ASUS Zenbook UX334FAC (UX334FL REV2.0) - No Display. Fell off the table.
  • gjgib
    • Nov 2022
    • 70
    • Venezuela
    Hi again!
    -Laptop fell from the table.
    -Motherboard -seems- intact.
    -It turns on kinda normal but NO DISPLAY, NO BACKLIGHT.
    I'm not too familiar with ASUS laptops yet. I'm using a similar laptop model Boardview. (UX333FN REV2.0)
    I feel there might be something wrong with these coil impedance values yet the voltage values go normal.
    COIL = VOLTAGES (adapter powered) = IMPEDANCE TO GND (off and unplugged)
    +VCCSA = 1.0V = 22ohm
    +VCCCORE1 = 0.8V = 3.5ohm
    +VCCCORE2 = 0.8V = 3.5ohm
    +1.05VSUS = 1.05V = 59.ohm
    +1.2V = 1.2V = High-fast fluctuations (weird)?
    +1.8VSUS = 1.8V = 27.3k ohm
    +3VA_DSW = 3.3V = 31.5k ohm
    +5V = 5.1V = 22k ohm
    +5VSUS = 0V = 6ohm
    P_CHG_RSENS_SHAPE = 0.28v = 500k ohm
    +VCCGT = NC = NC
    +1.3VSG = NC = NC
    +1.2V seems to have a -stable-voltage-value meassuring with multimeter but in resistance mode it just goes crazy.
    +5VSUS missing.
    Boardview seems to be in some $ites. If anyone has it would appreciate if can share. Thanks in advance!
    Click image for larger version  Name:	IMG_20240626_122144.jpg Views:	0 Size:	3.76 MB ID:	3297449 Click image for larger version  Name:	Screenshot_1.png Views:	0 Size:	1.47 MB ID:	3297450
  • nikolayu
    • Feb 2021
    • 40
    Does it output the picture on HDMI?
    • gjgib
      • Nov 2022
      • 70
      • Venezuela
      nikolayu Hi good sir. Nope, doesn't seem to be giving HDMI video and I use the cable everyday. Do I have to look out to test with another cable or is not usually a problem?
      Btw, monitor already says no signal after plugging HDMI cable in the laptop board(without adapter power), when usually in desktop boards it waits till I turn board on or plug it to power at least.
      Would that be a problem or na?
      edit1: +5VS_HDMI = 5.1V
    • gjgib
      • Nov 2022
      • 70
      • Venezuela
      I still don't know what the +5VSUS is and how does it work. Is it an important early value for board to go on? I thought it was something like SUSpended. So it came in after board was hybernating or something.
      • mon2
        • Dec 2019
        • 14235
        +5VSUS = 0V = 6ohm
        Resistance to ground is very low @ 6 ohms.
        BV file has been posted here:
        UX334FL 2.0 UX434FL MB_8G_I5-8265U_AS_R2.0 BV File - Badcaps
        • gjgib
          • Nov 2022
          • 70
          • Venezuela
          mon2 Oh, thanks a lot. I'll be right on it. Sorry if I ask much mon2, but could u gift me a brief 20-word description about +5VSUS? Kinda struggling to get it right. What powers, when, for what, etc. Please.
          Or if u know a guide or book, appreciated!
          • mon2
            • Dec 2019
            • 14235
            +5VSUS will be a low current power rail for suspend or perhaps even ALWAYS ON support of components such as the BIOS power rail. You have a low resistance on this rail so someone is very likely shorted. Do you have an adjustable power supply?
            BTW - There is a very similar case to yours on this forum and exactly the same fault. The tech located the power supply IC for this +5VSUS rail and had to replace it to power the bios and the laptop was repaired. Will try to locate that thread in a sec for your reference.
            Found it...
            Is it safe to power up ASUS ROG G14 without TPS25810? - Badcaps
            • mon2
              • Dec 2019
              • 14235
              Locate mosfet PQ8801 using the above linked BV file. Remove all power. Inspect of possible liquid or damage to the parts.
              Meter in resistance mode. Measure the resistance of this mosfet as follows:
              source (1-2-3) & drain (5-6-7-8) ; select any of the pins in the group
              source (1-2-3) & gate (4)
              gate (4) & drain (5-6-7-8)
              Post each measurement. Checking to see if this mosfet is shorted or not.
              • gjgib
                • Nov 2022
                • 70
                • Venezuela
                I think I misplaced couple components because of the similar model boardview I was using. I'll update everything and post it. Brb!
                • gjgib
                  • Nov 2022
                  • 70
                  • Venezuela
                  +VCCGT = 0V = 5 ohm
                  +VCCSA = 1.0V = 19.5 ohm
                  +VCCCORE1 = 0.84V = 3.5 ohm
                  +VCCCORE2 = 0.84V = 3.5 ohm
                  +1.05VSUS = 1.1V = 53 ohm
                  +1.8VSUS = 1.8V = 26.6K ohm
                  +3VA_DSW = 3.3V = 31.5K ohm
                  +5VSUS = 5.1V = 20.6K ohm
                  +1.35VSG = NC = NC
                  +1.2V seems to have a -stable-voltage-value while meassuring with multimeter but in resistance mode it just goes crazy and never stops.
                  +VCCGT missing)?
                  First time seeing this +VCCGT voltage, at least by that name. Can't tell if missing or if it comes in at a specific moment.
                  edit1: +VCCGT seems to be the graphics processor power supply. If is not on, I highly doubt it will give display.
                  Going deep...
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    +VCCGT will rise only on load and almost irrevalent for posting. first check whether numlock light glows on usb keyboard. If yes then mb is posting. If not,then mb is not posting at all.So simply there cant be any display on screen/hdmi.
                    Moreover, VCCGT can be measured only with DSO. Multimeter often fails to catch the slight pulse while posting.
                    • gjgib
                      • Nov 2022
                      • 70
                      • Venezuela
                      Hi. Sorry for being late. I usually attack the problems with the suggestions quick enough but I was sick. I know it because the laptop keyboard has a led on CAPSLOCK key and is not blinking at the beginning nor when I press it after some seconds. USB keyboard key lights turn on but the CAPS/NUMLOCK are off and irresponsive.
                      Indeed the board is NOT DOING POST.
                      Gotta say that board comes in right after AC.Adapter is plugged in, probably because the battery is not connected. After pressing the ON/OFF button on the keyboard for some seconds, it goes OFF for 2 seconds but comes right back ON automatically. Would that be an EC/KBC/IO issue?
                      This is some EC meassurements I did. I don't think I see anything off but I'm yet to learn all the voltages.
                      At first I thought DGPU line was having issues then I saw there's no DGPU chip in this board model. So that voltage shouldn't matter right? Or it is still necessary for the CPU display line?
                      PS_ON_EC = 3.28V
                      VSUS_ON = 3.28
                      5VSUS_ON = 3.28V
                      +3VA_EC = 3.28V
                      +3VPLL = 3.3V
                      +3VS = 3.3V
                      1.2V_ON = 3.3V
                      3VA_ALW = 3.3V
                      DPWROK_EC = 3.27V
                      3VA_DSW_PWRGD = 3.3V
                      3VADSW_ON = 3.3V
                      3VSUS_PWRGD = 3.3V
                      PM_SYSPWROK = 3.27V
                      PM_PWROK = 3.28V
                      ALL_SYSTEM_PWRGD = 3.3V
                      AC_IN_OC# = 0V
                      EC_RST# = 3.3V
                      LID_SW# = 3.28V
                      RC_IN# = 3.3V
                      PM_SUSB# = 3.3V
                      PM_RSMRST# = 3.28V
                      PM_SUSC# = 3.3V
                      PM_PWRBTN# = 3.3V
                      DGPU_PWR_EN#_EC = 2.55V
                      DGPU_RST#_EC = 2.55V
                      DGPU_LIMIT = 2.55V​
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Measurements shared on post#12 are correct.
                        DRAMRST# present?
                        • gjgib
                          • Nov 2022
                          • 70
                          • Venezuela
                          I don't think I see that 'DRAMRST#' voltage name in the EC voltages list. I'll leave the voltages# here just in case it goes with another name. If not, it may be hidden under the 'N83339956' stuff but I could track where it might be with some hints.
                          AC_IN_OC#
                          BAT1_IN_OC#
                          BUF_PLT_RST#
                          CAP_LED#
                          CHG_FULL_LED#
                          CHG_LED#
                          CVT_SNSR#
                          DGPU_PWR_EN#_EC
                          DGPU_RST#_EC
                          EC_RST#
                          EC_SCE#_PCH
                          EXT_SCI#
                          EXT_SMI#_X1
                          FN_LED#
                          IMVP8_VRHOT#
                          LCD_BACKOFF#
                          LID_SW#
                          LPC_FRAME#
                          MIPI_RESET#
                          OP_SD#
                          PCH_SUSACK#
                          PM_CLKRUN#
                          PM_PWRBTN#
                          PM_RSMRST#
                          PM_SUSB#
                          PM_SUSC#
                          PWR_SW#
                          RC_IN#
                          TP_DISABLE#
                          If not there I can check
                          • gjgib
                            • Nov 2022
                            • 70
                            • Venezuela
                            In this post about UX330UAR rev 2.1 no DISPLAY, DRAMRST# is missing. I tracked the line and it comes from the +1.2V through a Resistor which I don't know the value because the BV doesn't show.
                            My DRAMRST# could be similar. I'm using this BV UX334FL 2.0.
                            • gjgib
                              • Nov 2022
                              • 70
                              • Venezuela
                              Here I found something with different name that looks just like the line I've shown above.
                              ​Line +V_DDR_WR_VREF01_DIMM has 0.6V.
                              • gjgib
                                • Nov 2022
                                • 70
                                • Venezuela
                                Also meassured the RAM IC, don't seem to have any wrong values but the pin10-(P_DDR_LDO_EN_10) seems weird to me, maybe I'm wrong since it's a LDO Voltage. (Voltages in image, also)
                                • gjgib
                                  • Nov 2022
                                  • 70
                                  • Venezuela
                                  Couldn't find the RAM-IC anywhere. This is its inscription.
                                  Click image for larger version  Name:	Sin título.jpg Views:	0 Size:	557.3 KB ID:	3302606
                                  Marks: BCLBXA.
                                  Boardview calls it: DOWN CONVERTER SYV731RAC//SILERGY QFN3*3-20
                                  Btw, I know it kinda varies from IC to IC, but are these rails voltages usually around these values?
                                  'BST' (4.5V)?
                                  'P_DDR_LDO_EN_10' (2.8V)? Is this LDO ENable enough to be enabled/enabling?
                                  'P_DDR_VTTREF_10' (0.6V)?
                                  'P_DDR_FB_10' (0.6)?
                                  I started seeing these voltages recent ago with some Charger ICs. Yet to fully understand them.
                                  Are REFerence and FeedBack voltages half of the ouput value of the IC?
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    These voltages seems ok to me. Feedback,EN LDO voltages dependes on the resistor value and pull up value.
                                    • gjgib
                                      • Nov 2022
                                      • 70
                                      • Venezuela
                                      Thanks. The problem is that I couldn't find exactly DRAMRST# right?
                                        ASUS ZenBook UX334FL-A4015T Notebook 13 Specification for Upgrade or Repair
                                        This specification for the ASUS ZenBook UX334FL-A4015T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX334FL-A4015T boardview and UX334FL-A4015T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-06-2024, 08:40 PM
                                        ASUS ZenBook UX334FL-78DM5BP1 Notebook Edition 30 Specification for Upgrade or Repair
                                        This specification for the ASUS ZenBook UX334FL-78DM5BP1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX334FL-78DM5BP1 boardview and UX334FL-78DM5BP1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-06-2024, 04:40 PM
                                        ASUS ZenBook UX334FL-A4052T Notebook Edition 30 Specification for Upgrade or Repair
                                        This specification for the ASUS ZenBook UX334FL-A4052T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX334FL-A4052T boardview and UX334FL-A4052T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-06-2024, 02:34 PM
                                        ASUS ZenBook UX334FL-A4011T Notebook 13 Specification for Upgrade or Repair
                                        This specification for the ASUS ZenBook UX334FL-A4011T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX334FL-A4011T boardview and UX334FL-A4011T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-06-2024, 11:39 AM
                                        ASUS ZenBook UX334FL-A4033R Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS ZenBook UX334FL-A4033R Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX334FL-A4033R boardview and UX334FL-A4033R schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-06-2024, 11:30 AM
