Lenovo l450
  • roozigar
    • May 2018
    • 6
    • erbil
    Lenovo l450
    Hi friends i have lenovo thinkpad l450 not turning on But when I remove the battery COMS, whoring after When I turn it off led blinking after not turning on ،Again, it must be remove coms battery to turning on.
  • roozigar
    • May 2018
    • 6
    • erbil
    Hi friends i have lenovo thinkpad l450 not turning on But when I remove the battery COMS, working after When I turn it off led blinking after not turning on ،Again, it must be remove coms battery to turning on. sorry my english is not good
    • mon2
      • Dec 2019
      • 14280
      Working after you remove the CMOS battery? What is the voltage of this CMOS battery?
      See attached. Locate the diode mated to the CMOS / RTC battery. Remove all power. Meter in DIODE mode. Connect the meter leads across this part. The meter should tone beep and conduct in one direction (not the boy band; be a value of 0.3 to 0.6 volts) and will block when the meter leads are reversed. Confirm that this diode is not leaking.
      Click image for larger version  Name:	bat_diode.png Views:	0 Size:	28.0 KB ID:	3498547
      • roozigar
        • May 2018
        • 6
        • erbil
        I removed all the power, first diode 0.3v. Second diod 0.2, resistor is ok, but with battery computer It gives 3.3 volts but when I put the battery coms/rtc it gives 2.8 volts
          Lenovo ThinkPad L450 Notebook L Specification for Upgrade or Repair
          This specification for the Lenovo ThinkPad L450 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L450 boardview and L450 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
          09-06-2024, 05:30 AM
        • Popel1083
          Lenovo IdeaPad U330p Read Bios than Bios Password Remove
          by Popel1083
          I want to remove the Bios Password of my Lenovo IdeaPad U330p with the Lenovo autopatcher. I have the CH341A Black and I'm using NeoProgrammer. The Programmer has an LED that indecates when it reads or writes the Chip. When I try to Connect my Programmer to the Bios Chip (Winbond 25Q64FVSIQ) the LED lights up even though I didn't click on Detect botton in NeoProgrammer. If i click on Detect the LED still remains on and NeoProgrammer says "IC not responding".
          SN: QB08570065
          MB: DA0LZ5MB8D0; REV: D; MODEL J31/N02
          08-06-2024, 05:52 PM
        • xsd611
          Lenovo X270 Bios - remove Whitelist
          by xsd611
          ​Hello, this is a BIOS file for the Lenovo X270 laptop, read out through a CH341 programmer. I located error 1802 in the PE32 module. This is a detection for the network card's whitelist. How can I bypass or remove the whitelist check? My skills are limited, and I have tried many times but ended up with a black screen. How can I normally bypass this whitelist check? Please help me edit this BIOS file, thank you. It would be great if you could provide illustrations to guide me. Thank you very much!...
          07-13-2025, 09:13 PM
        • anton brunner
          Lenovo Ideapad Duet 3 (11IAN8) - Remove Password
          by anton brunner
          Hello Everyone,
          after some struggle I managed to sucessfully dump the Bios of an Lenovo Ideapad Duet 3 (11IAN8). Can someone help me remove the Bios Password?
          MO: YM90B49150N2
          MTM: 82XKS00500
          S/N: YM10CPP2
          Thanks in Advance, the Bios dump is attached....
          05-23-2025, 04:56 AM
