Lenovo Yoga C940-14 - will not power up each morning until resetting BIOS
  • survivalbloke
    • Aug 2021
    • 302
    I've got this laptop here which is presenting very odd behavior. It works perfectly fine except every morning, it won't power up. Power button does nothing. Reset button on bottom also doesn't seem to have any effect, but if I disconnect the battery, hold the power button for a few seconds to drain capacitance, when I connect the battery back, I can power on. It will go through RAM training as normal, and eventually boot into Windows. The laptop will work fine all day long, but the next morning - the problem is there again.
    Any thoughts?
  • mon2
    • Dec 2019
    • 14508
    Remove the battery. Does the laptop function with only the power adapter?
    • survivalbloke
      • Aug 2021
      • 302
      It does function without the battery. Also, an observation I made yesterday is that it doesn't need to sit overnight to produce the fault. I noted after only a few hours of sitting, not being used, lid open, the device had powered off. It would not respond to the power button. I disconnected the battery and powered it up and it is now sitting beside me, running perfectly normal - without the battery.
      **UPDATE** It powered off after only a few moments and has the fault.
      • mon2
        • Dec 2019
        • 14508
        To confirm, the board is unable to work with using the external power adapter only (no battery connected)?
        Carefully measure the voltage to ground of CHARGER_CHGOK (pin # 4) on the charger IC @ PU12 with the power adapter connected (no battery).
        • survivalbloke
          • Aug 2021
          • 302
          No, that is not correct. With battery disconnected and external power supply connected, it will power up. But in this case, moments later, the device lost power and is currently in a fault state "no power, no response from power button". Currently drawing 48ma.
          • mon2
            • Dec 2019
            • 14508
            Carefully measure the voltage to ground of CHARGER_CHGOK (pin # 4) on the charger IC @ PU12 with the power adapter connected (no battery).​
            • survivalbloke
              • Aug 2021
              • 302
              You wouldn't happen to have a boardview or schematic for this board would you? I'm trying to locate PU12. While I was looking for PU12, I noticed this @ PU2 (see attached) Also, liquid damage @ U17.
              • mon2
                • Dec 2019
                • 14508
                No BV. Yup, always always always start with a visual inspection. That is rule #1 on Rossmann videos. That cat puke / urine needs to be cleaned up with IPA.
                PU12 = BQ25710RSNR QFN 32P_4X4​
                • survivalbloke
                  • Aug 2021
                  • 302
                  Hey, thank you so much! So, to update you, after I repaired the liquid damage and re-flowed a couple of components, the laptop is working correctly and the fault has gone. Cheers!
                    Lenovo Yoga Yoga 6 13ALC7 Notebook Specification for Upgrade or Repair
                    This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-07-2024, 05:00 AM
                    Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) Specification for Upgrade or Repair
                    This specification for the Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga Gen 6 boardview and X1 Yoga Gen 6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                    Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
                    This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                    Lenovo Yoga Yoga 6 13ALC7 Notebook 700 Specification for Upgrade or Repair
