
    mon2
    • Dec 2019
    • 14203
    Yes, the linked datasheet is correct but please note the part # is BQ24780S.
    A very popular part on logic boards. Remove the 2nd mosfet and see if the measurements for the first one improves. You can also test the removed mosfet after it is cool on your work table. Test the resistance across the pins:
    source / drain
    source / gate
    gate / drain
    Each should be hundreds of k ohms or higher.
    • mon2
      • Dec 2019
      • 14203
      Yes. Flux and remove the second mosfet (as per above sticky by piernov on charger circuits) and then test if the measurements for the first mosfet improve.
      Each resistance check should be hundreds of k ohms or higher else the part may be shorted. Which charger IC is onboard? The gate pins on these 2 x DCin mosfets are being driven by the ACDRV pin on the charger IC. Share the full topside markings of the charger IC.
      • AppleLover123
        Mr.Bombastic
        • Dec 2023
        • 61
        Okay i will try that!
        In the picture is the charger ic (at least i think it is because it's a bq). It's markings say BQ 247805 TI138 A0YQ.
        It should be this one: https://www.datasheet4u.com/datashee...php?id=1415314
        • mon2
          • Dec 2019
          • 14203
          source / drain
          source / gate
          gate / drain
          • AppleLover123
            Mr.Bombastic
            • Dec 2023
            • 61
            source / drain
            source / gate
            gate / drain
            It works now!
            The second mosfet had 56k ohms and smth.and as you sad it should be a 100k at least this doesn't looked fine to me!
            I soldered a new mosfet and boom the 19v are going past the two mosfets and the laptop came on.
            Thank you
            • mon2
              • Dec 2019
              • 14203
              Awesome! Please do review the sticky above by piernov. A very solid article that covers many topics including this case. Well done!
                MSI Infinite Infinite A 8RD-203DE Infinite i7-8700 Specification for Upgrade or Repair
                This specification for the MSI Infinite Infinite A 8RD-203DE can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite Infinite A 8RD-203DE boardview and Infinite Infinite A 8RD-203DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                09-12-2024, 03:28 PM
              • Jane
                How do you test MOSFET in laptops ?
                by Jane
                I tried to use this method:
                Testing an N-channel MOSFET:
                Step 1: Discharge the Gate (turn off the MOSFET)
                Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                Step 2: Charge the Gate (turn on the MOSFET)
                Now, place the red probe on the Gate (G) and the black probe on the
                09-27-2024, 03:31 AM
                MSI Infinite A 9SC-663EU Infinite i5-9400 Specification for Upgrade or Repair
                This specification for the MSI Infinite A 9SC-663EU can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite A 9SC-663EU boardview and Infinite A 9SC-663EU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-12-2024, 03:30 PM
                MSI Infinite X Plus 9SE-272US Infinite i7-9700K Specification for Upgrade or Repair
                This specification for the MSI Infinite X Plus 9SE-272US can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite X Plus 9SE-272US boardview and Infinite X Plus 9SE-272US schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                MSI Infinite A 9SC-662EU Infinite i5-9400 Specification for Upgrade or Repair
                This specification for the MSI Infinite A 9SC-662EU can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite A 9SC-662EU boardview and Infinite A 9SC-662EU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
