Dell 5590 LA-F412P does charge with USB-C not with DC-Jack
  • diamon
    • 107
    • Netherlands
    As mentioned, I have a Dell 5590 laptop with motherboard LA-F412P.
    This laptop works with the USB-C charger and not with DC-Jack charger.
    With the USB-C charger attached, the battery is charging and in the BIOS the charger is also recognized.
    With the DC-Jack charger attached (USB-C charger removed), the light of the charger is not going off and the BIOS does not see the charger (message AC Adapter = Not installed). I'm using original Dell chargers and I have tested the used chargers on other Dell laptops and they are working correctly.
    I have replaced the DC-Jack, but still the same.
    According to owner of this laptop, they have used a wrong charger (don't know any other information, cannot ask the owner (holidays)).
    Have done some measurements and the first mosfet PQ9, there is on the Source 19.5V and the Gate has 17.8V, there is no voltage on the Drain.
    Done some random measurements, and did not find any shorts on the board.
    When I bridge the Source and Drain with a wire, the laptop turns on and is working correctly. In the BIOS the message "AC Adapter = Not installed" is then still there.
    According to my knowledge, when there are issues with the NB_PSID signal, the laptop should turn on, but the battery does not charge and the wattage cannot be determined.
    Any suggestions or directions ?
  • mon2
    • Dec 2019
    • 14211
    Link the schematics if available but do not post them here directly. The schematics should be in the dedicated forum.
    Update : Could not find the schematic in my paid sub. You will have to locate the charger IC on your board to continue with the investigation. Probably will be a TI / BQ series charger IC which will feature the ACDRV pin to drive the 2 x DCin mosfets using ~25v on the gate pins to enable each.
    What are the topside markings of your charger IC?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Just stick to basics and problem can be solved.
      01.Check dc-in fets in resistance mode between
      Source-Gate
      Source-Drain
      Gate-Drain
      Check PS_ID circuit. There are plenty of threads on this issue.
      • diamon
        • 107
        • Netherlands
        I have searched on the board for a TI / BQ chip, did not find it. I have the schematic of a Dell 5580 board la-e151p. Those 5580 board are visual very identical as the 5590 boards.
        Source-Gate
        Source-Drain
        Gate-Drain
        PQ9
        Source-Gate 1001K
        Source-Drain 177K
        Gate-Drain 1174K
        PQ4
        Source-Gate 496K
        Source-Drain 103K
        Gate-Drain ​661K
        Regarding the PS_ID circuit, with a not working PS_ID circuit, shouldn't the board start ?
        • mon2
          • Dec 2019
          • 14211
          PQ9
          Source-Drain 177K
          PQ4
          Source-Drain 103K
          These are low readings for a mosfet. At least one is defective. Carefully flux and remove one of the mosfets (suggest the 2nd one on the board) -> allow it to cool and then measure it again when it is on your work table. Before starting, protect the nearby plastic parts from the heat. You can consider to use aluminum foil, etc. + low air pressure. Once the mosfet is removed, check the other mosfet's resistance again. It too may be defective. There are many replacement parts that can work to replace these devices.
          Post the topside markings of these mosfets for guidance.
          • diamon
            • 107
            • Netherlands
            Measurement of the mosfets.
            PQ9 ZB0803 pdf
            Source-Gate no measurement
            Source-Drain resistance 1860K and goes higher it seems, my multi meter cannot show that.
            Gate-Drain no measurement
            PQ4 7409 pdf
            Source-Drain no measurement
            I have done the same measurements, but then on the PCB and the place of those mosfets
            PQ9
            Source-Gate 1002K
            Source-Drain 170K
            Gate-Drain 1174K
            PQ4 7409
            Source-Gate 496K
            Source-Drain 165K
            Gate-Drain 648K
            • flat-earther
              ASUS X54H laptop thinks it's always charging even with charger unplugged
              by flat-earther
              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
              Windows also shows ''Plugged in'' when charger is not connected.
              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
              If I let battery run out and say it has 3% Windows will...
              06-24-2025, 09:32 AM
            • motormayhem
              Lenovo T460 Only Charges on One Charger
              by motormayhem
              Laptop Question
              I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
              A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
              05-12-2023, 01:46 PM
              DELL Vostro 5590 Notebook 5000 Specification for Upgrade or Repair
              This specification for the DELL Vostro 5590 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5590 boardview and 5590 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 5590 Notebook...
              09-06-2024, 07:20 PM
              DELL Inspiron 5590 Notebook 5000 Specification for Upgrade or Repair
              This specification for the DELL Inspiron 5590 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5590 boardview and 5590 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5590...
              09-06-2024, 06:50 PM
              DELL G5 5590 Notebook Specification for Upgrade or Repair
              This specification for the DELL G5 5590 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5590 boardview and 5590 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL G5 5590 Notebook is...
              09-06-2024, 03:30 PM
