Acer nitro 5 AN517 battery not charging
  • nickstyle
    • Aug 2022
    • 42
    • United Kingdom
    Hi, I got this laptop with a dead GPU and i have replaced the moderboard same model
    The problem the new motherboard does not charge the battery. The faulty motherboard is charging.
    In windows the battery is presend and if i plug in the charger is detected
    All voltages are present
    What i have done :
    -i have replaced the BQ chip
    -i have replaced the IO chip with the IO chip fron the faulty motherboard
    -i have replaced the bios chip with the one from faulty motherboard
    Nothng has changed
    Any other ideea?
  • mon2
    • Dec 2019
    • 14659
    With care, measure and post the voltage to ground of each pin on the BQ charger IC for a review. Do attach the power adapter and battery for this review.
    Questions:
    1) Same charger IC part # was used for the replacement?
    2) BQ and other replaced parts are properly soldered onboard?
    3) Is the battery a known good battery? It was the same battery that worked with the fault motherboard?
    • nickstyle
      • Aug 2022
      • 42
      • United Kingdom
      Found the problem
      It was so easy but i have spent few hours to find it
      The first mosfet from the power supply circuit was shorted,so it was working like a fuse. I didn`t check as the laptop was working fine.
      Now is charging
      Thank you for your quick answwr
      • mon2
        • Dec 2019
        • 14659
        Np. Your case is mentioned in the sticky above on charger circuits by piernov. Good job on the repair!!
        • nickstyle
          • Aug 2022
          • 42
          • United Kingdom
          I did that, first thing before postig but i have missed the part with DC shorted mossfet )
          Thank you
          • Source Code
            Acer Nitro 5 not charging but working with battery
            by Source Code
            Hello Everyone
            First I must say I am trying to learn electronics. I have an Acer Nitro 5. Board is LA-861P. The laptop does not charge but when it has battery life it would power on and work fine. I have use a multimeter to check the charger and I get 19v.
            Input on PBQ3 mosfet is 19v but no output or very low voltage. The voltage on PCZ65 and PCZ48 is 2v and it keep dropping after putting the charger for a few second. Battery pin would give like 0.200v declining.
            If I put the laptop off for like 2-3 months it would start charging again but I need to do this...
            11-17-2024, 12:44 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • abrahim110
            [Help Needed] Acer Aspire 5 A517-52G โ€“ Removed Onboard RAM, Now Working But Battery Not Charging
            by abrahim110
            ๐Ÿงต [Help] Acer Aspire 5 A517-52G โ€“ Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
            I have an Acer Aspire 5 A517-52G-53NB laptop.
            The onboard (soldered) RAM was faulty, so I physically removed the chip.
            I also successfully modified the BIOS using the SPD Removal Tool โ€“ the laptop now boots fine and works with an 8โ€ฏGB DDR4 SO-DIMM installed.
            โœ… System status:
            • BIOS mod is done (SPD removed)
            • Laptop boots to Windows normally
            • RAM is detected and stable
            โŒ Problem:
            The battery is not charging:
            • Power adapter
            08-06-2025, 06:15 AM
          • titomno2
            Acer A315-41G similar to AN515-42, AC OK Battery OK but not charging
            by titomno2
            Hi guys,
            I currently trying to figure out why the laptop of my friend did not charge.
            It is a Acer AN515-42 (Ryzen 5 2500U), I manage to make it works on AC and battery but no charging.
            At first it was not working on Battery, I discovered that PQ201 was knocked off and replace it => work on battery precharged on another computer.
            I also checked the small resistors between PQ312 and PQ201 and even if they are ugly values are OK.
            My issue, when I plug the charger computer off, it drains 0.25A during few seconds with amber light on (charging) then amber light blinks...
            06-11-2024, 11:52 AM
            ACER NITRO Nitro N50-600 NITRO 50 i7-9700 Specification for Upgrade or Repair
            This specification for the ACER NITRO Nitro N50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro N50-600 boardview and NITRO Nitro N50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
            09-12-2024, 03:28 PM
