Hello, I got a macbook pro motherboard 820-4924 that refuses to turn on. The motherboard draws 0.22 amps on bench PSU and PPBUS_G3H is 12.59 volts. P3v3s5 and P5v1_sw are both present and power button has 3.3v but it does nothing. The charger light blinks between green and orange. No visible damage on motherboard aside from lint and dust. The charger was swapped and there was no difference. What could be the issue here?
Macbook Pro 820-4924 Not powering on
by echothegamerHello all,
Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
Details:
Macbook 13' A1466
Board (820-3209-A)
Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
Pictures below of Boardview and schematic...
I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
It's an older model and it is very likely that battery has become... -
by TechSplendidHi All,
I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior... -
by envymHi everyone!
I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...06-27-2025, 08:54 AM -
by motormayhemLaptop Question
I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when... -
by paparazzo79Hi guys.
May I charge this model with 60 W charger?
I know it requires 80 W to charge, but don't want to buy one.
If it specifically requires and 60 W can damage macbook and vise versa, I guess I will have to buy 80 W one.... - Loading...
