Asus X515KA not booting. after flashing bios sometimes i come there. but then dead again
  • tranquility
    • Dec 2024
    • 31
    hallo,
    i have an asus X515KA-EJ058W here.
    just both leds white...he battery blinking without battery connected
    consuming ~400mA and tries to start but nothing happens but fan spinning if cpu gets warm
    if i hold the power button it shuts down and consumes ~30mA i cant spot anything getting warm with thermal....the ec/sio a liiiitle but this is maybe normal beacause it is working ?
    power on again is possible but again 400mA then and no picture.
    now the really strange
    i flashed bios (some version i found on the internet) and resoldered....sometimes it starts then
    the first time i came to windows....restarted and dead again....i tried around maybe new flashed...then without ssd
    sometimes i get to bios....most of the time its completely dead as told above..
    what the hell is going on there ?
    if i read the bios again after it was in the board...there are changes in the bin.
    i think this is normal ? because as it tries to start it writes something to the bios which it has detected ? components or sth ?
    can the bios chip nevertheless be faulty ?
    or is it maybe the EC/SIO ? it has a rare name.... nuvoton NPCE68AAA0BX
    and it might be necessary to program it ?
    also i tried another RAM. but i am not sure if it is really compatible
    i hope you understand my bad english and maybe sbd has an idea
  • tranquility
    • Dec 2024
    • 31
    theres no obvious short when taking the 400mA. only cpu gets warm...seems to work and get warm....but no picture etc.
    • tranquility
      • Dec 2024
      • 31
      if i re-extract the bios after flashing....i cont aopen then in uefitool !
      the same with the original i extracted before i begin flashing the first time
      so something seems to corrupt that bios again and again and again....but....i had a time, i could restart and restart and came everytime to the bios....strange
      • Loli Popu
        DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
        by Loli Popu
        Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
        12-13-2024, 03:28 AM
      • Timeeez
        X270 - Bios flashing help
        by Timeeez
        I am still a beginner and want to learn more about flashing bios. First of all, thank you very much for the tutorials made on this forum it helps a lot.
        Lets get straight to the point. When I try to flash the bios of my Lenovo X270 it restarts several times and always returns to the bios that was there at the beginning. When I get the bios from someone on the forum and write it to the bios chip, I always have the same serial numbers. I have the feeling that the pc is reflashing itself. Where could this come from? How to avoid this problem?
        11-30-2022, 05:17 PM
      • zenius
        by zenius
        12-08-2024, 06:13 AM
      • Wahaz
        by Wahaz
        10-30-2023, 08:42 PM
      • Flyview
        Flashing ASUS UX51VZ with correct bios
        by Flyview
        Hi!
        Happy to be part of this forum for my first post!
        Short story:
        I believe my dad's UX51VZ has an incorrect bios (v207) for a UX51VZH flashed onto it. I'm not quite sure what the differences are between UX51VZ, UX51VZA, and UX51VZH. The serial number of this machine is D5N0CY845932229 and comes up as a "UX51VZ-DB103P" when checked on this ASUS website. All of the bioses can be found at this ASUS website.
        1) Do I have the correct bios or should it be the v205 for UX51VZ? Is there something I can check inside the machine to make sure?
        03-31-2024, 11:56 PM
