Acer Aspire 4736z no display on battery
  • abbas_govani
    • Jul 2013
    • 89
    • India
    Hi
    I had a Acer Aspire 4736z laptop working fine on dc adapter.
    but no display on battery. if batter and adapter both in it works but when disconnecting adapter power off. while only on battery it power on but no display.
    i had checked pq24 no power on source and gate while 1.5 on drain on battery.
    while no adapter gate 1.7 and drain 1.5
  • nazrul145
    • Jan 2014
    • 337
    • BD
    Re: Acer Aspire 4736z no display on battery
    Replace NEC Token with 330uf capacitor 4pcs. its solve the problem.
    • abbas_govani
      • Jul 2013
      • 89
      • India
      replaced but now the laptop starts and switch off after 2 to 3 sen
      • haw1116
        • Jul 2014
        • Sarawak
        help my 4736z bfor i change the nec tokin to 4 pcs 330uf is cannot on. after i change notebook can power on and can login to windows. but just the display got problem. all background become red color only.
        • Ramee
          • Jul 2014
          • 218
          • Israel
          Redo nec tokin.
          Make your own thead next time
          • makk2401
            • 3
            • Philippines
            hello mam/sir, I dont know how to post a new thread hope you can forgive this reply
            i have an acer 4736z with power but there is no display, Im wondering if I can replace the nectokin 0E907 with 4 pcs 330 d capacitors? how should I position the capacitor? cant find the + and - signs :x
            • Agent24
              I see dead caps
              • Oct 2007
              • 5068
              • New Zealand
              Probably you should upload a photo of the board and we can help you
              -David VanHorn
              • makk2401
                • 3
                • Philippines
                i attached it now sir. hope you can help me :x i still dont remove that capacitor from that dead mother board and i still not moving the nec
                • lezsimply
                  The Wanderer
                  • 657
                  • Philippines
                  outer lines are positive. yes 330d will do. but be careful. there are 2 points under that cap, you need to be careful not to put solder on them. It will cause some power issues.
