hp zbook g3 la-c381p no power
  • doctormasry
    • Dec 2019
    • 98
    • giza
    hello
    laptop hp zbook g3 la0c381p no power
    PR315 pin 1 and 4 there is 4 volt
    when i remove pr315 pin 1 and 2 = 19 volt
    but pin 3 and 4 still 4 volt
    pl59 = 450 om
    pl39 = 400 om
    pl40 = 420 om
    pl37 = 550 om
    no short on there coils
    i flash 2 bios ic no new
    i ve 2 laptop same problem
    please help
    and sorry for my english
  • doctormasry
    • Dec 2019
    • 98
    • giza
    BOARD VIEW https://www.badcaps.net/forum/troubl...g3-pcb-scans-b
    • doctormasry
      • Dec 2019
      • 98
      • giza
      no idea ?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Your description of problem is inadequate/incomplete and there is hardly any info provided. based on these data,no one can suggest anything.
        Describe in detail.
        • doctormasry
          • Dec 2019
          • 98
          • giza
          Describe in detail.
          hp la-c381p no power
          when i put adaptor jack the led light ok white
          when i measure on pr315 there is no 19 v just i found 4 v . its should get 19 v on pin 1-2 and get 19 v on 3-4 pin i found just 4 v
          when i remove this resistor ( pr315 ) i found on resistor pin 1-2 19 v ok but pin 3-4 found 4 volt
          i remove adaptor and measure all coils after resistor no short
          when i connected power supply no A ( 000 A )
          • mon2
            • Dec 2019
            • 14117
            Same fault here:
            https://www.badcaps.net/forum/troubl...power-no-acdrv
            What is going on? Strange...
            Which charger IC is onboard?
            • doctormasry
              • Dec 2019
              • 98
              • giza
              Originally posted by mon2
              Same fault here:
              thanks mon2
              i ll try your answer about asus and write for you
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Resistance to GND on pin3-4 of PR315?(while its removed)
                • doctormasry
                  • Dec 2019
                  • 98
                  • giza
                  when i press resistance it give me short after 10 sec give 400 om
                  • doctormasry
                    • Dec 2019
                    • 98
                    • giza
                    Same fault here:
                    i change charge ( BQ 24780s ) ic but same problem no new
                    • mon2
                      • Dec 2019
                      • 14117
                      Review the 2nd DCin mosfet. Remove all power. Meter in resistance mode.
                      Measure the resistance across this Dcin mosfet:
                      source(1-2-3) & drain (5-6-7-8)
                      source (1-2-3) & gate (4)
                      gate (4) & drain (5-6-7-8)
                      What is the resistance measurement of PR315?
                      With PR315 on the board, measure the resistance directly on pin # 1 to pin # 2 on the charger IC - measure at the contacts on the BQ24780S device.
                      Then measure the resistance to ground on pin # 2 of BQ24780S again.
                      Post each measurement.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        If the rrsistance to GND measurement is correct at 400 Ohms on pin3-4 of PR315,then your main 19V rail is shorted.
                        • doctormasry
                          • Dec 2019
                          • 98
                          • giza
                          thanks mon2 and mcplslg123
                          solved
                          problem in PD5
