Help finding part number
  • chickenhawk88
    • May 2024
    • 86
    • US
    I need help trying to figure out these components.
    1. There is large “Q” almost looks like Qualcomm, FA7808 or FA7608, 2039CC
    2. This chip has marking of VE with 5 pins.
    3. This chip has marking eHCSN.
    Thanks for helping. Im trying to fix laptop motherboard and not having much luck.
    • 21210
    Post the motherboard model number. Have you checked if there is a schematic or boardview available
    • chickenhawk88
      • May 2024
      • 86
      • US
      The laptop I am working on is RAZER BLADE 15 , RZ09-0369. Looks like the motherboard is DA560 VER 4.0
        • 21210
        There is no schematic available AFAIK.
        eHCSN could be a silergy SY8386RHC https://www.badcaps.net/forum/troubl...and-datasheets
        • chickenhawk88
          • May 2024
          • 86
          • US
          Thanks. I tried looking for older versions but there are not much out there for Razer laptops.
          • lorins_core
            BlackSmith
            • Dec 2012
            • 551
            • Philippines
            hello to all.
            Does anyone have this datasheet of this kind of ic?
            Click image for larger version  Name:	WIN_20240514_17_15_49_Pro.jpg Views:	0 Size:	108.5 KB ID:	3271850
            part no: RE=AD
              • 21210
              Originally posted by lorins_core
              hello to all.
              part no: RE=AD
              You`ve already asked in another thread https://www.badcaps.net/forum/troubl...-0#post3271798 .Also i sent you a private message 2 days ago :
              Thread merged with existing topic - https://www.badcaps.net/forum/troubl...m-f091-rev-1-0
              Thread renamed,added NM-F091 to thread title - https://www.badcaps.net/forum/troubl...-pro-7-nm-f091
              IC`s with an = are made by richtek https://www.badcaps.net/forum/troubl...and-datasheets
              Use the forum search,look for RE= ,or search on google​
              • chickenhawk88
                • May 2024
                • 86
                • US
                Need some help id some chips.This is for Razer Blade 15 motherboard DA560 v4.0
                1. Markings are "FA7608 2039CC"
                2. Markings are "bPCXN"
                I attached some pics of it. TIA.
                  • 21210
                  Thread merged, don`t start another thread again please.............
                  bPCXN SY8088IAAC​ https://www.silergy.com/download/dow...type=datasheet
                    • 21210
                    1. Markings are "FA7608 2039CC".
                    Fortune Advanced Technology FA7608 load switch https://www.fortuneadvanced.com/prod...il/FA7608-i.54
Name:	Fortune Advanced Technology.jpg
                      • 21210
                      1. This chip has marking of VE with 5 pins.
                      Nexperia 74LVC1G08GW https://www.mouser.co.uk/datasheet/2...08-2937782.pdf
                      • chickenhawk88
                        • May 2024
                        • 86
                        • US
                        Thanks for your help finding the part numbers, i found seller on aliexpress that has them.
                        • tampatec
                          • Nov 2015
                          • 15
                          • SriLanka
                          Please Some one Find me the IC part number.
                          This is from HP Pro book 450 G0 laptop mother board (location PU4701)
                          No Schematic available for this .(Fiji MB 12238-1)
                          Thank You
                          • mon2
                            • Dec 2019
                            • 14368
                            Post the bottom side view of this part.
                              • 21210
                              Thank You
                              RT8068AZQW https://www.badcaps.net/forum/troubl...96#post3203696
                              • tampatec
                                • Nov 2015
                                • 15
                                • SriLanka
                                Thank you for your Time.
                                SMDFlea found the Part Number.
                                • tampatec
                                  • Nov 2015
                                  • 15
                                  • SriLanka
                                  Thanks a lot for the HELP.
                                  Exactly this is the Correct part Number.
                                  Thank you.
                                  • edugimeno
                                    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                    by edugimeno
                                    Hi There!
                                    I'm trying to help my friend who owns a restaurant be just bought.
                                    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                    It's stuck using, I guess, the 2 sided tape that comes with the strip
                                    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                    09-05-2024, 09:34 AM
                                  • tech_guru
                                    Cannot find PS5 IC (marking F2=8D) part number
                                    by tech_guru
                                    Hello everyone.
                                    Is there any chance somebody can find the part number of this chip or equivalent, in the attached photo?
                                    It is from PS5 EDM-020 board, in the front usb section, near F3502.
                                    It must be a Richtek ic, vqfn32 package style.
                                    Thank you in advance....
                                    05-27-2024, 01:37 AM
                                  • esinior
                                    Smd code to part number
                                    by esinior
                                    Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
                                    I've attached pics of this part
                                    Thanks...
                                    08-20-2024, 02:50 AM
                                  • Yanleb
                                    Panasonic part number in service manuals
                                    by Yanleb
                                    In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                                    This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                                    For an example, look at the attached PDF.
                                    Do you have a way to cross reference the Panasonic part number with the actual part number?
                                    Thanks....
                                    07-03-2023, 08:16 PM
                                  • Mdink
                                    Schematic diagram for clevo w65jo and board part-number 6-71-w65j0-d01
                                    by Mdink
                                    Hello, I need help me with schematic diagram for clevo w65j0 and part number 6-71-w65j0-d01.
                                    07-10-2025, 11:35 AM
