HP G35N no discrete videocard detected
  • Slang
    • Oct 2006
    • 49
    Hi
    all working great but GTX1050 discrete graphic card does not appear in device manager (clearly no driver request).
    A wrong bios version could be the reason?
    Or it is an harware problem?
    TIA
    Slang
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    No measurements? Very likely a hardware problem.
    • EvazX
      ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
      by EvazX
      I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
      Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
      For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
      However, after some time, the replacement motherboard...
      08-25-2025, 06:09 PM
    • Francisco.s
      MSI GP62 7RE no discrete graphics detected
      by Francisco.s
      Hi, this laptop come to me from other repair shop.
      It works all fine but discrete graphics is not detected.
      The motherboard is a Thermal 8-M2L4.5 and bios chip is not the original one.
      I have downloaded and flashed bios chip with E16J9IMS.324 from MSI website, but nothig changes.
      I have flashed EC Firmware with 16J9EMS1.112 via windows. (ECWin.BAT)
      The weird thing is that when ECWin.BAT finish its job, it doesn't reboot, only screen goes black and current comsumtion goes up from 1.5 amps to 2.4 amps.
      I have...
      02-14-2021, 03:06 PM
    • spacez
      XPS 15 9520 - tpm device is not detected - NO ssd detected
      by spacez
      I have an XPS 15 9520 with a damaged bios so I flashed another one from badcaps. in manufacturing mode I changed the service tag but unfortunately ssd is not detected and also the error -tpm device is not detected- please help me. I haven't changed the tpm chip yet. Thanks in advance
      Service Tag: J2MSHW3
      |Express Service Code: 41518077843
      mother board LA-L402P REV 1.0(A00)​...
      08-18-2024, 10:54 PM
    • Nikan.e
      Inno 3d RTX2070 not detected - no I²C connection
      by Nikan.e
      Greetings and Salutations!
      I have encountered a faulty GPU — an Inno3D RTX 2070 Twin. There was a shorted MOSFET on the Vcore rail.
      The faulty DrMOS was removed, and the burned PCB area was milled away.
      All voltages are now good, but the GPU is not being detected.
      I found that the CS pin of the BIOS (GPU) is not being pulled low, and thus, the GPU isn't detected.
      I wanted to measure the SM_Data and SM_Clock, but to my surprise, there is no connection at all.
      I thought these pins were used for communication during startup?!?
      On all...
      03-30-2025, 07:21 AM
    • superdota2
      HP 15s-FQ2552TU nvme drive not detected
      by superdota2
      HP 15s-FQ2552TU
      da0p5hmb8f1 rev f
      sn# 5CD138CCH4
      problem is power on but no display,no bios post
      i search bios here ,i found and it work and got display.
      https://www.badcaps.net/forum/showthread.php?t=104925
      second problem is nvme drive not detected in bios intel rapid storage,
      i tried a working nvme drive but still not detected in bios,
      also tried install system and install intel rapid driver,still not detected....
      06-21-2023, 09:36 PM
