Lenovo Legion NM-F771 No turn on
  • judamex
    Active Member
    • Jan 2021
    • 183
    • Mexico
    Hi, I have a legion nm-f771 that does not turn on.
    -when injecting voltage with the power supply it only consumes 0.1A, but it is very fast as if it were turning on and off very quickly
    -the 20V rail has 3.6V and goes up and down very quickly from 3.6 to 4.5
    -I changed the charging IC without success
    -I checked ACDRV, CSMSRC and the voltages are correct
    -I removed the main input mosfet and the BQ24780S behaves correctly sending the 20V correctly
    -the main input mosfet sends good measurements outside the motherboard
    I am a little lost in this, I would appreciate the support, there are no schematics or boardview available and I am relying on a very similar nm-D601 mother board​
  • mon2
    • Dec 2019
    • 14266
    Solder back all the parts. No bypass wires.
    Meter in DC voltage mode. Attach the power adapter. Carefully measure the voltage to ground of each pin on the charger ic. Post each measurement with their pin number and function in a list for a review. Need exact values.
    • judamex
      Active Member
      • Jan 2021
      • 183
      • Mexico
      The measurements are as follows
      I put pins 1 and 2 like this, because they change voltage very quickly from 3 to 4
      • mon2
        • Dec 2019
        • 14266
        Forgot to include the pin functions in the table.
        Is this list with or without the battery?
        • judamex
          Active Member
          • Jan 2021
          • 183
          • Mexico
          Corrected list, measurements are without battery connected, no peripherals and corresponds to a BQ24780S
          • mon2
            • Dec 2019
            • 14266
            Thanks. Remove all power. Meter in resistance mode.
            Measure the resistance to ground on pin 1 of the charger ic. Checking if the main power rail is shorted.
            Measure the resistance on pins 1 & 2 on the charger ic. Checking if the current sense loop of the main power rail is ok or not. Measure directly on the charger ic pins.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Remove the 2nd dc-in mosfet and apply power .Does pin4 of 1st mosfet is now 25V?
              • judamex
                Active Member
                • Jan 2021
                • 183
                • Mexico
                measurements of pin 1 and 2 of charger ic
                black terminal to ground and red to pin 1 and 2 gives 30k and going up
                red terminal to ground and black to pin 1 and 2 gives 30k and going up
                • judamex
                  Active Member
                  • Jan 2021
                  • 183
                  • Mexico
                  i remove the sence resistor and give me a 20V
ID:	3509419 Click image for larger version
                  • judamex
                    Active Member
                    • Jan 2021
                    • 183
                    • Mexico
                    bump
                    • mon2
                      • Dec 2019
                      • 14266
                      20v on pin 4 of first mosfet?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        What you have written is just half the info reqd. So if u remove CLR,20V is reaching CLR but what's the voltage on pin4 of dc-in fet?
                        Whats the resistance to GND on CLR pin 3-4(where u have zero volt)?
                        • judamex
                          Active Member
                          • Jan 2021
                          • 183
                          • Mexico
                          The first p-channel mosfet has a voltage of 8.9 and the second n-channel has 25v, both on pin 4. In the following image I explain it better
                          • judamex
                            Active Member
                            • Jan 2021
                            • 183
                            • Mexico
                            These are the measurements on the entry lineClick image for larger version
                            • mon2
                              • Dec 2019
                              • 14266
                              These look fine.
                              Now remove all power. Meter in resistance mode. Measure the resistance to ground on pin # 1 of the charger IC. Then repeat to measure pin # 2 to ground. The current sense resistor is between pins # 1 and # 2 on this charger IC. We need to know the resistance to understand why there is a large voltage drop in the power path.
                              • judamex
                                Active Member
                                • Jan 2021
                                • 183
                                • Mexico
                                These look fine.
                                The measurements look good, I took them with the resistance outside the board like the previous image.Click image for larger version
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  No power attached,resistance between pin1-2 of charging IC? Voltage on all pins of PD5401?
                                  • judamex
                                    Active Member
                                    • Jan 2021
                                    • 183
                                    • Mexico
                                    The measurement between pin 1 and 2 is 4.2Mohm, Voltage on PD5401
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      I beleive you mean 4.2 milli ohms and not mega ohms. Correct? If thats correct,then nothing wrong here.
                                      • judamex
                                        Active Member
                                        • Jan 2021
                                        • 183
                                        • Mexico
                                        Yes, they are Megaohms.
                                        I put the pr5401 resistor back and the problem returned, without it installed the entire charging system seems to work normally.
                                          LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                                          This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                          09-12-2024, 02:30 PM
                                          Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-07-2024, 05:00 AM
                                          Lenovo Legion Legion 5 17ACH6H Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion Legion 5 17ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 17ACH6H boardview and Legion 5 17ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          Lenovo Legion Legion 5 15ITH6H Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion Legion 5 15ITH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 15ITH6H boardview and Legion 5 15ITH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          LENOVO Legion T730 Legion i9-9900K Specification for Upgrade or Repair
                                          This specification for the LENOVO Legion T730 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion T730 boardview and Legion T730 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
