Help finding part number
  • chickenhawk88
    • May 2024
    • 86
    • US
    I need help trying to figure out these components.
    1. There is large “Q” almost looks like Qualcomm, FA7808 or FA7608, 2039CC
    2. This chip has marking of VE with 5 pins.
    3. This chip has marking eHCSN.
    Thanks for helping. Im trying to fix laptop motherboard and not having much luck.
    • 23624
    Post the motherboard model number. Have you checked if there is a schematic or boardview available
    • chickenhawk88
      • May 2024
      • 86
      • US
      The laptop I am working on is RAZER BLADE 15 , RZ09-0369. Looks like the motherboard is DA560 VER 4.0
        • 23624
        There is no schematic available AFAIK.
        eHCSN could be a silergy SY8386RHC https://www.badcaps.net/forum/troubl...and-datasheets
        • chickenhawk88
          • May 2024
          • 86
          • US
          Thanks. I tried looking for older versions but there are not much out there for Razer laptops.
          • lorins_core
            BlackSmith
            • Dec 2012
            • 552
            • Philippines
            • Information Technology
            hello to all.
            Does anyone have this datasheet of this kind of ic?
            Click image for larger version  Name:	WIN_20240514_17_15_49_Pro.jpg Views:	0 Size:	108.5 KB ID:	3271850
            part no: RE=AD
              • 23624
              Originally posted by lorins_core
              hello to all.
              part no: RE=AD
              You`ve already asked in another thread https://www.badcaps.net/forum/troubl...-0#post3271798 .Also i sent you a private message 2 days ago :
              Thread merged with existing topic - https://www.badcaps.net/forum/troubl...m-f091-rev-1-0
              Thread renamed,added NM-F091 to thread title - https://www.badcaps.net/forum/troubl...-pro-7-nm-f091
              IC`s with an = are made by richtek https://www.badcaps.net/forum/troubl...and-datasheets
              Use the forum search,look for RE= ,or search on google​
              • chickenhawk88
                • May 2024
                • 86
                • US
                Need some help id some chips.This is for Razer Blade 15 motherboard DA560 v4.0
                1. Markings are "FA7608 2039CC"
                2. Markings are "bPCXN"
                I attached some pics of it. TIA.
                  • 23624
                  Thread merged, don`t start another thread again please.............
                  bPCXN SY8088IAAC​ https://www.silergy.com/download/dow...type=datasheet
                    • 23624
                    1. Markings are "FA7608 2039CC".
                    Fortune Advanced Technology FA7608 load switch https://www.fortuneadvanced.com/prod...il/FA7608-i.54
Name:	Fortune Advanced Technology.jpg
                      • 23624
                      1. This chip has marking of VE with 5 pins.
                      Nexperia 74LVC1G08GW https://www.badcaps.net/download/?id=55183226
                      • chickenhawk88
                        • May 2024
                        • 86
                        • US
                        Thanks for your help finding the part numbers, i found seller on aliexpress that has them.
                        • tampatec
                          • Nov 2015
                          • 15
                          • SriLanka
                          • Electronics
                          Please Some one Find me the IC part number.
                          This is from HP Pro book 450 G0 laptop mother board (location PU4701)
                          No Schematic available for this .(Fiji MB 12238-1)
                          Thank You
                          • mon2
                            • 15869
                            Post the bottom side view of this part.
                              • 23624
                              Thank You
                              RT8068AZQW https://www.badcaps.net/forum/troubl...96#post3203696
                              • tampatec
                                • Nov 2015
                                • 15
                                • SriLanka
                                • Electronics
                                Thank you for your Time.
                                SMDFlea found the Part Number.
                                • tampatec
                                  • Nov 2015
                                  • 15
                                  • SriLanka
                                  • Electronics
                                  Thanks a lot for the HELP.
                                  Exactly this is the Correct part Number.
                                  Thank you.
                                  • saghi88
                                    looking for part number (Marking code 46BF) Case DFN8 3x3
                                    by saghi88
                                    I am looking for the part number of this component so I can order it. I cannot identify it based on the marking code; I think it is an LDO IC. Can anyone determine the manufacturer's part number from the marking code?
                                    I have uploaded images showing the dimensions and the marking code of the IC. I believe the package is a DFN-8 with dimensions of 3 mm × 3 mm × 0.9 mm.
                                    Thank you in advance for your support
                                    11-21-2025, 03:38 AM
                                  • AJ847.63e
                                    Xbox 360 slim trinity 5v to 3.3 regulator part number?
                                    by AJ847.63e
                                    does anyone know the part number for the 5v to 3.3v regulator to the Xbox 360 slim trinity board? It’s the sot 23 package directly in front of the fan connector.
                                    I’ve checked the schematics but the part number it gives seems to be a Xbox specific part number so google has no results for it.
                                    board I’m looking at had it shorted. 2.1 ohms to ground on its output. Removing it and the short is gone.
                                    thanks for the assistance
                                    01-30-2026, 02:49 AM
                                  • mgourgios
                                    Cannot find PS5 IC (marking F2=8D) part number
                                    by mgourgios
                                    Hello everyone.
                                    Is there any chance somebody can find the part number of this chip or equivalent, in the attached photo?
                                    It is from PS5 EDM-020 board, in the front usb section, near F3502.
                                    It must be a Richtek ic, vqfn32 package style.
                                    Thank you in advance....
                                    05-27-2024, 01:37 AM
                                  • esinior
                                    Smd code to part number
                                    by esinior
                                    Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
                                    I've attached pics of this part
                                    Thanks...
                                    08-20-2024, 02:50 AM
                                  • SilverbackITGuy
                                    Asus ROG Strix G17 , Identifying a part number from the boardview diagram ID
                                    by SilverbackITGuy
                                    First of all, I hope I got this into the right section. Apologies if I did not.
                                    I was working on my Asus ROG Strix G17 (2021) G713QM-RS96, and I guess I pre-heated the board too much replacing the DC Jack and one of the small parts came off. I looked for it on my soldering mat, and it was nowhere to be found. So now, the laptop is powered from the new DC Jack I installed, but it will not charge the battery from that jack. Only powers the hardware.
                                    I looked at the boardview diagram in another post for the G713QM, and it looks like the diagram displays it as X450, a 4 contact...
                                    11-18-2025, 07:23 PM
