Lenovo Yoga 3 PRO 1370 no power
  • vpower
    • Sep 2022
    • 111
    • italy
    Hi, I have this dead laptop, no power and no charging light.
    Power voltage seems ok, I have 19v on CLR. I tested a few coils, and I found a short near battery connector, on PL5.
    I injected 1v and I noticed a component named U40 getting hot. This is what I get with multimeter on that part with diode mode:
    pin 1 VUSB shorted
    pin 2 N25415288 shorted
    pin 6 +5VDX_WALKPORT shorted
    I attached photos of shorted (?) coil and component getting hot
    any hint? thanks in advance
  • mon2
    • 14117
    Post a clear pic of u40. Need at least the full topside markings of this device.
    Remove all power. Meter in resistance mode. Measure the resistance to ground of the inductor marked 2R2 that is heating up. Post the measurement in ohms.
    • vpower
      • Sep 2022
      • 111
      • italy
      U40 in attached photo.
      cannot find 2R2. U40 is heating up
      • mon2
        • 14117
        It may be AP2553FDC-7
        https://www.s-manuals.com/pdf/datash...0-2_diodes.pdf
        • vpower
          • Sep 2022
          • 111
          • italy
          do you think I need to replace it?
          • vpower
            • Sep 2022
            • 111
            • italy
            Originally posted by mon2
            looking at schematics, component name is TPS2553DRV_SON6_2X2
            • mon2
              • 14117
              Same product, different vendor.
              https://www.ti.com/product/TPS2553/p...E&gclsrc=aw.ds
              With no power, meter in resistance mode, test the resistance to ground of the Vout pins. What is the resistance in ohms?
              • vpower
                • Sep 2022
                • 111
                • italy
                pin 1 4.6 ohm
                pin 2 5.2 ohm
                pin 3 open
                pin 4 open
                pin 5 2.5 ohm
                pin 6 4.6 ohm
                • mon2
                  • 14117
                  Definitely very low resistance to ground.
                  Flux and carefully remove this part. Then test the resistance to ground again of the pcb pads without this part.
                  • vpower
                    • Sep 2022
                    • 111
                    • italy
                    I removed the part. now all pins are open except for pin5 which is ground. I was thinking about making a bridge on pin 1 and 6 .. what do you think? I read about it here:
                    https://www.badcaps.net/forum/troubl...fied-component
                    • vpower
                      • Sep 2022
                      • 111
                      • italy
                      update: after removing the U40 part,no more low resistance on PL5. So I ordered and replaced it, the laptop is still dead but I can see that PU3 (ISL95905) is getting hot.
                      do you think I should replace it? it's a BGA part and not so cheap, so I'm not sure about the job
                        Lenovo Yoga YOGA Book Hybrid (2-in-1) Book Specification for Upgrade or Repair
                        This specification for the Lenovo Yoga YOGA Book Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the YOGA Book boardview and YOGA Book schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                        09-06-2024, 08:10 AM
