Dell Latitude 7430 - LA-L581P: not powering on, not charging.
  • djtaotao
    • Nov 2023
    • 22
    • Sweden
    Hello guys, I need some help for troubleshoot my personal laptop. It's my first attempt to repair a laptop, I have good soldering skills and basic electronics knowledge.
    Dell Latitude 7430 - not powering on, not charging.
    The USB charger is negotiating the voltage and the USB meter shows 19.98V and 0.08A on both ports.
    When I plug in the charger the led on the power button lights up and stays on for 30s, turns off for 1s and turns on again for 30s and so on.
    The main power rail is done by ISL9538, without battery I have +8.6V and with the battery plugged in I have constant +17.2V on it.
    The disconnected battery shows me 16.2V.
    With battery connected to MB I tried to inject some voltage to the battery connector but is taking no current.
    I changed the charging IC ISL9538 and the associated boost dual mosfets FDPC5030SG with no results, I have the same behaviour.
    I have attached a picture of a reference schematic for the charging circuit.
    3.3V and 5V are present.
    Thank you for any advice!​
  • mon2
    • Dec 2019
    • 14577
    Voltage to ground check on:
    ACOK
    ACIN
    • djtaotao
      • Nov 2023
      • 22
      • Sweden
      AKOK = 3V
      ACIN = 3.8V
      • mon2
        • Dec 2019
        • 14577
        These are good measurements. ACOK is at a logic '1' since the ACIN > threshold voltage from the power adapter so the charger IC likes the power adapter.
        What are the voltage to ground measurements for the DCin mosfets? What is the gate voltage? It must be higher than the voltage being passed between source / drain pins to enable so should be ~25 volts which is supplied by the charger IC.
        • djtaotao
          • Nov 2023
          • 22
          • Sweden
          I assume you're referring to the 1st and 2nd mosfets and I think they are opened by the PD controllers, there are 4 mosfets, 2 for each PD and they are P-channel, the voltage on their gates is 1.8V, and the voltage after them is 19.9V.
          • Bill F
            • Jan 2023
            • 10
            I believe you may have a bad bios. I had two boards behave like that. A new clean bios fixed them.
            • djtaotao
              • Nov 2023
              • 22
              • Sweden
              I believe so. I tried to "cook" a clean one based on yt tutorials but I failed. The CSME FIT tool is giving me some decompress error messages.
              • mon2
                • Dec 2019
                • 14577
                Post your request for a working bios for this logic board in the dedicated bios forum. See above.
                • santoslao
                  • Apr 2017
                  • 130
                  • BZ
                  Would it be possible for you to provide the electrical diagram for this board? I would be grateful!
                    • 21472
                    Read again "I have attached a picture of a reference schematic for the charging circuit." . There is no schematic available but a boardview has recently been released.It is on some paid sites.If you post your request in the thread where you`ve already asked for the schematic someone might post it,if you`re lucky. https://www.badcaps.net/forum/troubl...581p-schematic .Or you could buy it yourself and share it
                    • djtaotao
                      • Nov 2023
                      • 22
                      • Sweden
                      Unfortunately I don't have it. The schematic I posted it above is for the LA-K371P board, most likely the previous Latitude version. That schematic is for free to download on the internet.
                        DELL Latitude 7430 Notebook 7000 Specification for Upgrade or Repair
                        This specification for the DELL Latitude 7430 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7430 boardview and 7430 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7430...
                        09-07-2024, 07:19 AM
                        09-07-2024, 06:31 AM
                      • Stefan Steff
                        Interesting challenge with DELL Latitude 7400 and DELL Latitude 7430
                        by Stefan Steff
                        I have 3 DELL Latitude 7430 with faulty MBs and 2 DELL Latitude 7400 with broken screens.
                        Both have 14'' touchscreen with 30 pin eDP
                        I try to connect the 7430 screen to 7400 and getting picture OK. Yuppie!
                        So far so good...
                        Reboot in BIOS settings to check battery, processor type , etc. everything is OK even the touch is working.
                        At this point I know everything is fine with pin assignment.
                        I installed a Windows 10 Pro x64 and as a big surprise the touchscreen is not working!
                        There is no mention about touchscreen in Device Manager… no device with yellow...
                        10-05-2024, 02:26 AM
                      • Ranch 44
                        recovering abandoned Latitude 7430 laptop, bitlocker trouble
                        by Ranch 44
                        I've inherited a Dell Latitude 7430 with W10 that has Bitlocker installed. I have no documentation at all, so no recovery passwords.
                        I want to format and re-install Windows with no Bitlocker. I've gone to BIOS and made the USB with the install the first boot option, and that works. But when following the prompts to install, when I am asked what drive to format the option area is empty. It suggests loading drivers.
                        I have gone to Command Prompt and am able to see the C: drive and it's four partitions there.
                        I can see the Bitlocker ID in Command Prompt...
                        07-03-2023, 02:28 PM
                      • farouk_1994
                        DELL Latitude 7430 bios
                        by farouk_1994
                        Hello please i need bios bin file clean me for Dell Latitude 7430 Clean dump...
                        04-19-2023, 04:22 PM
