Acer ES1-512 series wont turn on
This topic has been answered.
  • baddjavo
    • Jun 2018
    • 87
    • Serbia
    laptop: Acer es1-512-C79X
    model no: MS2394
    S/N: NXMRWEX01152004e64660
    mb: EA53-bm/EG52-BM MB 14222-1 448.03707 0011
    Few days iam trying to figure why wont turn on after pressing pwrbtn.
    I have 3v on pwr btn.
    3V and 5v not present (if i short ecrst# pin 85 on EC chip then 3 and 5v present)
    Probably missing signal on EC chip, but i dont know which one.
ID:	3307772 Click image for larger version
ID:	3307773 Click image for larger version
ID:	3307774Click image for larger version
  • Answer selected by baddjavo at 07-19-2024, 06:03 PM.
    baddjavo
    • Jun 2018
    • 87
    • Serbia
    Let close this thread. Finally i have found that pu5001 working properly but getting hot, taking so much amps.... traced short over pu3601 out ... and then short lead me to c2729 ! Its a BADCAP !
    Thank to all percipients. BADCAP !!!
    • mon2
      • Dec 2019
      • 13830
      Check the earlier power sequence signals.
      • baddjavo
        • Jun 2018
        • 87
        • Serbia
        Thank you for answer. Please can u specify where to find RTC_AUX_S5 on which component.
        RTC_RST# = 3V that not good, line going only to cpu.
        3D3V_AUX_S5 = 3v
        3D3V_RTC_AUX = 3v
        5V_AUX_S5 = 5v
        ECRST# = 3V
        • mon2
          • Dec 2019
          • 13830
          If the earlier lines are logic ‘1' then you are ok.
          In your first post, what did you do to pin 85 to make the power rails work?
          • baddjavo
            • Jun 2018
            • 87
            • Serbia
            RTC_RST# should be ZERO, coz #, this is not good.
            ECRST# should be ZERO.
            I just short to gnd pin 85 with tweezers, and 3v and 5v always voltage started.
            • mon2
              • Dec 2019
              • 13830
              Study who is driving the ECRST#​ signal. That driver circuit needs to be reviewed. If it is the EC then check the power, check the clock. Maybe the EC bios is corrupt.
              • baddjavo
                • Jun 2018
                • 87
                • Serbia
                ECRST# signal is generated by EC chip dropping voltage to zero probably mosfet inside EC. This is initialization stage BIOS coming later. I think EC chip is good.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Wrong. ECRST# & RTC_RST# both should be 3.3V. You need to understand the suffix # a bit more.
                  If ECRST# is say 0V that means its in RESET mode .When its at 3.3V it means its has reset itself.
                  • baddjavo
                    • Jun 2018
                    • 87
                    • Serbia
                    Ok. If i get it, ecrst# is impulse for short time, then returns to 3.3v for EC normal mode. So i should try to change bios ?
                    Can u explain why 3v,5v regulator working when short ecrst# to zero ?
                    Didnt find any shorts on board. Laptop used on battery then sudden shut down, after that laptop wont turn on.
                    • mon2
                      • Dec 2019
                      • 13830
                      The reset line is active low, denoted with the '#' suffix. When this signal is LOW, the RESET state is active. After a period of required time, this signal must release the logic LOW level and return to a logic HIGH = ~3 volts. Only then will the components being driven by this signal start execution.
                      When you use the tweezers, your logic low level is long enough to perform this task.
                      So,
                      1) either the EC is never performing the EC reset pulse from LOW to a HIGH.
                      2) or the pulse on this line is too short of a duration to perform the reset action
                      Does the board power up normally after you perform this tweezer short action?
                      The EC is a stand alone microcontroller (8051 / ARM, etc.) and has its own firmware. Often a local flash device or internal to the EC controller. Sometimes, the main PCH / CPU will spoon feed the firmware over it's communication lines. Either way, yes, it is worthwhile to make a bios backup and reflash it with a known good one for further testing.
                      • baddjavo
                        • Jun 2018
                        • 87
                        • Serbia
                        I think i get it.
                        Board not powering up after tweezer shot.
                        Still dont have ec programmer.
                        I will take bios backup.
                        Update. I just noticed after pressing pwnbtn laptop is trying to start giving short faint blink on power led, and voltages coming from 3v.5v reg, only for a moment.
                        • mon2
                          • Dec 2019
                          • 13830
                          Ok. Start with the basics. Review the charger IC thread sticky (above) by piernov.
                          Remove all power. Measure the resistance to ground of the main power rail that follows after the 2 x DCin mosfets.
                          We are checking if there is any shorted part on the board.
                          Measure the resistance to ground on pin # 1 of the charger IC @ PU4403. This rail should not be with a low resistance.
                          What is the exact resistance in ohms?
                          • baddjavo
                            • Jun 2018
                            • 87
                            • Serbia
                            Ressistance in Kilo or Mega, and voltage in picture. All mosfets good.
                            • baddjavo
                              • Jun 2018
                              • 87
                              • Serbia
                              After searching for possible shorts i have found that one of mosfets pu5003 is shorted sourse drain side, but gate is not. Its surprising that lower mosfet died usually that is upper.
                              So i removed mosfet then after pressingpower button blue led light on ! Then i changed mosfet and nothing! Same place where i started.uhm
                              On oscilloscope i found mosfet gate signal no impulses so probably controller also died...
                              • baddjavo
                                • Jun 2018
                                • 87
                                • Serbia
                                • mon2
                                  • Dec 2019
                                  • 13830
                                  Excellent find. Thanks for the closure.
                                  • robante15
                                    Acer Aspire 4520 won't turn on after reboot
                                    by robante15
                                    Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                    It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                    The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                    If I remove the...
                                    04-06-2024, 06:50 PM
                                    09-06-2024, 05:27 AM
                                    Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                    This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                    09-07-2024, 05:00 AM
                                    Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                    This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                    Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                    This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-07-2024, 04:10 AM
