Dell inspiron 13 5000 - Doesn't turn on, overheating
  • Nagyesz
    • May 2024
    • 124
    • Hungary
    I have a Dell laptop with me, a DELL inspiron 13 5379. It doesn't turn on. After some investigation, I found that the charger is delivering 0-3V instead of 19.5V, and this voltage fluctuates constantly. Additionally, two ICs are overheating. I searched for these ICs, and it seems they are likely related to the issue of not having 19V.
    Should I inject voltage somewhere, or should I replace the ICs right away?
    So, PU4301 is overheating, and the surrounding area is hot, possibly just because of this IC.
ID:	3308552Click image for larger version
  • mon2
    • Dec 2019
    • 14562
    Hi. No injection, yet. Both, PU4301 & PU4302 are mosfets. They are acting like solid state relays / switches to pass through the adapter voltage or not to power the logic board.
    Remove all power. Meter in resistance mode.
    Measure the resistance across each leg of the mosfet. Post each measurement.
    Measure:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    then measure the resistance to ground of the each group. Repeat for the next mosfet.
    We are checking if a part on the rail they power is shorted. We are checking if the mosfet itself is shorted through resistance (ohms) measurements.
    • Nagyesz
      • May 2024
      • 124
      • Hungary
      PU4301
      Source to Drain 5Mohm
      Source to gate 2Mohm
      Gate to drain 125kOhm
      Ground to drain 114kOhm
      Ground to source 125kOhm
      Ground to gate 45kOhm
      PU4302
      Source to Drain 112kOhm
      Source to Gate 100kOhm
      Gate to Drain 225kOhm
      Ground to drain 110 KOhm
      Ground to source 3.5 Ohm (!!)
      Ground to gate 100 KOhm
      • mon2
        • Dec 2019
        • 14562
        Ok. Remove all power. Meter in lowest resistance mode.
        One meter probe on the source pin that appears to be showing a short.
        Other meter probe on any inductor on the board. Check if there is a low resistance. Keep testing each and every inductor on the board.
        One meter probe will always be on this source pin group of the mosfet.
        List all suspected inductors. We are checking if there is a leaky high side mosfet. If for example, the cpu inductors are a low resistance in this checking, then the cpu is probably dead.
        • Nagyesz
          • May 2024
          • 124
          • Hungary
          Found it.
          PL4701 PL4702
          PL4701 to source pin is 0.3 Ohm
          PL4701 to ground 4 ohm
          PL4702 to source pin is 10 ohm
          PL4702 to ground 6 ohm
          also found this near to these inductors
          • mon2
            • Dec 2019
            • 14562
            See attached. This area looks like it has been reworked. The part with the yellow arrow is a suspect. Flux and carefully remove this capacitor. Do not lose the part.
            Then check if you still have the very low resistance on the source pins of the mosfets.
            • mon2
              • Dec 2019
              • 14562
              These measurements are of concern and usually imply that the high side mosfets that are internal to the regulators @ PU4701 and PU4702 are leaking and this will often kill the CPU.
              That is, the high voltage from the adapter of ~19 volts would have travelled to these switching regulators. The high side mosfet turns on/off to regulate the voltage for the CPU to be ~1 volt.
              If the high side mosfet (either one) is leaking, then the full ~19 volts would hit the CPU power rail.
              For closure, would you have an adjustable power supply? If yes, dial it to 1 volt (only) and inject the voltage at the source pins of the mosfet and check who is heating up. Is it the CPU?
              If you do not have a power supply, then flux and remove either PU4701 or PU4702. Then measure the resistance to ground again. If needed, remove the other VCORE regulator. Test the resistance again. Proceed only if you feel comfortable or test the process on a donor board.​
              • Nagyesz
                • May 2024
                • 124
                • Hungary
                With the PSU, there was no heating when conducting 1V through the source; the machine drew 0.6-0.8A out of 2A. Now I will try the other method.
                edit: Are you sure to remove PU4701 or PU4702, wouldn't be better to remove the inductors?
                • mon2
                  • Dec 2019
                  • 14562
                  Some part on your main power rail is partially shorted. The resistance of 3R5 to ground is too low.
                  Try to lift one leg of the local inductor at PL4701.
                  Test the resistance again. Suspecting the short is inside one or both of the regulator chips.
                  • Nagyesz
                    • May 2024
                    • 124
                    • Hungary
                    Unfortunately, after removing the inductors, the suspicion of a short circuit remained on the processor side. In both areas where I lifted the inductor legs, the processor side is around 2 ohms (VCC_CORE) , and from other side it's OL to ground (PWR_VCORE_SW1-2) .
                    Edit: I suppose if I plugged it into the charger now, the voltage wouldn't jump between 0 and 3, right?
                    • mon2
                      • Dec 2019
                      • 14562
                      Having a low resistance on a low voltage rail like the VCORE is ok. This is by design.
                      Can you check the source pins again at the mosfet to ground resistance? Do you still have 0.3 ohms to ground? Perhaps you can share a pic of the meter for a cross check of the measurement.
                      Do not plug in the power with these parts removed.
                      PS: Perhaps with some luck - the internal mosfets inside of these VCORE regulators stopped the flow of the high voltage to the VCORE pins of the CPU. My suspicion is still with these regulators and should be replaced. The key point is that the source pins should be with 0R3 to ground.
                      • Nagyesz
                        • May 2024
                        • 124
                        • Hungary
                        Without the two inductors, the PU4302 Source is 2-3MOhm
                        VCC_CORE is 2.7 Ohms and 3.7 Ohms PWR_VCORE_SW2 is OL PWR_VCORE_SW1 is 170k Ohm
                        However, when any inductor is reattached, the PU4302 Source remains at 0 Ohms
                        Could I be lucky this time?
                        • mon2
                          • Dec 2019
                          • 14562
                          Do wait on feedback from other techs but in my opinion, these regulators have internal high side mosfet shorts. If you wish, replace both of these regulators and then check the resistance at the mosfet source pins again. If the source pins are at a high resistance after the regulator ICs have been replaced, then you may be lucky to try again. My concern is if the high voltage reached the CPU core voltage rails or not.
                          As a test, inject 1 volt at the source pins of the mosfet. Then monitor the voltage at the inductors that you have lifted. Do you see a voltage that is similar to what you are injecting?
                          • Nagyesz
                            • May 2024
                            • 124
                            • Hungary
                            I tried it, with 1V injected precisely at the legs of the inductors, both inductor legs are fine, and there is no current draw, whereas when the inductors were connected, the machine drew 0.6-0.8A.
                            So, from what I understand so far, something is short-circuiting, because instead of 19V, the machine fluctuated between 0-3V. After removing the inductors, the MOSFET source leg was fixed. When I put the inductor back, there's a short circuit on mosfet source (0 ohms).
                            Unfortunately, I'm stuck here; could it be my luck, or is the processor the issue?
                            • Nagyesz
                              • May 2024
                              • 124
                              • Hungary
                              Edit
                              I mean to the source pins of the mosfet, and same Volts could be measured from the inductors
                              • tofik
                                MOSFET equivalent K8A60DA
                                by tofik
                                Hello guys,
                                I have a shorted MOSFET K8A60DA with the following characteristics:
                                Type Designator: TK8A60DA
                                Marking Code: K8A60DA
                                Type of Transistor: MOSFET
                                Type of Control Channel: N -Channel
                                Maximum Power Dissipation (Pd): 45 W
                                Maximum Drain-Source Voltage |Vds|: 600 V
                                Maximum Gate-Source Voltage |Vgs|: 30 V
                                Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                                Maximum Drain Current |Id|: 7.5 A
                                Maximum Junction Temperature (Tj): 150 °C
                                Total Gate Charge (Qg): 20 nC
                                Rise Time (tr): 25 nS
                                Drain-Source
                                07-19-2023, 05:18 AM
                                DELL Inspiron 3250 Inspiron 3000 i5-6400 Specification for Upgrade or Repair
                                This specification for the DELL Inspiron 3250 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3250 boardview and Inspiron 3250 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                09-12-2024, 03:44 PM
                                DELL Inspiron 3268 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                This specification for the DELL Inspiron 3268 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3268 boardview and Inspiron 3268 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                DELL Inspiron 3650 Inspiron i5-6400 Specification for Upgrade or Repair
                                This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                DELL Inspiron 3650 Inspiron i7-6700 Specification for Upgrade or Repair
