hp 830 850 g3 6050A2892401
  • jesi
    • Jul 2013
    • 78
    • uk
    3 motherboards have exactly the same issue , video attached , probe on pin 2 of main bios , when plugged in charger this is what i get on the scope ,also 3v 5v all there, 1v 1.2v 1.8v all ok n cpu fan comes one after 3 - 4 mins but display blank , i have 3 motherboards with the same fault..
    my next step is to either reflow cpu , or replace cpu
    anyone else with this king of issues on hp motherboard
    thanks in advance
  • madscientist750
    Replacing electrolytic caps by solid caps on old motherboards
    by madscientist750
    I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
    I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
    I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
    10-19-2025, 06:10 AM
  • jesi
    6050A2892401 hp 840 g3 schematic
    by jesi
    hi there everyone
    looking for schematic for hp 840 g3 6050a2892401 mb a01
    found several but non of them match all have the mec ic not the novoton
    thanks in advance
    05-01-2025, 07:51 AM
  • qwerty99
    Xbox 1.6 Motherboards and Polymer Capacitors
    by qwerty99
    Hello!
    I need to change the capacitors on my three original Xboxes.
    Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
    The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
    The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
    I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
    06-26-2022, 12:53 AM
  • Foetuss
    Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
    by Foetuss
    Hi all
    Hope this is in the correct place.
    I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
    Could use some double checking to see if I'm not doing something stupid .
    Pictures of the boards are attached.
    What I will be replacing with what : (planned)
    Soltek Golden ::
    4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
    6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
    01-18-2025, 11:44 AM
  • Technoking69
    HP Compaq Pro 6305 - KING COBRAS REV B motherboard schematics
    by Technoking69
    Hi everyone. I have a HP Compaq Pro 6305 - KING COBRAS REV Bmotherboard that I want to repair. Does anyone have the schematics?
    09-24-2024, 11:31 AM
