hp x360 convertible 14-dh0086ne turn on but not charging
  • bembeno
    • Feb 2016
    • 309
    • egypt
    HP x360 convertible 14-dh0086ne turn on but not charging
    sn#8CG9221BJR - PRODID 7DM15EA#ABV
    FAROE_DIS_X32_MB_MV
    18742-1
    448.0GG03.0011​
    charger ic : BQ24781
    volt on Battery coil 0.858 v
    which pins should i check on BQ24781
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    VCC/ACN/ACP/CMSRC/ACDRV/REGN/ACDET/ACOK/SDA/SCL-Check these pins to begin with.
    • bembeno
      • Feb 2016
      • 309
      • egypt
      vcc 19 v - ACN 18.8 v - ACP 18.8 v - CMSRC 19 v - ACDRV 19 v - REGN 5.9 v - ACDET 2.8 v - ACOK 3.1 v - SDA 3.2 v - SCL 3.2 v
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        ACDRV at 19V is wrong. Either of the two dc-in mosfets is shorted. Check them in resistance mode between
        Source-gate
        Source-Drain
        Gate-Drain
        • bembeno
          • Feb 2016
          • 309
          • egypt
          you r right i found low resistance between Source&gate Source&Drain Gate&Drain​ of the 1st mosfet after charging port = 0.4 ohm i replaced it with n channel mosfet and now i have about 12 volt on battery coil and its work good - thank you
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Nice to know you fixed it but the fault is pretty basic for someone who is in this forum from 2016. So put some more hard work in diagnosing problems. Hope you take it in postive manner.
