please help thinkpad T480 NM-b501 dead, VSYS_OUT 9.2v, thank you
  • fredyjbi
    • Feb 2021
    • 144
    • malaysia
    Please help sir , this board does not turn on because VSYS_OUT is 9.2v, I compared it with a normal board VSYS_OUT is 10.2v, I have replaced the PQ101 and PQ102 mosfet and BQ 25700 which is known to be good , but the results are still the same, thank you.
    VSYS_OUT 9.2v Meter in resistance mode auto range 6M ok
    NORMAL BOARD 10.2V
    PQ101
    PIN 2 20V
    PIN 7 0.004V
    PIN 6 6V
    PIN 5678 0V
    PQ102
    PIN 567 0V
    PIN 9 0.004V
    PIN 234 9.2V (VSYS_OUT)
    PU101 BQ25700ARSNR
    1 VBUS 20V
    2 ACN 20,21V
    3 ACP 20,21V
    7 VDDa 6v
    5 chrg_ok 0v
    schematic https://www.badcaps.net/forum/troubl...b501-schematic
  • Markus1741
    • Sep 2020
    • 946
    • N/A
    Lenovo ThinkPad T480
    Type 20L6-S2L200
    Motherboard Number: NM-B501 Rev: 1.0
    Serial Number: PF1FZ63H
    Hello, I'm not getting anywhere, maybe someone can give me a tip in the right direction.
    About the background Notebook had liquid damage, I removed corrosion with alcohol so far none of the components were burnt out or had burn mark.
    Notebook will not start.
    It doesn't show any LEDs or anything like that when you turn it on and the voltage doesn't change.
    • mon2
      • Dec 2019
      • 14662
      The charger IC's output voltage is configured using the SMBUS SCL / SDA lines so it is important that they are not shunted to ground.
      Carefully, measure the voltage to ground of:
      RTCVCC ; battery with charge for RTC is required
      I2C_CLK_CHARGE
      I2C_DATA_CHARGE
      I2C_CLK_BT0
      I2C_DATA_BT0
      • mon2
        • Dec 2019
        • 14662
        The 20V on the power delivery meter is a good start. This implies that the PD controller on the logic board is working. This PD controller and the external USB Type C power adapter have properly communicated to dial up the required 20V to power up. However, the current draw is wimpy @ ~50 mA so the logic board's power path is defective.
        Do review:
        PF1 ; fuse onboard - most likely not the fault since you have some current consumption but does not hurt to remove all power and measure the resistance across this fuse. It should be ~0 ohms if the fuse is not defective.
        Next in the power path from the USB Type C connector are:
        PQ1
        PQ2
        Dcin mosfets. Carefully, measure their voltage to ground of the source (1-2-3); gate (4) and drain pins (5-6-7-8).
        As a quick check -> jump over to inductor PL1 and check its voltage to ground. Do you see ~20 volts here? If not, the fault is in the PQ1 / PQ2 Dcin mosfet region or their trigger conditions.
          • 21874
          LINK to schematic https://www.badcaps.net/forum/troubl...b501-schematic
          • Markus1741
            • Sep 2020
            • 946
            • N/A
            Do review:
            PQ1
            PQ2
            Klicke auf die Grafik f?r eine vergr??erte Ansicht  Name: power_path.png Ansichten: 0 Gr??e: 172,1 KB ID: 3265300
            Thanks for the answer here the values.​
            Fuse PF1 = okay
            PL1 = 20 Volt okay
            PQ2= 20 Volt okay
            PQ1= Gate-Source Voltage 19,7 Volt
            PQ1= Source Voltage 19,7 Volt
            PQ1= Drain-Source Voltage 0,000 Volt not okay
            • mon2
              • Dec 2019
              • 14662
              Remove all power. Meter in resistance mode. Measure the resistance (not DIODE mode) to ground of VSYS_OUT. This is the main power rail that powers the logic board. Checking if this main power rail is shorted which will be sensed by the charger IC and cause the DCin path mosfets to turn OFF.
              If this resistance is not low, proceed...
              Review the next stage of this circuit @ dual mosfet PQ101. What voltage to ground do you see on PL101 ? This leg of the circuit is driven by the charger IC @ PU101.
              If there is a low or no voltage on PL101, then proceed to investigate the PU101 IC.
              (Carefully) Measure the voltage to ground of:
              VBUS ; pin 1
              REGN ; pin 28
              Post each measurement.​
              • fredyjbi
                • Feb 2021
                • 144
                • malaysia
                Type 20L6-S2L200
                Sorry Markus, you should make your own post, your case and mine are different
                  Lenovo ThinkPad T480 Notebook T Specification for Upgrade or Repair
                  This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                  09-06-2024, 03:21 PM
                  09-06-2024, 02:34 PM
                  09-06-2024, 02:28 PM
                  09-06-2024, 12:30 PM
                  09-06-2024, 11:39 AM
