Toshiba C660 IGp chip get really hot.
Re: Toshiba C660 IGp chip get really hot.
Yeah once the solution gets hot "inside the enclosed portion only" but it does not emit any gas it all stays in the pipe and all kinds of solutions are used there is no real good information on the solution which is a liquid I suppose it does turn into a gas and back to a liquid...
Many times the graphics chipset which is what I thought was being discussed is just a little shim coming off of the pipe and there is no gas in this portion it is connected to the portion with gas but I haven't recalled seeing many if any graphics chipsets having a hollow shim with gas in it per say the tubes themselves are the only thing that contain gas...
Anyhow I guess I may have read into the answer a little further than I should have so your claim with gases would be semi correct as it is like the handbone connecting to the finger bone and the hand bone has gas but the finger don't ... Anyhow should be plenty of clarity.
But this is what I would check ----> http://www.youtube.com/watch?v=fhIHfBy0khYPlease note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.Comment
Heat is transferred to the shim which covers the chip. The heat from the shim is transferred to the heatpipe welded to it. The increase in heat gives the heatpipe liquid enough energy to enter the gaseous state. The gas diffuses along the heatpipe to an area of cooler temperature (the heatsink fins), where it then recondenses forming a liquid.Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSDComment
Thanks for all the input. I had stripped the laptop down and dismantled the fan to remove the lint. I refitted and used MX4 thermal compound. I also fitted a copper shim but I did notice the air coming through the vents of the heatsink was not really hot at all so the Air/Liquid/gasses or whichever it is are probably the fault here if the heatsink is not conducting the heat away. The heat is very localised as in both the IGP and the opposite side of the pcb are very hot 69-70c this is just on the bios screen. Im going to order a new heatsink to see what it does. The reason I mentioned the S/C caps on the Igp was because I check a few other board I have and none of them had S/C caps on the Igp chip itself. Also I removed both S/C chips and the short was still there. I thought maybe the chip was drawing too much current and heating up but due to the fact theres not hot air being pulled away I think the new heatsink might be the best bet.Comment
This specification for the Toshiba Satellite Pro C660-1NQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660-1NQ boardview and C660-1NQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:27 AM
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by DynaxSCHi
I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6... -
by SMDFleaCommon SPI bios chip programming Questions and Answers
Bad...-
Channel: BIOS Requests ONLY!
09-02-2021, 04:40 PM -
This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
- Loading...
