Acer Aspire 3 ( dh5jv la-g021p Rev:1)
    The laptop does not start. 19V, 5V and 3.3V are present.
    ON/OFF button is a part of keypad. Is there a way how to check that ON/OFF button is working ( without replacing the keypad)?
    Or is it BIOS problem? Or anything else?
    What to try?
    Thank you for a hint.
    https://youtu.be/YsisRlG_buk?feature=shared
      Thank you for the link. I followed the video. Shorted pin 27 and 28 but the laptop /fan did not start and it takes ( during time Iam shorting pins) about 1mA only.
      ( If keypad flex is unplug there is about 3.3V on pin 27. If keypad is pluged there only 0.3V. Pin 28 is ground.
      What should I try next?Thank you for help
        What is the history of this laptop? Just died one day?
        using original power adapter?
          Yes, just died one day. I use universal adapter that worked with every laptop in the past
            Would you have the attached parts on your board? This is from the Acer Aspire v3-571G schematics in my database.
            Not sure I fully understand. There is PWR button as a part of keypad, as we spoke above.Not separated.
            I enclosed a picture of the mainboard
              ON/OFFBTN# is SWK1 Click image for larger version
                Do you mean there might be an alternative/another way how to start the laptop?Via SWK1 ?
                  Yes.
                    I tried to start the laptop via SWK1 but still the same behaviour - the laptop did not start.
                    Do you think it can be BIOS problem or SuperIO or different problem?
