Dynabook Satellite Pro L50-G-1C2 - No boot / no charge
  • nosfay
    • May 2024
    • 64
    • France
    I've got a Dynabook Satellite Pro L50-G-1C2 that doesn't charge or power on.
    Checked AC adapter first, it's good.
    I've found some corrosion near a mosfet, and it's shorted from source to drain, identical mosfet close is shorted the same way.
    I cannot find the datasheet or spare, reference is 6794 - GPOH11.
    I need help to find what it is please
  • mon2
    • Dec 2019
    • 14753
    The insignia appears to be Alpha Omega from a distance.
    AON6794.pdf (aosmd.com)
    Jellybean mosfet. N-channel type. Can be replaced with many others from other donor boards that will have the BQ charger IC onboard so they too will be driving N-channel mosfets like this one.
    • nosfay
      • May 2024
      • 64
      • France
      You're right, thank you !
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Are you sure the mosfets are shorted? They are likely to show very lows impedance in circuit as part og cpu/gpu rails. better to de solder the mosfets and then test them out of circuit. Verly likely not shorted.
        • nosfay
          • May 2024
          • 64
          • France
          Indeed, both are good out of board. I've found one component close to them that heat a lot when AC charger is plugged.
ID:	3344686Click image for larger version
          I can't read the reference, it's something like APBM 861.
          • mon2
            • Dec 2019
            • 14753
            MPS # NB680AGD
            (from the above sticky thread on IC part markings = APB*)
            monolithicpower.com/en/documentview/productdocument/index/version/2/document_type/Datasheet/lang/en/sku/NB680/document_id/4031/
            (5piece)100% New NB680AGD-Z NB680AGD NB680A (APBF APBE APBG APB*) QFN-12 NB680 NB680GD NB680GD-Z ALV.. - AliExpress 502
            Parts Markings thread:
            IC Marking Codes and Datasheets - Badcaps
            • nosfay
              • May 2024
              • 64
              • France
              Thank you
              • nosfay
                • May 2024
                • 64
                • France
                I've replace the part, and it's still heat a lot. Do you know what can I check next? I dont have schematic.
                I've found 19v and 5v on the board.
                Replaced part is a 3.3v buck converter.
                • mon2
                  • Dec 2019
                  • 14753
                  Remove all power. Meter in resistance mode.
                  Measure the resistance from the output of this switching regulator (see the red arrow) to ground (see other red arrow). What is the resistance in ohms?
                  • nosfay
                    • May 2024
                    • 64
                    • France
                    This is what I got:
                    • nosfay
                      • May 2024
                      • 64
                      • France
                      Are these measurement OK ?
                      • nosfay
                        • May 2024
                        • 64
                        • France
                        I've found a similar issue here :https://www.badcaps.net/forum/troubl...-gets-very-hot
                        They talk about a possible short on RTC circuit, but I don't know how to check it and what it does, if someone may help me
                        • nosfay
                          • May 2024
                          • 64
                          • France
                          Iv'e done some voltage measurement, here is what I've got:
                          Vin = 19v
                          Vout = 0v
                          LDO = 0.9v
                          EN = 0.8v
                          VCC = 3.66v
                          BST = 3.5v
                          SW = 0v
                          I've joined aswell motherboard photo.
                          • mon2
                            • Dec 2019
                            • 14753
                            The EN voltage is too low to enable the switching regulator inside this device. The signal needs to be a logic ‘1’ = ~ 3 volts to enable.
                            • nosfay
                              • May 2024
                              • 64
                              • France
                              If it's too low, it can heat the buck converter?
                              • mon2
                                • Dec 2019
                                • 14753
                                With such a low enable voltage, the switching regulator will not enable. The resistance to ground at the output is not low enough to cause the immense heating of this regulator.
                                The other regulator is the LDO rail which appears to be a fixed ON low current regulator. Such regulators literally burn the high input voltage of 19v down to the target LDO voltage so it will heat up the part in the process. The output of the LDO rail does not appear to be shorted either yet the output LDO voltage is very low. The other thread mentions a short in the RTC (real time clock) but the resistance to ground of this LDO does not show a short condition.
                                The posted pic looks clean with respect to soldering. Do confirm again the resistance to ground of the LDO and the SW rails - with no power to the board.
                                • nosfay
                                  • May 2024
                                  • 64
                                  • France
                                  Resistance are the same.
                                  I've removed the buck converter et do voltage measurements:
                                  - EN = 0.15v
                                  - LDO = 0.18v
                                  - Vout = 0.15v
                                  Then I've injected 1.5v / 0.5A to LDO, and saw a hot component near the battery connector.
                                  It's a Schotkky diode, model BAT54C, I'll try to replace it.
                                  • nosfay
                                    • May 2024
                                    • 64
                                    • France
                                    I've replaced the diode, but the converter is still heating a lot (130° with thermal camera).
                                    But now I've found 5.1v, 3.4v and 1.05v on some board test point, then I lost 3.4v and 1.05v because I guess the buck converter goes in thermal protection (140°c in datasheet)
                                    Tension :
                                    Vin = 19v
                                    Vout = 3.4v before thermal shutdown, 0v after
                                    LDO = 2.1v
                                    EN = 1.95v
                                    VCC = 3.66v
                                    BST = 3.5v
                                    SW = 0v
                                    Resistance (no power) :
                                    Vin = 75kΩ​
                                    Vout = 27kΩ​
                                    LDO = 1.7kΩ​
                                    EN = 475kΩ​
                                    VCC = 0.85MΩ​
                                    BST = OL
                                    SW = 27kΩ​
                                    1.05v test point : 45Ω​
                                    • nosfay
                                      • May 2024
                                      • 64
                                      • France
                                      Any idea on what I can try next ?
                                      • mon2
                                        • Dec 2019
                                        • 14753
                                        Which diode was used for the replacement? Was it with the same suffix? It is important.
                                          Dynabook Satellite Pro Satellite Pro A50-E-209 Notebook Specification for Upgrade or Repair
                                          This specification for the Dynabook Satellite Pro Satellite Pro A50-E-209 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A50-E-209 boardview and Satellite Pro A50-E-209 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 12:08 PM
                                          Dynabook Satellite Pro Satellite Pro C40-G-13E Notebook Specification for Upgrade or Repair
                                          This specification for the Dynabook Satellite Pro Satellite Pro C40-G-13E Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro C40-G-13E boardview and Satellite Pro C40-G-13E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-07-2024, 05:50 AM
                                          Dynabook Satellite Pro Satellite Pro C50D-B-113 Notebook Specification for Upgrade or Repair
                                          This specification for the Dynabook Satellite Pro Satellite Pro C50D-B-113 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro C50D-B-113 boardview and Satellite Pro C50D-B-113 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 04:30 AM
                                          Dynabook Satellite Pro Satellite Pro C50-J-10L Notebook Specification for Upgrade or Repair
                                          This specification for the Dynabook Satellite Pro Satellite Pro C50-J-10L Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro C50-J-10L boardview and Satellite Pro C50-J-10L schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          Dynabook Satellite Pro Satellite Pro C50-J-11A Notebook Specification for Upgrade or Repair
                                          This specification for the Dynabook Satellite Pro Satellite Pro C50-J-11A Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro C50-J-11A boardview and Satellite Pro C50-J-11A schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
