Lenovo IP3 NM-D471 No power
  • BlueRay
    • Jul 2018
    • 20
    • Indonesia
    This board has no power. I have 20v on PQ5400 pin 5678. ACDRV on Pin 4 = 0V. Tested change charging ic BQ24780s, no result. Try change PQ5400 and PQ5401 also same. try bypass PQ5400 and working find. i got the power and laptop turn on fine. No short circuit find.
    28 VCC = 20v
    24 REGN = 6v
    6 ACDET = 2.6v
    5 ACOK = 0v
    For ACOK, can i get it directly from REGN pin on charging ic? On the schematic, PR5436 and PR5437 has no component attached. so if i put 2 100k resistor to get 3v acok. does its ok? or maybe i should check other component?
    [MOD EDIT] Link to schematic -> https://www.badcaps.net/forum/troubl...15itl6-nm-d472
    Reminder: rules and organization of this section -> https://www.badcaps.net/forum/troubl...f-this-section
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    You cant generate ACOK forcibly. The IC is pulling ACOK low for some reason. Theoritically,even if ACOK is forced,ACDRV wont work as CMSRC is still missing. Resistance measurements for PQ5400/5401 between
    Source-Gate
    Source-Drain
    Drain to Gate
    • BlueRay
      • Jul 2018
      • 20
      • Indonesia
      Source-Gate
      Source-Drain
      Drain to Gate
      I measure them without desolder
      PQ5400
      Source to Gate : 3.9 ohm
      Source to drain : 3.4 Mohm
      Gate to drain : 5.5 Mohm
      PQ5401
      Source to drain : 4.0 Mohm
      Gate to drain : 3.28 Mohm​
      • mon2
        • Dec 2019
        • 14832
        Source to gate are in ohms or Mohms? If ohms, they are shorted. Be sure there is no power during resistance checks.
        • BlueRay
          • Jul 2018
          • 20
          • Indonesia
          In Mohms. i dont think this two mosfet shorted. because i try remove PR5425. 20v can pass thru PQ5401. checked after PR5425. no short find.
          • mon2
            • Dec 2019
            • 14832
            ACOK is an open-drain output. For this reason, this line must have a pull-up resistor to park this line when the ACOK output is hi-z (high impedance / tristate). That is, if this line is NOT ok in case the power adapter is wimpy then this line will be pulled LOW by the charger IC. If the adapter is deemed to be OK, this line will float and therefore an external resistor must be present.
            In tracing this ACIN netname, the resistor of interest appears to be @ RE89. Confirm it is present on your board and also confirm that you have a valid voltage for +3VL. Summary: ACOK is low because the power adapter is wimpy OR you are missing the +3VL rail to park this floating line (my guess is this condition - final answer).
            • coasterghost
              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
              by coasterghost
              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
              System Hardware:
              Processor: AMD Ryzen 7 PRO 5850U
              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
              09-08-2025, 10:46 PM
              Lenovo 3000 Series Schematic
              Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
              3000 C100 laptop with Braille keyboard
              Lenovo 3000 C
              C100, C200 - 15-inch XGA screen
              Lenovo 3000 N
              N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
              N500 - 15.4 inch screen.
              Lenovo 3000 V
              V100, V200 - 12.1-inch WXGA models
              Lenovo 3000 G
              G400, G410, G430, G450, G455, G510, G530, G550, and G560...
              10-04-2024, 06:05 AM
              Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
              This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
              09-06-2024, 06:40 AM
              This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
              09-06-2024, 06:06 AM
            • derradji89
              Need help Lenovo MIX 320-10lCR domaine name SERCOL
              by derradji89
              Hi everyone 🤗
              I have a Lenovo MIX 320-10lCR computer.**
              1. **Operating System**: Windows 10 ** Education** 64-bit.
              2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
              3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
              4. **BIOS Chip Reflashing**: Currently,...
              04-19-2025, 03:04 PM
