Asus FX506HM DA0NJMBAH0 - no backlight
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3593
    • slovakia
    Hello.
    Have this Asus FX506HM DA0NJMBAH0 with no backlight. I measured
    PCH_BRIGHT - 1.16V
    +VIN_BLIGHT - 20V
    +3VLCD_CON - 3.5V
    is that 1.16V on PCH_BRIGHT too low? but i dont have short on its rail and it come straight from PCH
    any hint?
    https://www.badcaps.net/forum/troubl...c-or-boardview
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    1.16V is definitely low.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3593
      • slovakia
      but it is come right from PCH. only ESD and capacitor on that line. no low resistance/25Kohm/. is that PCH damaged or some sensor or bad bios fw can do this? i see some light sensor for backlight on some laptops, maybe it have some
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3593
        • slovakia
        disassembled lcd but found only camera and two mic, no ambient light sensor
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          There are no components inbetween on new gen mb's making them very susceptible to PCH damage. I'll suggest to cut the track for PCH_BRIGHT and apply 2.5V-3.0V directly on edp connector and see if backlit works. After all you cant cure the PCH,so lets try a workaround. Even if it works,you'll loose brigtness control.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3593
            • slovakia
            laptop works normally with this anomaly. i cut wire and bridge it to next pin +3VLCD_CON but nothing changed
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Check whether +3VLCD_CON is dropping low after bridging..Best not to bridge with any pins from edp connector and use your dc supply to put voltage(This way you also know the current consumption which may give some clue).
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3593
                • slovakia
                first i was injecting with psu, but it not work and was little uncomfort because of thin cable. power consumption was 0.0W, i start to think something bad was happen in that brightness line.i must find some testing 144hz lcd
                • ash91
                  • Jun 2023
                  • 31
                  • SAUDI
                  Well my friend i think your problem is the backlight enable signal (bklt_en) or so you can test it by locate the signal on led connector pin
                  or on the screen panel there is a test point (which is a small dot ) with bklt_en next to it there shuld be 3v on it
                  if that is the issu you can bybass it by a jumper from 3 v coil or from the screen it self
                  also by a jumper from 3v fuse to the bklt_en point on the screen panel
                  i hope this be useful to you
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3593
                    • slovakia
                    i dont know why, but i remove lcd and connect another and it works, i connect original again and it works.
                    • ash91
                      • Jun 2023
                      • 31
                      • SAUDI
                      Glad to know that problem sovled,some times it is just do not want to work and some times it works
                        ASUS TUF Gaming FX506HM-HN045 Notebook F15 Specification for Upgrade or Repair
                        This specification for the ASUS TUF Gaming FX506HM-HN045 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX506HM-HN045 boardview and FX506HM-HN045 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-07-2024, 02:20 AM
                        ASUS TUF Gaming FX506HM-HN060 Notebook F15 Specification for Upgrade or Repair
                        This specification for the ASUS TUF Gaming FX506HM-HN060 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX506HM-HN060 boardview and FX506HM-HN060 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        ASUS TUF Gaming FX506HM-HN014T Notebook F15 Specification for Upgrade or Repair
                        This specification for the ASUS TUF Gaming FX506HM-HN014T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX506HM-HN014T boardview and FX506HM-HN014T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                        09-07-2024, 01:00 AM
                        ASUS TUF Gaming FX506HM-HN004W Notebook F15 Specification for Upgrade or Repair
                        This specification for the ASUS TUF Gaming FX506HM-HN004W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX506HM-HN004W boardview and FX506HM-HN004W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                        09-07-2024, 04:30 AM
                        ASUS TUF Gaming FX506HM-HN019T Notebook F15 Specification for Upgrade or Repair
                        This specification for the ASUS TUF Gaming FX506HM-HN019T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX506HM-HN019T boardview and FX506HM-HN019T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                        09-07-2024, 03:10 AM
