Dell Inspiron 14-5448 - fan turns off and mobo keeps running
  • Felipe_Serra_83
    • Nov 2023
    • 25
    • Chile
    Hi, everyone. First post of an actual repair. I'm a technician but a complete newbie with laptops.
    So I got this Dell Inspiron to play with.
    No charger, so I connected to my bench PSU.
    The laptop also didn't include: hard disk (I added one of my own for testing, see below) and wireless PCB (but I doubt this could have anything to do with this particular failure).
    ------What it did (and didn't do)------
    1) I turned it on and it powered on. Powered down in 2 seconds by itself.
    2) Removed RAM, changed slot. Same issue. Removed RAMs, cleansed slots. Turned laptop on. It stayed on and it gave the two intermittent beeps alarm.
    3) Put RAM again. Removed battery.
    4) Checked CMOS battery. Removed it, resetted BIOS (pressing power button for 30 seconds)
    5) Removed heatsink and replaced thermal paste.
    5) Added the DDE. Powered on, and it stays on. BUT... The fan (this mobo has only a single fan) stops and the laptop keeps running. Touched the heatsink. Noticed that CPU and GPU temp go up, I shut it off manually. No POSTing, and a single intermittent beep.
    This is the pattern that repeats all the time.
    ------Some checks I made------
    Checked mobo for water stains. None, looks ok to me.
    No component seems visually damaged (such as diodes, mosfets, capacitors and the like).
    No idea if it was ever tinkered with (as in attempts of repair, if it ever had other issues, etc.)
    The chassis and other boards (such as USB and card PCB) are fine.
    I made voltage measurements of inductors. Here's a pic with the numbers:
    ------Machine specs------
    Machine model number --> Dell Inspiron 14-5448
    CPU --> no model specified in the chip itself. Here's a pic:
    In Aliexpress it says the CPU could be either a i5-5200U or a i7-5500U
    GPU --> AMD 216-0855000
    RAM --> 4GB, PC3L, 12800S
    Storage device --> I plugged in a spare DDE I had, a Hitachi 5K320-160 (SATA, 160 GB)
    Motherboard model number --> LA-B015P
    I supossed the problem could either be: in the BIOS. Or maybe the Temp sensor or any other part of the temp monitor is dead.
    Hope I'm not missing anything in the description above. If so let me know.
    Thanks in advance, I really appreciate your help.
  • mon2
    • Dec 2019
    • 14244
    Stop. Did not read the rest (yet).
    Dell uses a single-wire communication line which is often named PS_ID. This communication line is to the Dallas Semiconductor -> Maxim -> Analog (in the order of who owns whom), specification. If you are using a PSU, you are not able to emulate this mandatory PS_ID line so the EC controller (8051 based) does not get pacified on the expected specs of the power adapter.
    Can you source a true and suitable Dell power adapter and test again?​
    • Felipe_Serra_83
      • Nov 2023
      • 25
      • Chile
      Hi, mon2.
      Yes, I can try and get a compatible charger. I'll let you know.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Btw, your cpu setails is indeed there on soc.Look carefully. and its SR23W
        https://www.cpu-world.com/sspec/SR/SR23W.html
        • Felipe_Serra_83
          • Nov 2023
          • 25
          • Chile
          You're absolutely right, mcplslg123​, and I missed that because of all the other numbers behind the "SR" :P. Thanks for the heads up.
          • Felipe_Serra_83
            • Nov 2023
            • 25
            • Chile
            I got the charger, original one, from the guy who gave me the laptop.
            Changed the thermal paste again, installed heatsink and fan. Connected screen and battery. Single RAM in its slot.
            Plugged in the charger and turned on. Neither the power nor the battery light turn on. The screen flashes once, very lightly, but shows nothing. And like before, the fan turns off after two seconds, the single beep warning sounds, the CPU and GPU get hot.
            Does anyone know the terminals of the battery, so I can check the voltage with a multimeter? Perhaps the charger works, even thought the LED doesn't turn on.
            Thanks in advance.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              This mb seems to be a discrete model. Share the mb markings so that discrete graphics can be disabled or not-can be ascertained.
              • Felipe_Serra_83
                • Nov 2023
                • 25
                • Chile
                Hello, mcplslg123​. I suppose that by markings you mean the characters printed there.
                I attached here some snapshots.
                Thanks.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  LA-B015 is mb marking. Try disconnecting graphics coil(PL1002/1003). If it doesnt help
                  01 Shift RC99 to RC100
                  02.Remove RE3
                  03.Stuff RE5(20K)
                  This will make it UMA and if the problem lies in graphics card,you may get display.
                  • Felipe_Serra_83
                    • Nov 2023
                    • 25
                    • Chile
                    Ok, thank you very much. I'll do these and let you know how it goes.
                    • Felipe_Serra_83
                      • Nov 2023
                      • 25
                      • Chile
                      Hello, all. Couldn't find either the RC nor the RE components. Searched for the mobo's schematic, but no luck either. There's only a manual service for the laptop, but it wasn't of much use.
                      I did find the coils.
                      But in desoldering one of them, I accidentally blew a tiny resistor and now I can't find it.
                      Those d-mned little things. But in any case, fat chance of ever reinstalling it, as I have no microscope. :P
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        The only resistor near those coil is a thermistor. After disconnecting both the coils,what is the status?
                        • Felipe_Serra_83
                          • Nov 2023
                          • 25
                          • Chile
                          Tested, and laptop did the same thing: screen flashes, then shows nothing. One beep, which repeats itself continuously. Fan turns off, CPU and GPU heat up.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            You can put the coils back as graphics chip doesnt seems to be the issue here.
                            Whats the status of DRAMRST#? Measure it on ram slot pin30.
                            • Felipe_Serra_83
                              • Nov 2023
                              • 25
                              • Chile
                              DRAMRST# equals 1.34 V
                              Hope I measured this one correctly :P. I did it in the back view of the RAM, where pair numbers are printed in the PCB right next to the pins.
                              BTW, mcplslg123​, I appreciate the time you are putting into this. Thank you!
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Dramrst# is correct. What about PLTRST#?
                                Do you have a dc power supply and DSO? If yes, then we proceed to check smbus communication.
                                However, if you dont have these tools,measure voltage on all pins of QC1.
                                Are you sure bios you flashed is good and me cleaned?
                                • Felipe_Serra_83
                                  • Nov 2023
                                  • 25
                                  • Chile
                                  PLTRST# = 3.3 V
                                  (BTW, I found a schematic of the mobo)
                                  No oscilloscope here, so I measured QC1. All six pins = 3.3 V
                                  "Are you sure bios you flashed is good and me cleaned?" Yes, I resetted it by unplugging and then plugging the CMOS battery,
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    So,you didnt flashed the bios chip and did only a cmos reset. Correct?
                                    If so,strongly recommend to flash bios with an spi programmer like CH34A/RT809F etc.
                                    Cmos reset will reset the bios but wont fix a corrupt bios.
                                    • Felipe_Serra_83
                                      • Nov 2023
                                      • 25
                                      • Chile
                                      Correct, I only did the cmos reset. Like I said, I'm a noob in laptop repairs, but I learnt quite a bit in this experience. Thanks to you and mon2 who replied to this
                                      I'll get the programmer... It's pretty cheap and will sure come on handy for other laptop repairs.
                                      Let you know when I have it. Have a good day!
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        Yeh,flash the bios chip first and then if issue persists we can dig further. However,i'm very hopeful it will be resolved with bios flash.
                                        PS: I wont be available for next 4-5 days as heading for a short vacation but keep the forum posted about progress,if any.
                                        Good luck.
                                          DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:36 PM
                                          DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:30 PM
                                          DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
                                          09-12-2024, 03:28 PM
                                          DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
