ASUS ROG GL502VS does not POST or fan spin
  • waakye
    • Dec 2018
    • 340
    • Electronada
    Good day everyone,
    I have with me an ASUS Rog GL502vs that exhibit the following symptoms:
    When the power button is pressed, the caplock and power button LED turn on. The laptop does not post. The fans does not spin. The GPU and CPU become warm. I have flash the bios and same symptoms persist.
    please, can someone help me fix this laptop.
    Thanks in advance. I have attached some pictures
  • C0dR
    • Sep 2023
    • 15
    Can you check the CPU and RAM Voltages when its turned on?
    • waakye
      • Dec 2018
      • 340
      • Electronada
      Hi C0dR,
      Thanks for replying. I do not have a board view nor schematic for this board but I will greatly appreciate if you can tell me where to take the measurements.
      • rtstorm
        • Feb 2012
        • 971
        • Croatia
        If you have a lupe or microscope do a detailed visual inspection of the board, search for burned components, maybe some physical damage or water damage.
        ...the quieter you become the more you are able to hear...
        • waakye
          • Dec 2018
          • 340
          • Electronada
          Thanks rtstorm for replying. I scan the board and there seem to be no water damage. One thing I noticed is that whe I disconnected the fan and plug it half way and turn on the laptop, the fan spin fast but no POST, no image. The power Led and the Caplock are on. All the voltages on all inductors are present.
          • waakye
            • Dec 2018
            • 340
            • Electronada
            I also flash several bios bin and same result.
            • waakye
              • Dec 2018
              • 340
              • Electronada
              Does this board need the 2133mhz Ram frequency in order to function?
              • waakye
                • Dec 2018
                • 340
                • Electronada
                Can someone please help fix this laptop. Is it beyond repair?
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  https://www.badcaps.net/forum/troubl...-and-boardview
                  schematic and boardview already posted in the forum.
                  • myth77
                    • Feb 2017
                    • 380
                    • Croatia
                    maybe i am not seeing good but on the first picture that gpu ram seems blown? also right of that ram i can see mosfet also burned? But maybe its just bad picture...but it is cleary someone worked on that area because there is discoloration and you can see cooper in that area.
                    • waakye
                      • Dec 2018
                      • 340
                      • Electronada
                      Thanks mcplslg123.
                      myth77, the picture is the light from my microscope.
                      I will look again if there are any burns.
                      It just strange because the laptop fan spins and the CPU and GPU is warm when you press the power button but no post no image
                        • 22012
                        Is that liquid damage or has it been reworked in that area
                        • waakye
                          • Dec 2018
                          • 340
                          • Electronada
                          Thanks SMDFlea!
                          It seemed to flux. Most likely it was reworked. I will review that area again.
                          • waakye
                            • Dec 2018
                            • 340
                            • Electronada
                            Does anyone has a repair manual on how to repair this mono. It seems that all voltages at the inductors are all present.
                            • waakye
                              • Dec 2018
                              • 340
                              • Electronada
                              I measure the resistance on all inductors and there is no short. One thing I noticed is when I try to disconnect the fan connector, the fan fast spins. Any help guys?
                              • waakye
                                • Dec 2018
                                • 340
                                • Electronada
                                The Power supply shows 19.5V and 0.64Amps but no activity at laptop.
                                Can someone please help me out?
                                • waakye
                                  • Dec 2018
                                  • 340
                                  • Electronada
                                  Any help guys? 🙏 🙏
                                  • waakye
                                    • Dec 2018
                                    • 340
                                    • Electronada
                                    All voltages are present except the CPU. GPU voltage is 0.8VDC. The CPU inductors measures 2.1 Ohms and the GPU inductors measures 0.4 Ohms. Any help will be appreciated.
                                    • waakye
                                      • Dec 2018
                                      • 340
                                      • Electronada
                                      I removed and measured the source to drain of all mosfets circled in the red and they all measure 0.125VDS in diode mode. I guess it means game over?
                                      Click image for larger version  Name:	image.png Views:	0 Size:	198.0 KB ID:	3505116
                                        ASUS ROG GL502VS-FY352T Notebook Strix Specification for Upgrade or Repair
                                        This specification for the ASUS ROG GL502VS-FY352T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL502VS-FY352T boardview and GL502VS-FY352T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-06-2024, 08:00 AM
                                        ASUS ROG GL502VS-GZ226T Notebook Strix Specification for Upgrade or Repair
                                        This specification for the ASUS ROG GL502VS-GZ226T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL502VS-GZ226T boardview and GL502VS-GZ226T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-06-2024, 07:42 AM
                                        ASUS ROG GL502VS-FI144T Notebook Strix Specification for Upgrade or Repair
                                        This specification for the ASUS ROG GL502VS-FI144T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL502VS-FI144T boardview and GL502VS-FI144T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-06-2024, 06:31 AM
                                        ASUS ROG GL502VS-FY370T Notebook Strix Specification for Upgrade or Repair
                                        This specification for the ASUS ROG GL502VS-FY370T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL502VS-FY370T boardview and GL502VS-FY370T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-06-2024, 06:14 AM
                                        09-06-2024, 06:11 AM
