820-2610 No Image Troubleshoot
  • dakap10
    • May 2023
    My workhorse of a MacBook finally gave up on me. I put my MacBook to sleep and when I returned and woke it up I no longer had an image. Strange about all of this is that when I long press the power button to turn it off the screen flashes with the image before shutting down. Upon power up the screen remains blank but I can clearly see that the backlight works from the light seen around the edges of the display. I have no idea where to even begin with troubleshooting and any help would be greatly appreciated.
  • mon2
    • 14659
    'Power up' normally. Wait the usual time needed for the OS to boot to the login screen which you cannot see. Then press the caps key. Does it toggle the green light upon each keypress? If yes, then the OS is truly booting and the motherboard is alive.
    Test with an external monitor if you are indeed booting.
    Review this thread on topic:
    https://www.bleepingcomputer.com/for...10-no-display/
    • Ugur87
      MacBook Air M4 A3240 Brand New Water Damage no Image
      by Ugur87
      I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
      08-28-2025, 01:09 PM
    • baglaivlad
      MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
      by baglaivlad
      Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
      Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
      01-09-2024, 09:55 PM
    • thuygsm
      Macbook pro A2159 EMC3301 no image, no CapsLocklight, only USB activity
      by thuygsm
      Hello! Please help with a strange disease that I have never encountered before.
      At first I got the following status:
      MacBook does not turn on. Current consumption is about 0.500-0.600A at 20V from USB-C.
      - no signs of rust, or spilled water
      - CPU gets hot, fan still spins, no Capslocks light
      then I cleaned it and I got the following video:
      - Cannot install software, and after a while I get a red screen and the whole thing freezes
      Macbook Pro A2159 / Bệnh lạ
      07-28-2025, 11:35 AM
    • Madoy104
      Macbook Pro A1989 - No image, working fine with external monitor
      by Madoy104
      I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
      08-15-2024, 10:01 AM
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
