820-01958 MBA 13" '20 A2179 - unable to enter DFU
  • cruiser_
    • Nov 2019
    • 124
    • Ireland
    I've got A2179 of unknown history - no liquid damage visible under microscope.
    Macbook starts to an Apple logo, after a few minutes it either turns off or shows error screen (computer had to be restarted etc). Battery is shot (ripped).
    I tried to DFU it. No luck with keyboard sequence - although I am not sure if keyboard works at all - wasn't able to 'D'iagnose or 'R'ecover.
    Board on the bench... Both USBc ports negotiate 20V and current fluctuates a bit to steady out at around 200mA.
    I jumped SOC_FORCE_DFU with PP1V8_SLPS2R. No luck, SOC_DFU_STATUS stays at 0V. DFU host does not detect connection.
    Would appreciate some suggestions as to how to approach this case.
  • mon2
    • 14662
    Disconnect the keyboard and trackpad. Test again. Any difference?
    Review the resistance to ground with no power for each of the following rails as per the following article:
    https://repair.wiki/w/MacBook_Air_A2...nt_draw_repair
    • reformatt
      • Feb 2020
      • 1495
      You should check the board first for any corrosion before you leap into DFU. Had a A2289 the other day where you'd get the Apple logo and it would shut down soon after. Had a shorted PP3V3_G3S_WLANBT power rail due to corroded cap C3724. It was hidden under the small flap covering the WIFI antennas.
      • cruiser_
        • Nov 2019
        • 124
        • Ireland
        Board on bench.
        Checked the rails listed there. All stable. I am getting a stable ALL_SYS_PWRGD/PM_PCH_PWROK/PM_PCH_SYS_PWROK/PLT_RST_L too. When connected via USB both ports negotiate USB speed, PID, VID, etc.
        I looked at the board under the microscope, nothing suspicious found. Granted, I did not look under the metal shields.
        • cruiser_
          • Nov 2019
          • 124
          • Ireland
          A bit of an update... I flashed SOC ROM with T203 dump. The device came back in DFU mode finally (!).
          Unfortunately the restore failed (IPD update / no touchpad). Turned out the flex is broken so cannot continue with the restore.
          Thanks for looking
          • M4n0l0307
            • Nov 2020
            • 171
            • Republica Checa
            Thanks for looking
            Thanks Friend for Update !
