I realy NEED your help Acer Spire 3820T
  • dj_ricoh
    • 2073
    it does not power at all.
    i`m stuck on pic 1 at U27 with voltage output.
    VOUT1=0 VOUT2=0
    vout1 and vout2 needs to be outputing before after pressing the button?
    page 42 in the laptop schematic and the RT8223B
  • loser18
    • Nov 2013
    • 274
    Re: I realy NEED your help Acer Spire 3820T
    Think the fastest way to determine where the fault could be, is to post voltages of all pins...
    • dj_ricoh
      • 2073
      the rest its 0
      on page 47 its ISL88731A almost everything its ok
      and on U3 gate pin4 and q18 i injected up to 19v and nada nothing.
      was hoping to heat something
      • dj_ricoh
        • 2073
        U3 pin1,2,3 19v gate 1v and rest 19v
        • dj_ricoh
          • 2073
          on page 40 on that isl u39 i`m stuck cuz almost everything its 0
          • loser18
            • Nov 2013
            • 274
            I would check L45,L40 & all pins of U27 against ground for shorts...
            Also check voltages at SIO (u17) pin 19,46,76,88 & 115...
            • loser18
              • Nov 2013
              • 274
              Don't worry about other regulators for now...
              • dj_ricoh
                • 2073
                I would check all pins of U27 against ground for shorts...
                ok
                they all shorted to ground , even the fets around u18 and 15
                every thing that does not have a value on the first picture its 0 and shorted to ground
                dammm
                • loser18
                  • Nov 2013
                  • 274
                  You need to desolder both coils & check which pads are shorted...
                  • dj_ricoh
                    • 2073
                    you are referring to L23
                    and the other one?
                    • loser18
                      • Nov 2013
                      • 274
                      Also looks there's some residue of flux around fets and U27...Where did you get that mobo?
                      • loser18
                        • Nov 2013
                        • 274
                        Originally posted by dj_ricoh
                        you are referring to l23
                        and the other one?
                        l40 & l45
                        • dj_ricoh
                          • 2073
                          l40 & l45
                          thank you.
                          tomorrow its bank holiday only after i can desolder them.
                          is there a case for each side?
                          • loser18
                            • Nov 2013
                            • 274
                            Technically yes...
                            You may have 5V_PWR, 3D3V_PWR rail & U27 shorted or/also fets...
                            That's why I've been asking where did you get mobo...
                            Last week I bought some laptops from bankrupt IT shop ( now i know, why they bankrupted, lol) & every one has been badly reworked, many rails shorted on one he reflowed CPU socket & melted plastic(such a moron)...
                            • dj_ricoh
                              • 2073
                              the actual notebook was working and it just stop working
                              • loser18
                                • Nov 2013
                                • 274
                                Think it would be U27 or fets broken...
                                • dj_ricoh
                                  • 2073
                                  a friend of mine sold it and came back to me to help him.
                                  • dj_ricoh
                                    • 2073
                                    Ok i remove those coils !
                                    the short its gone.
                                    brb i forgot the readings.
                                    • dj_ricoh
                                      • 2073
                                      starting from pin1 ENTRIP1 to pin 24 VOUT1
                                      Ground to each pin
                                      1: 58.9 kOhm
                                      2: 16 kOhm keep rising
                                      3: 115.3 kOhm
                                      4: 0.6 Ohm and it beeps with continuity
                                      5: 4.7 kOhm
                                      6: 59.1 kOhm
                                      7: 474.5 kOhm
                                      8: 54 kOhm
                                      9: 1.84 MOhm
                                      10: 520 kOhm rising
                                      11: 520 kOhm rising
                                      12: 534 kOhm
                                      13: 111 kOhm rising
                                      14: 54 kOhm
                                      15: 0.7 Ohm PGND
                                      16: 440 kOhm going down
                                      17: 203 kOhm
                                      18: 12.25 kOhm
                                      19: 550 kOhm
                                      20: 500 kOhm rising
                                      21: 500 kOhm rising
                                      22: 2 MOhm rising
                                      23: 243 kOhm
                                      24: falling and rising fro 500 kOhm till 1 kOhm the goes back up up and down up and down.
                                      i think its charging and discharging the caps.
                                      so?
                                      should i replace it? ?
                                      • atsio
                                        • Oct 2013
                                        • 819
                                        • Greece
                                        Check if short on rail on the + side of TC22 and TC23
                                          09-06-2024, 05:27 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          Acer Swift SF314-511-511S + Pack Gold Acer 14'' Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift SF314-511-511S + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-511-511S + Pack Gold Acer 14'' boardview and SF314-511-511S + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 03:10 AM
