Acer 5742G power problem
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hi, i need help with acer 5742G (it is Compal NEW71 LA-5893P)
    Laptop wont start when connected LVDS. When i disconnect LVDS fan start spin, no picture on VGA output.
    I found that i hava 0.94V on PQ36 and PQ35. and i have 4 Ohm D to S
    I check PQ36 and PQ35 them they have no leakage
    ...the quieter you become the more you are able to hear...
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Re: Acer 5742G power problem
    i check PU998
    • khaahk
      • Dec 2013
      • 781
      • Estonia
      Try a working panel. Measure resistance of lvds connector power lines, pin 1-7.
      • rtstorm
        • Feb 2012
        • 971
        • Croatia
        You mean to plug in the LCD check resistance 1-7 pin
        • khaahk
          • Dec 2013
          • 781
          • Estonia
          With panel attached, 1-7 pin relative to ground. Panel might be shorted or LVDS cable might be shorted.
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            pin 1,2,3,4 = 25 Mohm and falling
            pin 5,6 = 2.2kohm
            pin 7 = 10 ohm
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              if the LCD is bad, laptop shoud work on external VGA port. But i have no picture on it
              • rtstorm
                • Feb 2012
                • 971
                • Croatia
                can you tell me what mean VGA@ xxx i cannot find the cap and resistor
                • khaahk
                  • Dec 2013
                  • 781
                  • Estonia
                  10 ohm is too small. 3V on 10 ohm, meaning it should consume 300mA. Why no picture - maybe it will not show to vga by default, maybe gpu problems. Try another panel first.
                  • rtstorm
                    • Feb 2012
                    • 971
                    • Croatia
                    i try with another panel, and laptop turn on. Still no picture.
                    Ok now we know that panel is fail. Shoud i try reflow GPU
                    • khaahk
                      • Dec 2013
                      • 781
                      • Estonia
                      I would attach POST card to see where the boot process stops. It is unlikely that reflow will fix the problem.
                      • rtstorm
                        • Feb 2012
                        • 971
                        • Croatia
                        i do not have POST card, never used it. i will replace PU998 and se will that help
                        • khaahk
                          • Dec 2013
                          • 781
                          • Estonia
                          PU998 output is 0.96V, should be ok for vga core. If possible reprogram ec and bios.
                          • rtstorm
                            • Feb 2012
                            • 971
                            • Croatia
                            ec?
                            • khaahk
                              • Dec 2013
                              • 781
                              • Estonia
                              U31 - ec bios. In bios download file there is DOS directory with file KBCA230A.rom.
                              • rtstorm
                                • Feb 2012
                                • 971
                                • Croatia
                                found it, now i just need to find universal programator
                                • rtstorm
                                  • Feb 2012
                                  • 971
                                  • Croatia
                                  i reflash the BIOS, still the same issue
