HP Pavillon Laptop I5 G34A Mobo no startup or led power light.
  • Med-Tech
    • Jan 2024
    • 26
    i have a problem with a my HP laptop. No startup or led power light, when I plug in the mains supply. After testing the 19V rail, up until the first MOSFET all seems good. The first MOSFET measures 19V in, but output voltage fluctuates. Output measures 14V (or there abouts) and begins to drop to around 2V and then increases again. I have replaced this MOSFET to no avail. I have tested for a short, but I am unable to locate one. Has anyone experienced this type of behaviour? Or perhaps someone has an idea what could be this cause of this?
    Pic with measurments attached.
    aClick image for larger versionName:	Mobo G34A Pic 1.pngViews:	45Size:	10.61 MBID:	3180464
    Thanks for looking and hopefully for your positive input.
  • mon2
    • Dec 2019
    • 13846
    Post the following:
    1) full top side markings of these mosfets
    2) the charger IC that should be nearby and perhaps with a BQ marking. Square in shape.
    3) what is the resistance to ground of the mosfet pins that are fluctuating in voltage? No power during resistance checks.
    • Med-Tech
      • Jan 2024
      • 26
      Mosfets in circuit:
      First: AP0203GMT-HF
      Second (smaller in size): 7408 GL8R11
      Third: 6414A GV6G3H
      Forth (not fully in pic at bottom): TPCA 8A11-H
      ISL88750HRZ-T
      3) what is the resistance to ground of the mosfet pins that are fluctuating in voltage? No power during resistance checks.​
      First: Gate = 0, Source = 1.3M and drops, Drain = 2M an drops.
      Second: Gate = 0, Source = 1.9M and drops, Drain = 1.8M and drops.
      Third: Gate = 380K and dropping (measured again and it rises), Source = 100K and rising and drops, Drain = 1.1M and rising.
      Due to the measurement on the second taking rising. I re-measured all again and they were rising. No Power connected, but same behaviour when the power is connected as mentioned in my original post. Voltage increases as the resistance decreases.
      • jasko_jacker
        • Oct 2014
        • 1137
        • italy
        First check with the tester if the mosfets are working (in reality they should be desoldered to test them but a superficial test is possible even if they are soldered), check the drop resistor is not shorted (remove it and test the side opposite the input) . If the mosfets are working and there are no shorts, check the gate resistance of the two mosfets. If everything is correct you can move on to the chip that drives them, download its datasheet and check what the basic conditions are for enabling the power supply.
        • Med-Tech
          • Jan 2024
          • 26
          When you say "check with the tester", do you mean in diode mode?
          Drop resistor being the Current Sensor?
          Also in diode mode?
          If I get this far, your support to do this will be highly appreciated
          Thanks for the support.
          • jasko_jacker
            • Oct 2014
            • 1137
            • italy
            This system also uses an AD_ID (check schematic) to validate the power supply. However, before investigating the system that manages the battery charge and the 19V from the power supply, you can try to understand if there are no other problems. 1) remove PR2 2) check if pin 2 of R2 is shorted: if it is not short, connect a wire to pin 2 of R2 and inject 19V and try to turn on. Do not connect the battery when you are testing the system this way.
            • jasko_jacker
              • Oct 2014
              • 1137
              • italy
              However, this type of test should be done as a last chance and it is advisable to try to identify the problem first. This is because even if normally there shouldn't be any problems we are always bypassing the power system which is also a protection
              • jasko_jacker
                • Oct 2014
                • 1137
                • italy
                I'm waiting the renesas allow to me to download the full datasheet of charger ic ISL88750HRZ-T
                • Med-Tech
                  • Jan 2024
                  • 26
                  I removed PR2 and tested out of circuit. It tested as 0.1ohms as it should. I resoldered it and injected 19V. You can see the result, as I have uploaded two vids. The first is 19V injected and the Second is also, but with pressing of power switch. Seem good?
                  Last edited by Vesko356; 01-19-2024, 03:37 PM. Reason: External url removed. Video files attached to post from link.
                  • Vesko356
                    Vesko356 commented
                    Editing a comment
                    Do not upload files to external server please.
                    Add the files as an attachment to your post.
                • jasko_jacker
                  • Oct 2014
                  • 1137
                  • italy
                  Normally PR2 should be desoldered before injecting the 19V because that resistor which has a very low value (so as not to affect the circuit) is connected to the ISL88750 chip and produces a potential difference...... How many amperes have you set the power supply that supplies 19V? You are using cables that are too small, the cable on PR2 must be soldered to pin 2 (without pr2) otherwise you cannot do any checks on the board. After you have made these connections and if the power supply does not show max amps (basically there is a short somewhere) check if there are 3V on the power button even if the system should start automatically. (obviously in addition to the main battery you must also remove the RTC battery if it is present)
                  • Med-Tech
                    • Jan 2024
                    • 26
                    The PSU is set to 0.3amps. What do you mean when you say the cables are too small? not thick enough? Once I know which cable to use, I will do as you have instructed and report the outcome 👍
                    • Med-Tech
                      • Jan 2024
                      • 26
                      PSU set to 19V 0.3amps. I have done some measurements (pic attached) as well as testing for 3V at Power Switch. 3V not present and the PSU displays 0amps drawn.
                      • jasko_jacker
                        • Oct 2014
                        • 1137
                        • italy
                        You must set the PSU to 4A 19V otherwise the system does not have enough current. The cables with which you make the connections must be at least the same size as those of the original power supply otherwise they heat up and do not pass enough current
                        • jasko_jacker
                          • Oct 2014
                          • 1137
                          • italy
                          Remember to follow carefully what I wrote especially about removing the drop resistance see #6
                          The purpose of this test is to verify, by bypassing the IC that manages the charging and power management mosfets to verify that the system has no other problems, in 90% of cases this type of test works by just making the connection as per diagram #6 other times it is necessary to make changes. Check that the 19V line is not shorted and do the test I recommended, then based on the result you will understand whether the problem is limited only to the charging IC or there are (as I suspect) other problems
                          • Med-Tech
                            • Jan 2024
                            • 26
                            Having followed your instructions the 19V gets to PQ5 Drain, at the Source it measures 100mV. This is the same with the DC Jack plugged in and PR2 soldered to the board. I did some poking around doing different measurements and found that at PU19 (RT8813A) the following pins are shorted to ground, 24, 22, 19, 11 and 10. Looking at the datasheet, they should not be (if my understanding is right). After this my knowledge fails me. I tested most of the components connected to these pinouts and could not find the source of the shorted pins. Am i barking up the wrong tree here?
                            Click image for larger version  Name:	RT8813A.png Views:	0 Size:	153.1 KB ID:	3227284
                            • Med-Tech
                              • Jan 2024
                              • 26
                              I think I understand why those pinout are reading short on PU19. Having looked at the Schematic, pins 24, 19, 11 and 10 are in connection with VGA Core (due to low resistance here, MM beeps). Pin 22 is GND/PWM3 (GND is GND). What i do not understand is what the problem is... my head hurts.
                              • Sephir0th
                                • Oct 2020
                                • 1260
                                This is a NVDC charging controller, so the main power rail does NOT start after the second Mosfet.
                                Random measurements of random components (e.g. controller for GPU Core) likely won't lead to any progress here.
                                in my opinion there was digged in way to early. I strongly suggest a full measurement of the charging controller (voltages and resistances) before moving further.
                                FairRepair on YouTube
                                • Med-Tech
                                  • Jan 2024
                                  • 26
                                  finally getting some power into the Laptop. It is now drawing 12mA, before it was drawing null power. This happened after swapping out PQ7. Obviously it still does not turn on or light the LED, but progress keeps me determined.
                                  Your thoughts/input are welcome and appreciated.
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    gate Biasing of dc-in mosfets is correct now? 19V is reaching CLR?
                                    If the answer is yes,then absence of light at dc jack is probably due to absence of 3V LDO.
                                      Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                      by sam_sam_sam
                                      I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                      I also have back when Light of America had these light bulbs available for yard lights
                                      The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                      While the Lithonia lighting fixture has all most certain bulb failure
                                      So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                      I have only had this light fixture for not more than a year if it...
                                      07-02-2023, 03:45 PM
                                      LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                      This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 03:40 AM
                                      LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                      This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 09:10 PM
                                      09-06-2024, 08:40 PM
                                    • esqmooo
                                      HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                                      by esqmooo
                                      Hello everyone.
                                      This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                                      Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                                      Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                                      I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                                      03-11-2025, 03:57 PM
