GL702VM not charging/unable to power on
  • Peter Toropov
    • Mar 2024
    • 16
    Removed PQ8901, resistances I got on PU8900 IC:
    ACN:‎‎‎‎...................................0 Ohm (short)
    ACP:...................................0 Ohm (short)
    CMSRC:.............................4.55mO
    ACDRV:..............................7.35mO
    ACOK:................................1.1mO
    ACDET:..............................4.25kO
    IADP:.................................197.5kO
    BATPRES:.........................99.3kO
    TB_STAT:...........................19.85kO
    BATSRC:............................8 Ohm
    BATDRV:............................3.9mO
    SRN:..................................9Ohm
    SRP:..................................9Ohm
    ILIM:...................................71.7kO
    IDCHG:..............................183.2kO
    IMVP8_PSYS_INFO:.........28.6kO
    PROCHOT:........................3.5mO
    SDA:..................................0.64mO
    SCL:...................................0.66mO
    CMPIN:..............................58.5kO
    CMPOUT:..........................45kO
    GND: GND
    LG:....................................4 Ohm
    REGN:..............................3.08mO
    BST:..................................2.95mO
    HG:...................................0 Ohm (short)
    LX:....................................0 Ohm (short)
    VCC:.................................4.15kO
    • mon2
      • Dec 2019
      • 14342
      Based on the very low resistance to ground measurements of SRN / SRP, the charger IC appears to be defective. Suggest to flux it well and remove off the board. Do not replace this part yet. Then still with no power, measure the resistance to ground of each pin on the charger IC. Need to know if the SRN / SRP and other pads are restored to normal values. What is the value of the ACN / ACP pin to ground after the charger IC is removed?
      Be patient so that the charger IC pcb pads are not torn off the board. Use tweezers to slightly nudge the IC to see if the part can be removed.
      • Peter Toropov
        • Mar 2024
        • 16
        Both the ACN and ACP are shorted to ground.
        ACN: short
        ACP: short
        LG: short
        SRN: short
        SRP: short
        HG: short
        LX: short
        • mon2
          • Dec 2019
          • 14342
          Would you have resistance values on these points or using diode mode checking? Best to use the lowest resistance scale on your meter and then measure again to ground.
          Interested in the resistance readings in ohms for each.
          • Peter Toropov
            • Mar 2024
            • 16
            They all give 0 Ohms in resistance mode.
            Will check in diode mode later as the multimeter I have right now can't measure diode mode.
            • mon2
              • Dec 2019
              • 14342
              Diode mode is not required if the resistance scale is known to be stable. Short your probes and you should also see a 0 ohm resistance. Concern is with the 0 ohms to ground on the main power rail. Inspect the board for obvious solder shorts on the board. If not present, then inspect the resistance across the mosfets (source & drain; source & gate; gate & drain pins); check the resistance to ground of each inductor on the board.
              Do you have an adjustable power supply for voltage injection? Do not proceed yet but perform the above reviews.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                #27
                Schematic/bdv is not linked-so cant check but its clear that the damage is very likely in high side charging mosfet. Remove the mosfet connected to HG pin of charging ic and check again for short.
                • Peter Toropov
                  • Mar 2024
                  • 16
                  I apologize for not replying earlier, I, sadly, don't have a variable power supply for voltage injection. Checked all the inductors, almost all of them gave a resistance of 0 ohms to ground. Should I make a list of one's that have resistance? Or both with resistance and no resistance?
                  Also, removed the mosfet connected to HG, PQH8901. Short to ground on IC HG pin, as well as on AC_BAT_SYS has disappeared. Resistance on AC_BAT is now 3.9mO. Checked the battery connector itself, BAT_CON to ground gives 0 Ohm resistance.
                  I have also received some replacement charger IC's
                  Can I attach the boardview in the next post?
                  • mon2
                    • Dec 2019
                    • 14342
                    Post a pic of the front face of your meter while measuring one of the 0 ohms to ground. Something else may be wrong if you are reading 0 ohms on so many coils.
                    • Peter Toropov
                      • Mar 2024
                      • 16
                      Apologies for not replying for so long, had to catch up with school.
                      Checked HG again, just in case, got no reading from it to GND.
                      Attaching the pictures of resistances from inductors to ground and a boardview.
                      • Sephir0th
                        • Oct 2020
                        • 1283
                        CPU Core supply measuring 0 Ohms usually means a dead CPU, except there "just" went something very wrong with your capacitor replacement. But it stongly looks like a typical high-side short.
                        Charging rail measuring 0 Ohms explains the not charging battery. However, from my understanding there is no point to proceed with the repair attempt. Even of you fix the problem in the charging circuit, you can't do anything for the CPU anymore.
                        FairRepair on YouTube
                        • Peter Toropov
                          • Mar 2024
                          • 16
                          That's unfortunate to hear, but at the same time was kind of expected. Nevertheless, due to this "project" being an educational one to me in terms of how to troubleshoot things, practicing soldering and general knowledge gaining, I would like to try and resolve those high and battery rail shorts, if it is possible.
                          • novice1
                            Acer Aspire E5-574G - Not Powering On
                            by novice1
                            Laptop name Acer Aspire E5-574G. Processor = i7-6500u. GPU = NVIDIA GEFORCE 940M. Motherboard Model = DA0ZRWMB6G0
                            This laptop was not powering on at all so I started investigating. The blue light would come on for a second, and then disappear. Fan would sometimes turn on for a second and then shut off immediately, and at other times would not turn on at all.
                            To start with, about 3 months ago I had no clue about soldering, motherboard schematics, board view, and then I stumbled about this forum and other stuff online. I have never done any of those before. But to ask...
                            11-03-2023, 05:53 PM
                            ASUS ROG GL702VM-BA131T Notebook Strix Specification for Upgrade or Repair
                            This specification for the ASUS ROG GL702VM-BA131T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL702VM-BA131T boardview and GL702VM-BA131T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 07:29 AM
                            ASUS ROG GL702VM-BA309T Notebook Strix Specification for Upgrade or Repair
                            This specification for the ASUS ROG GL702VM-BA309T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL702VM-BA309T boardview and GL702VM-BA309T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 07:25 AM
                            09-06-2024, 06:11 AM
                            ASUS ROG GL702VM-DS74-HID4 Notebook Strix Specification for Upgrade or Repair
                            This specification for the ASUS ROG GL702VM-DS74-HID4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL702VM-DS74-HID4 boardview and GL702VM-DS74-HID4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 06:08 AM
