Lenovo V310-15ISK - It doesn't work after changing the battery
  • piernov
    • Jan 2016
    • 4435
    • France
    Neither TL866 II nor T56 are designed to program ECs. While they can do some of them, I wouldn't recommend buying one of these specifically to program ECs. (but I would recommend them for most other kind of EEPROM/Flash devices)
    SVOD4 is designed to program EC and probably has the largest list of supported ECs but it is expensive.
    • pabloroggeri
      Electronic
      • Apr 2015
      • 90
      • Argentina
      Originally posted by mon2
      The linked adapter does not appear to be available at that site. Contact the mfr to confirm. They may have a zif version by now. Also, from where will you get the EC dump? There is one on this website which may work for you.
      I downloaded the EC bios file and the main bios from a telegam channel
      • pabloroggeri
        Electronic
        • Apr 2015
        • 90
        • Argentina
        Thanks for the collaboration
        • pabloroggeri
          Electronic
          • Apr 2015
          • 90
          • Argentina
          I don't agree. I personally have the TL-866II Plus and have successfully programmed several ECs, for example the KB9012. The problem is that the TL866II does not record ECs from the ITE family, but many other ECs from different manufacturers​
          • piernov
            • Jan 2016
            • 4435
            • France
            I did say they can do *some* of them. ENE KB90xx are easier because they have an SPI interface for programming. Other ECs use different interfaces.
            • ndarjo21
              • Nov 2021
              • 77
              • Indonesia
              #26
              hi piernov. the ITE 8xxx series can be programmed using i2c/smbus interface isn't it, i read in the zephyr wiki, + svod4 can use that too, i also read in i2ite github project (using FT232H) can read/write ITE chip. the writer also write a program to flash the ENE ec using FTDI device. they all use i2c interfaces right? so, because ch341a can using i2c interface, it is possible to flash ITE ec using it if someone write correct program? you can poke dexas or LED to communicate with me. hehe
              • ndarjo21
                • Nov 2021
                • 77
                • Indonesia
                #27
                after talking with imsprog maintainer, it seems the ch341a unable to send the initial waveform to make the EC get into debug/DFU mode because the in gpio mode, it will be very slow in ch341a sda and scl
                • ferah831208
                  by ferah831208
                  03-18-2025, 01:18 AM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • code share
                  Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                  by code share
                  I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                  Here's what I've tried so far:
                  • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                  • Booted successfully on AC power only with the battery disconnected
                  • Visual inspection of the battery — no swelling, burn marks, or connector damage
                  • Battery
                  04-21-2025, 12:50 PM
                • mrkmpn
                  Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
                  by mrkmpn
                  Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
                  This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
                  03-13-2024, 01:54 PM
                • dhs6512
                  Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 not work with the battery
                  by dhs6512
                  Hello. Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 board
                  Initially dead. Inspection: the board was not touched, on EC IT8227E-192 2101-CXA there is a mini-burnout.
                  Replaced with the same one, flashed the EC with the official firmware (had to solder to the pins), left the main firmware (Gigadevice 25LB128DSIG) original.
                  When connecting the charger, the device started, gave picture and works, checked all the functions - ok.
                  Connected the original battery. Only on the battery the device starts for a second, lights up the keyboard backlight and turns off.
                  When connecting...
                  10-29-2024, 11:04 AM
