Strange behavior of charging ic ISL88738H
  • linhtinh
    • Sep 2020
    • 33
    • thailand
    Dell LA-H331P board.
    Schematic here
    Boardview exactly same la-f541p here
    First is the ISL88738H charging ic died, i replaced it but the PQ1900+PQ1902 mosfets kept dying, all mosfets are taken from the donor board.
    Strange behavior is the machine still turns on without battery, i can still enter into bios, but when I pluggin the battery it doesn't charge.
    I measured all the capacitors and resistors around the charging ic, all are normal. Does anyone know why the PQ1900/1902 mosfets keep dying (shorted D-S) ?​
  • mon2
    • 14720
    1) Check if any of the other mosfets on this charger IC is shorted / leaky. Are you sure that the PQ1900/1902 mosfets are being soldered in the correct orientation for pin # 1? They are 100% the same mosfet as the original? Share the part number of the mosfet(s) that are dying. Post pics of the reworked area for these replaced parts.
    2) Confirm that the ISL88738 IC is soldered properly and without shorts.
    3) If the battery does not charge, confirm the battery is not defective. This is a DELL so the PSID communication on the DCin power connector is very important. Attach your power adapter and measure the voltage to ground of the PSID pin # 4 of the DCin power connector.
    Post the measurement. Without this 1-wire communication line, the logic board assumes the power adapter is underrated and will not charge the battery.
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
    • Benchaton
      Weird Charging behavior Aspire A517-51G
      by Benchaton
      Ok so, I've got a 17" Aspire 5, when I put it under any sort of medium high load it just stops charging and show blinks the status LEDs which I suppose mean it get's in power safety mode. Only notable things I can see being an issue are my CSME firmware which isn't the one from Acer because the Acer one was a vulnerable version relative to the current firmware I have installed (latest for KabyLake / KabyLake Refresh), the PC being only able to supply 0.05W to the battery on load spikes, and the slightly loose power inlet.
      I mostly suspect the latter but it seamingly started happening...
      07-30-2025, 04:43 PM
    • Scoff
      HP Probook 470 G4 - Power and Charging Problem
      by Scoff
      Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
      Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
      07-03-2023, 09:28 AM
    • Wang Tingting
      Acer Nitro 5 AN515-57-536Q not charging
      by Wang Tingting
      I am trying to fix a Acer Nitro 5 AN515-57-536Q not charging issue, the laptop can boot from battery, adaptor or both. The battery LED is solid orange, but it doesn’t charge. The battery report from win11 looks normal, the acer care
      report is also good for battery.
      Following https://www.badcaps.net/forum/troubl...arging-circuit,
      • DCIN/VCC: 19.1
      • ACIN/ACDET: 3v
      • REGN/VDD: 6v
      • CMSRC : 19v
      • ACOK: 3.3v
      • ACDRV: it is 19v, not 25V(when charging, the ACDRV
      09-10-2025, 01:46 PM
    • abrahim110
      [Help Needed] Acer Aspire 5 A517-52G – Removed Onboard RAM, Now Working But Battery Not Charging
      by abrahim110
      🧡 [Help] Acer Aspire 5 A517-52G – Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
      I have an Acer Aspire 5 A517-52G-53NB laptop.
      The onboard (soldered) RAM was faulty, so I physically removed the chip.
      I also successfully modified the BIOS using the SPD Removal Tool – the laptop now boots fine and works with an 8β€―GB DDR4 SO-DIMM installed.
      βœ… System status:
      • BIOS mod is done (SPD removed)
      • Laptop boots to Windows normally
      • RAM is detected and stable
      ❌ Problem:
      The battery is not charging:
      • Power adapter
      08-06-2025, 06:15 AM
