HP X2 1012 G2 Type-C problem
  • pc boy
    D Member
    • Sep 2019
    • 8
    Hi everyone. An HP X2 1012 G2 came the other day. The problem was that the device drained the battery while off. I checked and saw the current is 0.2 before start. I went and checked parts on the MB and saw that the JHL6340 IC that is responsible for controlling Type-C gets hot. Everything worked fine and I checked charging and data of type-C both were OK. I went ahead and replaced the JHL6340. Now it does not get hot, no current before start, charging is OK, but the data of type-c is lost. I mean any type-c device like flash memory or hdmi adapter etc. do not work. I tried another jhl6340 and still the same problem.
    Any Ideas?
    Thanks in advance.
  • mon2
    • Dec 2019
    • 14207
    Check each pin on the type c connector at the pcb pads in diode mode. Remove all power. Meter in diode mode. Red meter probe to ground. Black probe to point to test. Post each measurement and pin tested. The faults may be due to defective esd tvs diodes or a transient that killed the TBT controller the first time.
    • pc boy
      D Member
      • Sep 2019
      • 8
      Thanks for your reply. The point is that before replacing the TBT controller I checked data and power of type-c connector and I am 100% positive that everything worked fine. So eventually the TBT controller was not dead. Would it possibly change any part of your suggestion?
      • pc boy
        D Member
        • Sep 2019
        • 8
        Attached is the values I got from type-c connector pins. Any suggestion?
        • mon2
          • Dec 2019
          • 14207
          Post a pic of the type C connector from the same side where these measurements were taken. Wish to compare the pinout to the connector's datasheet.
          My review is as follows (at this time):
          • pc boy
            D Member
            • Sep 2019
            • 8
            Thanks a million.
            • mon2
              • Dec 2019
              • 14207
              Concerns about the attached and circled areas.
              You are missing some parts in these PCB pad areas. Be sure the PCB tracks are not broken here.
              • pc boy
                D Member
                • Sep 2019
                • 8
                Sorry bro, thought you just need to see the pinout.
                The exact pcb pics are attached.
                • pc boy
                  D Member
                  • Sep 2019
                  • 8
                  Could it be software related?
                  Like those devices that need the bios be modified when replacing SB?
                  • pc boy
                    D Member
                    • Sep 2019
                    • 8
                    Up!
                    Any help is much appreciated.
                    • mon2
                      • Dec 2019
                      • 14207
                      Personally would consider to scrape very gently the blue solder mask off the round vias you can see on the PCB layout. That is, to allow for the meter to test each such PCB via from the connector through hole pads to these vias. Do this for each such PCB trace. Confirm that you have ~0 ohms between the paths (A-B conductivity checks). Proceed with care so that the via nor the trace are cut in the process of this investigation.
                      Diode mode is not recommended here because the meter will tone beep even if the resistance is ~30-50 ohms. We do want to confirm that each trace check is ~0 ohms. Short your meter probes to confirm the lowest the meter can measure before starting. No power during these tests. Want to rule out the connector / PCB traces / PCB vias as the fault.
                        HP Elite x2 1012 G2 + EliteDisplay S14 Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                        This specification for the HP Elite x2 1012 G2 + EliteDisplay S14 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1012 G2 + EliteDisplay S14 boardview and 1012 G2 + EliteDisplay S14 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        09-06-2024, 08:47 AM
                        HP Elite x2 1012 G2 + LaserJet Pro M15w Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                        This specification for the HP Elite x2 1012 G2 + LaserJet Pro M15w Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1012 G2 + LaserJet Pro M15w boardview and 1012 G2 + LaserJet Pro M15w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        HP Elite x2 1012 G2 + Microsoft Office Home & Business 2019 Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                        This specification for the HP Elite x2 1012 G2 + Microsoft Office Home & Business 2019 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1012 G2 + Microsoft Office Home & Business 2019 boardview and 1012 G2 + Microsoft Office Home & Business 2019 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                        HP Elite x2 1012 G2 Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                        This specification for the HP Elite x2 1012 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1012 G2 boardview and 1012 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                        09-06-2024, 08:27 AM
