please help friends thinkpad T470 error post "bottom cover tamper detection error"
  • bhatt
    replied
    Originally posted by fredyjbi
    please help friends thinkpad T470 board CT470 series NM-A931 error post "bottom cover tamper detection error"
    I've already
    flashed the bios clean me and updated from the Lenovo site, then removed the switch and immediately jumped the S3 from pins 1 to 4, 2 to 3 but the problem remained the same, thank you
    jumper 1+2 2 and 3 and 4
  • charliee
    replied
    Originally posted by charliee
    I think the EC chip (Embedded Controller,MEC1653) may have a soldering defect.
    Place the motherboard steadily,and try heating the EC chip with a heat gun to 230°C for 1 minute.Then let it cool down naturally.
    Or you can also consider replacing the chip.Note that this chip has a built-in program. Please make sure that the spare part also has a program.
    [UPDATE]
    You may need to check whether these components are normal first. If they are damaged, this error will also occur.
ID:	3342544Click image for larger version
  • charliee
    replied
    Or you can also consider replacing the chip.Note that this chip has a built-in program. Please make sure that the spare part​ also has a program.
  • fredyjbi
    replied
    Originally posted by mon2
    The logic levels look correct to me since the parked state is a logic '1'.
    Review the BIOS settings under SECURITY to see if this setting can be disabled.
    Some Lenovo ThinkPad notebook systems contain a mechanical tamper detection switch - Lenovo Support US
    thank you sir for your help, yes this case is very strange sir still the tamper error, I have checked the bios security position is disabled, thank you Click image for larger version
  • mon2
    replied
  • fredyjbi
    replied
    INTRUDER# netname has a '#' as a suffix. In the digital logic world, the hash-tag suffix denotes that the signal is active LOW. That is, if this line is ~0v = logic low, then the signal is active. So if 0v, INTRUDER alert.
    Respectively, remove the short applied between S3 pins 2-3. This will remove the hard short to ground and then the pull-up resistor (R646) on the same signal will be parked to the logic '1' state. Test again.
    Sorry sir, I am late in giving an answer, sir, I have removed the pin 2 to 3 jumper, and also replaced the R646 resistor but the results are still the same, thank you and where should I check again
    sw3
    pin1 3.3v -INTRUDER_PCH
    pin2 3.3v
    pin3 3.3v
    pin4 0v
    D5
    pin 1 3.3v
    pin2 3.3v -INTRUDER_EC
  • mon2
    replied
  • please help friends thinkpad T470 error post "bottom cover tamper detection error"
    I've already
  • aldopc
    LENOVO T480 ERROR POST " bottom cover tamper detection error "
    by aldopc
    Hello friends, could someone help, I have this thinkpad with that message when starting, I already disabled it from the bios but the message continues, I also cleaned the region for me but the problem is not fixed, I also measured the switch cover but it is working... does anyone have Any idea what it could be? I attached my dump in case anyone can help....
    04-19-2023, 02:38 PM
    Lenovo ThinkPad T470 Notebook T Specification for Upgrade or Repair
    This specification for the Lenovo ThinkPad T470 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T470 boardview and T470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
    09-06-2024, 03:30 PM
    09-06-2024, 11:40 AM
    09-06-2024, 11:29 AM
