Macbook Pro Mid 2012 bad fuse?-Charity $$$ reward
  • akotalik
    • Mar 2014
    • 26
    Hello, thanks for reading this!
    I have a macbook pro mid 2012 13 inch that is completely dead, magsafe charger plugged in- sometimes green light, sometimes nothing. I purchased this computer already broken, the person said (they often lie, but I believe him) that he tried to upgrade the HDD himself and when he put it together, the computer was dead.
    The board is very clean, no water damage (I have worked on hundreds of water damaged boards, so I believe I am quite good at spotting the tiniest corrosion) This leads me to believe that he shorted something when working on it, prob with his screwdriver.
    The battery is completely shot, I put it in a working pro and it does not charge, it only has 0.15V on it, which again leads me to believe that it was shorted. I even took this board and put it in my working late 2011, no life, and vice versa (put the working 2011 board in this computer, everything was working but it was slow as hell- I believe this is because the temp sensors are not cross-compatible)
    What I know:
    The board has 2 fuses on it, one of which is on the magsafe port (I changed the whole magsafe port, so that is not it). But I found some conflicting information as to where the main fuse is. Most of the threads are on older macbooks, so they may not necessarily apply.
    The battery is good (i put in a new, working battery)
    My charger is good
    The magsafe DC board is good
    What I do not know:
    how to read the schematics (sorry)
    how to diagnose the board properly
    what to do next?
    I tried to check some parts that I suspect are the fuse with my multimeter continuity function, I attached a picture with a board and what I measured. These are based on previous threads about older macbooks.
    On pics:
    no 1: OK (multimeter goes to 0)
    2:OK
    3:No reaction (Multimeter stays at 1)
    4: OK
    5: OK
    These are based on some info from the net, some say the fuse is (was) near the display cable, some say it is down near the battery plug, or on the other side next to where magsafe DC plugs in.
    To make this slightly more interesting and maybe to motivate people to help even a noob like myself, I decided to add a little twist: If you help me and we do get the board working, I will donate $100 to a charity or nonprofit of your choosing.
    I was going to take the computer to an Apple store for diagnostics, but I would prefer to fix it myself. (out of warranty)
  • dellxps15
    • Feb 2014
    • 1594
    • italy
    Re: Macbook Pro Mid 2012 bad fuse?-Charity $$$ reward
    main fuse for ac dc is N°4 on your picture. number 1 is for battery. 2-3 are not fuse.
    plug-in magsafe without battery and see if at fuse 4 u have 16-18.5 volt both side. if yes then check isl6259 U7000 pin N°3 if 16-18v are present.
    • akotalik
      • Mar 2014
      • 26
      Hi, thanks for your reply, I really appreciate it! I will measure the fuse when I get home, but just to speed things up, I have no idea what is isl6259 U7000 pin N°3 or how to find it, it's probably a retarded question, sorry. Can you explain in a simpleton-friendly way how to measure it? I mean even if I find the pin, what do I measure the voltage against (eg where to place the other probe)
      • dellxps15
        • Feb 2014
        • 1594
        • italy
        isl 6259 is a qfn chip ( small) on the board. put multimeter in dcv 20 volt. negative to a metal place like usb port or so, and the positive to pin 3 (starting from the little dot on the isl6259 chip. be Carefull to not touch other pins while measure the pin N°3 or u can burn something else. this chip on macbook are really small and is easy to make contact beween 2 or more pins together : example u touch pin 3 and 4 together and u will burn something.
        to locate chip and work a microscope or scope is better. i use a very cheap 20x magnifier, but do its work for now waithing to get a proper scope for that.
        edit: probable u7000 chip is up number 2 of your picture or nearby there.
        • akotalik
          • Mar 2014
          • 26
          Great info, nicely written too! I am at school right now, I will be home in a few hours, so I will let you know what I found, is the isl 6259 chip marked? Eg does it have this name printed on it? Apple likes to leave things without labels and to make their products repair- unfriendly.
          I only have a regular multimeter with normal probes, hopefully they are small enough. Just to double check, you want me to perform the tests with just the stripped board and charger plugged into it, nothing else plugged in right?
          • dellxps15
            • Feb 2014
            • 1594
            • italy
            exactly only board and magsafe+ dcin adapter. put all on a safe place (not on the macbook alluminium conductive case).
            yes chip name is written on them.
            yes is a bad that apple (also samsung on ultrabook as far as i know) doesnt put component part near them....so to see one component what is u have to trace back from some big component near it
            repair macbook think is the hardest thing to do, 1° because it's not properly a normal notebook (has smc chip not bios), second all component are very small and not named. plus board absorbe heat very well.........
            ive burned some chip before getting into them properly
            • akotalik
              • Mar 2014
              • 26
              Hi, so i plugged in a good charger and measured the voltage, there is 0 voltage on the white fuse. When I measure voltage on where the dcin adapter plugs into the board, there is voltage. Does this mean that the main fuse is blown?
              Also, when I put the probes on both sides of the fuse, the light on my multimeter comes on which I believe means that one of the probes is connected to a live wire, right? Thanks for your help
              • dellxps15
                • Feb 2014
                • 1594
                • italy
                if on fuse 4, you have voltage to one side and 0 to the other , fuse is bad, but before change it check with multimeter if there is a short. multimeter in diode mode; black to one metal place like external usb... the red to one side of the fuse at time. 000, 001, 002...008 means there is a short and replace the fuse will blow it again.
                if you have 0 volt both side of that fuse 4, we have to investigate more.
                hope that help.
                • akotalik
                  • Mar 2014
                  • 26
                  Hi, yeah I know that, I checked the fuse both ways just to be sure, there is no voltage either way.
                  When i use the multimeter in continuity, diode mode, i put the black probe to the metal casing of usb connector and red to either side of the fuse, the value stays at 1 both times. So i guess that means there is no short?
                  • akotalik
                    • Mar 2014
                    • 26
                    Btw just a theoretical question- how come that when i use the multimeter in diode mode and test the fuse (probe on each side), it tests positive on continuity? I would think that if it tests continuous that means the fuse is good (prob also a stupid question)
                    Edit: nevermind, i was just confused I guess, since there is no voltage either way, that means the problem is NOT the fuse. Got it. So do you have any other ideas?
                    • dellxps15
                      • Feb 2014
                      • 1594
                      • italy
                      near that fuse "4" there is a brown component C6905 0603 capacitors. check if it is short on both side
                      exactly no volt there should be that capacitors.
                      but no short on fuse... is strange... bad ac adapter connector ?
                      https://www.youtube.com/watch?v=fb3e...2CACC1&index=9
                      • akotalik
                        • Mar 2014
                        • 26
                        Ok thanks, so I assume again the same test- black probe on metal housing, red probe on each side of the component? I cannot really find that capacitator, do you know where it is, does it have that full name on it? Seems awfully long on such tiny components. Idk if you can point it out in a pic....
                        • akotalik
                          • Mar 2014
                          • 26
                          Well the magsafe dcin is good i believe, i bought a new one and when i plug in charger and measure voltage on the metal pins where it plugs into the motherboard (on the part where it is soldered to the board) it gives me 16 volts
                          • dellxps15
                            • Feb 2014
                            • 1594
                            • italy
                            marked one is 0603 C6905, check if short on both side (without power)
                            with power, check voltage on that lines.
                            edit: from your last picture... are all inside pin of dc plug on mainboard ok and straight?
                            • akotalik
                              • Mar 2014
                              • 26
                              Thanks a lot! When I put black probe to metal housing of usb and red probe to the capacitator, it says there is short on one side (the side closer to the white fuse). When i plug in power, there is 17 volts between the ends of the capacitator.
                              • dellxps15
                                • Feb 2014
                                • 1594
                                • italy
                                c6905 shorted to only one side and volt to another is ok. now voltage goes from that 0603 to fuse 4 of your picture. remove fuse and see if track is damaged and also if voltage is present on fuse pin.
                                edit: if u can make a better and focused macro picture of white fuse 4 would be great
                                before remove fuse make a macro. you sure no voltage on fuse?
                                • akotalik
                                  • Mar 2014
                                  • 26
                                  Attached are some macro photos of the fuse area. Let me make the measurement on the fuse again, but I am pretty sure there is 0 voltage between the ends of the fuse.
                                  • akotalik
                                    • Mar 2014
                                    • 26
                                    I am 100% sure no voltage between fuse ends. When i measure voltage between (either) fuse end and the capacitor end that is closer to the fuse, I get 16V. If I measure voltage between fuse end and the farther end of the capacitator, I get 0
                                    • dellxps15
                                      • Feb 2014
                                      • 1594
                                      • italy
                                      voltage on numbers:
                                      1:
                                      2:
                                      3:
                                      4:
                                      what is that burn on dc jack socket? check if inside pins are ok.
                                      • akotalik
                                        • Mar 2014
                                        • 26
                                        Burn- don't know, I was wondering myself. I did not touch this board with a solder. But it may be that someone else did of course.
                                        Voltage
                                        between 1 and 2: 17 volts
                                        between 1 and 3: 0
                                        1 and 4: 0
                                        2 and 3:17 volts
                                        2 and 4: 17 volts
                                        3 and 4: 0 volts
                                        DC socket pins are good- I would assume that since there is 17 volts on the capacitator, that shows that the dc in board is good right? I mean it supplies the right voltage into the board. Idk if there is another way to check that they are all good, since if you flip the board, the connections are not visible.
                                        • Rezendes
                                          Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                                          by Rezendes
                                          Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                                          I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                                          The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                                          05-10-2024, 02:18 PM
                                        • korben_dallas
                                          Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                                          by korben_dallas
                                          Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                                          I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                                          I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                                          MY QUESTION:
                                          I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                                          02-14-2024, 12:23 AM
                                        • bastien
                                          OBDATA Raccoon Computer V1 for Macbook Pro Air 2012-2025
                                          by bastien
                                          It's the end of three years of work, it costs money, it costs time, and you owe me a beer.
                                          This is the new database for FlexBV
                                          it's optimized to work with it
                                          by using board ID has Default name, give us the opportunity,
                                          to use other diode board data with sibling board or family board
                                          I Merged the whole data (optimal)
                                          A2991 A2992 M3 -> -> 2 Entries diode data M1
                                          A2681 A3113 A3114 M1 M2 Air -> -> 2 Entries diode data M1 M2 13"
                                          A2442 A2485 A2779...
                                          03-18-2025, 08:03 AM
                                        • envym
                                          MacBook Pro 2018 with Activation Lock
                                          by envym
                                          Hi everyone!
                                          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                          06-27-2025, 08:54 AM
                                          MagSafe Audio Board MacBook Pro 15" A1226 Left I/O 820-2102 Boardview
                                          MagSafe Audio Board MacBook Pro 15" A1226 Left I/O 820-2102 Boardview...
                                          10-28-2024, 03:29 AM
